Salta al contenuto principale
iRobot Braava 320 Body Shell Replacement
Cosa ti serve
  1. iRobot Braava 320 Body Shell Replacement, Battery: passo 1, immagine 1 di 1
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
  2. iRobot Braava 320 Body Shell Replacement: passo 2, immagine 1 di 1
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
  3. iRobot Braava 320 Body Shell Replacement: passo 3, immagine 1 di 2 iRobot Braava 320 Body Shell Replacement: passo 3, immagine 2 di 2
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
  4. iRobot Braava 320 Body Shell Replacement, Body Shell and Control Panel: passo 4, immagine 1 di 1
    • With the battery removed, rotate your device so the front of it is facing you.
    • Remove the four 10mm Phillips #2 screws that attach the shell.
  5. iRobot Braava 320 Body Shell Replacement: passo 5, immagine 1 di 2 iRobot Braava 320 Body Shell Replacement: passo 5, immagine 2 di 2
    • Using both hands, hold the device together while you flip it over.
    • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
Conclusione
Adam Lewis
Membro da: 02/28/17
214 Reputazione
1 Guida realizzata
USF Tampa, Team S1-G3, Nance Spring 2017 Membro di USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 716
