Salta al contenuto principale
iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement
Cosa ti serve
  1. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement, Rear Case: passo 1, immagine 1 di 1
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 2, immagine 1 di 2 iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 2, immagine 2 di 2
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 3, immagine 1 di 1
    • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 4, immagine 1 di 1
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
  5. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement, Logic Board: passo 5, immagine 1 di 1
    • Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
  6. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 6, immagine 1 di 1
    • Remove the single Phillips screw securing the logic board to the front case.
  7. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 7, immagine 1 di 1
    • Peel the battery up from the front case with an iPod opening tool.
    • Remove the logic board and battery from the iPod.
  8. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement, Headphone Jack & Shuffle Switch: passo 8, immagine 1 di 1
    • Pry the headphone jack from the front case with an iPod opening tool.
    • Don't attempt to remove the headphone jack yet, it is connected to the shuffle switch.
  9. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 9, immagine 1 di 1
    • Using the pointed tip of a spudger, push the shuffle switch in to separate it from the front case.
  10. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: passo 10, immagine 1 di 1
    • Remove the headphone jack and shuffle switch from the front case.
Conclusione
Matthew Newsom
Membro da: 01/05/10
39.685 Reputazione
67 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 12,032
