Salta al contenuto principale
iPod Touch 5th Generation Rear-Facing Camera Replacement
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: passo 1, immagine 1 di 3 iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: passo 1, immagine 2 di 3 iPod Touch 5th Generation Rear-Facing Camera Replacement, Rear-Facing Camera: passo 1, immagine 3 di 3
    • Insert the flat end of a spudger between the rear-facing camera and its frame.
    • Gently twist the spudger to free the camera.
    • Lift the rear-facing camera up out of its socket, and remove it from the iPod Touch.
  2. iPod Touch 5th Generation Rear-Facing Camera Replacement: passo 2, immagine 1 di 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: passo 2, immagine 2 di 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: passo 2, immagine 3 di 3
    • Gently slide the flat end of a spudger underneath the piece of foam tape covering the button ribbon cable.
    • Run the spudger along the full length of the tape to disconnect it from the rear case.
  3. iPod Touch 5th Generation Rear-Facing Camera Replacement: passo 3, immagine 1 di 2 iPod Touch 5th Generation Rear-Facing Camera Replacement: passo 3, immagine 2 di 2
    • Peel and remove the foam tape from the rear case of the iPod.
  4. iPod Touch 5th Generation Rear-Facing Camera Replacement: passo 4, immagine 1 di 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: passo 4, immagine 2 di 3 iPod Touch 5th Generation Rear-Facing Camera Replacement: passo 4, immagine 3 di 3
    • Use the tip of a spudger to peel up the edge of the tape covering the button ribbon cable.
    • Use tweezers or your fingers to peel the tape up from the rear case, and remove it from the iPod.
Conclusione
iFixit Membro di iFixit
Staff
135 Membri
16.718 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 86
