Introduzione
Replace the damaged headphone jack to hear those sweet tunes again.
Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
  • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
  • Be careful when using a metal spudger, as you may scratch the outer case.
Aggiungi Commento
Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
Aggiungi Commento
  • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
  • Pry the rear case away from the front case.
Aggiungi Commento
  • Lift the bottom of the rear case and remove it from the rest of the iPod.
Aggiungi Commento
  • Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
Aggiungi Commento
  • Remove the single Phillips screw securing the logic board to the front case.
Aggiungi Commento
  • Peel the battery up from the front case with an iPod opening tool.
  • Remove the logic board and battery from the iPod.
Aggiungi Commento
  • Pry the headphone jack from the front case with an iPod opening tool.
  • Don't attempt to remove the headphone jack yet, it is connected to the shuffle switch.
Aggiungi Commento
  • Using the pointed tip of a spudger, push the shuffle switch in to separate it from the front case.
Aggiungi Commento
  • Remove the headphone jack and shuffle switch from the front case.
Aggiungi Commento
Conclusione
Matthew Newsom
Membro da: 05/01/2010
31.755 Reputazione
67 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 27
Tutti i Tempi: 10,791
