Salta al contenuto principale
iPod Touch 5th Generation Lightning Connector Assembly Replacement
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. iPod Touch 5th Generation Lightning Connector Assembly Replacement, Lightning Connector Assembly: passo 1, immagine 1 di 1
    • Use the tip of a spudger to peel back a small piece of tape covering a screw on the left side of the headphone jack.
  2. iPod Touch 5th Generation Lightning Connector Assembly Replacement: passo 2, immagine 1 di 1
    • Remove the following screws securing the headphone jack, Lightning connector, and speaker.
    • Three 2.6 mm #000 Phillips screws
    • Two 2.0 mm #000 Phillips screws
  3. iPod Touch 5th Generation Lightning Connector Assembly Replacement: passo 3, immagine 1 di 1
    • Use the flat end of a spudger to pry the speaker up from the rear case.
    • Do not try to remove the speaker, as it is soldered to the Lightning connector assembly.
  4. iPod Touch 5th Generation Lightning Connector Assembly Replacement: passo 4, immagine 1 di 2 iPod Touch 5th Generation Lightning Connector Assembly Replacement: passo 4, immagine 2 di 2
    • Grasping the large ribbon cable, gently pull the Lightning connector assembly out of the bottom of the case.
Conclusione
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 225
