Salta al contenuto principale
iRobot Braava 320 Deck Plate Assembly Replacement
Cosa ti serve
  1. iRobot Braava 320 Deck Plate Assembly  Replacement, Battery: passo 1, immagine 1 di 1
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
  2. iRobot Braava 320 Deck Plate Assembly  Replacement: passo 2, immagine 1 di 1
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
  3. iRobot Braava 320 Deck Plate Assembly  Replacement: passo 3, immagine 1 di 2 iRobot Braava 320 Deck Plate Assembly  Replacement: passo 3, immagine 2 di 2
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
  4. iRobot Braava 320 Deck Plate Assembly  Replacement, Body Shell and Control Panel: passo 4, immagine 1 di 1
    • With the battery removed, rotate your device so the front of it is facing you.
    • Remove the four 10mm Phillips #2 screws that attach the shell.
  5. iRobot Braava 320 Deck Plate Assembly  Replacement: passo 5, immagine 1 di 2 iRobot Braava 320 Deck Plate Assembly  Replacement: passo 5, immagine 2 di 2
    • Using both hands, hold the device together while you flip it over.
    • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
  6. iRobot Braava 320 Deck Plate Assembly  Replacement, Deck Plate Assembly: passo 6, immagine 1 di 1
    • With the shell off, flip the iRobot over and remove the four 10mm Phillips #0 screws holding the deck plate assembly on.
  7. iRobot Braava 320 Deck Plate Assembly  Replacement: passo 7, immagine 1 di 3 iRobot Braava 320 Deck Plate Assembly  Replacement: passo 7, immagine 2 di 3 iRobot Braava 320 Deck Plate Assembly  Replacement: passo 7, immagine 3 di 3
    • Remove the two 12mm Phillips #0 screws that hold the two springs onto the deck plate assembly.
    • Remove the two springs by gently lifting them up.
  8. iRobot Braava 320 Deck Plate Assembly  Replacement: passo 8, immagine 1 di 1
    • Flip the device over and remove the deck plate assembly cover by lifting it up.
  9. iRobot Braava 320 Deck Plate Assembly  Replacement: passo 9, immagine 1 di 1
    • Pull the arms together by lifting them up and to the center.
    • With the arms together. slide the deck plate up and over the arms until it is fully removed.
Conclusione
USF Tampa, Team S1-G3, Nance Spring 2017 Membro di USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 12
Tutti i Tempi: 588
