Salta al contenuto principale
iPod Shuffle 3rd Generation Rear Case Replacement
Cosa ti serve
  1. iPod Shuffle 3rd Generation Rear Case Replacement, Rear Case: passo 1, immagine 1 di 1
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. iPod Shuffle 3rd Generation Rear Case Replacement: passo 2, immagine 1 di 2 iPod Shuffle 3rd Generation Rear Case Replacement: passo 2, immagine 2 di 2
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. iPod Shuffle 3rd Generation Rear Case Replacement: passo 3, immagine 1 di 1
    • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. iPod Shuffle 3rd Generation Rear Case Replacement: passo 4, immagine 1 di 1
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
Conclusione
Matthew Newsom
Membro da: 01/05/10
41.951 Reputazione
67 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 8,481
