Introduzione
Sostituisci la scheda madre rotta nel tuo iPod Nano.
Cosa ti serve
Infila uno strumento di apertura per iPod tra la copertura esterna e il bordo superiore vicino allo schermo.
Sollevando lo strumento di apertura per iPod, fai leva per rimuovere il bordo superiore del dispositivo.
Infila uno strumento di apertura per iPod tra la copertura esterna e il supporto in metallo dell'interruttore hold vicino al bordo superiore dello schermo.
Mentre tiri leggermente verso l'alto lo strumento di apertura, tira fuori dall'iPod il supporto in metallo dell'interruttore hold.
My ribbon broke.
I see that on the pictures further down, you removed the covering plate, which I would suggest to do, as it'll put less weight on the ribbon.
Luckily, we can find spare ones. In fact it doesn't sell alone, it's with the earphones jack.
could you elaborate more as to how did you remedy the broken ribbon?
is the broken ribbon fixable?
I am new to this my ribbon broke when I was taking out the battery doesn't the new battery ribbon connect to the one connected to the end switch, by that I mean can I connect the new battery ribbon to the end switch ribbon?,where it broke?
Infila uno strumento di apertura per iPod tra lo schermo e il vetro dal bordo superiore del dispositivo.
Ruota lo strumento di apertura verso il retro del dispositivo, sollevando leggermente il bordo superiore del vetro dalla copertura esterna.
At this point, I find it helps to separate the lock switch from the top metal casting. You then have just the switch dangling on the fragile ribbon cable. Much less likely to snag or break the ribbon. Just loosen (Don't remove completely) the two Phillips screws. The heavy clunky casting bit can be removed.
You can remove this lens with virtually zero risk to the LCD underneath:
Get a couple guitar picks or spudgers ready, and another old spudger. Using a hot glue gun, glue the old spudger into the very middle of the lens. Let the glue cool completely.
Using a heat gun pointing up from the bottom, heat the 3 edges of the shell around the top and sides of the lens. Avoid getting heat on the lens or hot glue as it will soften.
Using the spudger as a handle, pull up on the lens to get the top edge started and get your guitar picks/spudgers under the sides at the top of the lens.
Complete removal as above.
Using a spudger/guitar pick, start to peel an edge of the hot glue loose to remove old spudger from lens; then clean any residue with alcohol.
“couple of” guitar picks
After destroying one iPod, I learned from my mistakes. Heating it with a hair dryer to loosen the adhesive helped a lot. You need to get the tool between the glass and the lcd display; be very careful not to put pressure on the display!
Mentre sollevi lo schermo con lo strumento di apertura per iPod, infila un secondo strumento di apertura tra la copertura esterna e la parte sinistra del bordo superiore del vetro.
Rimuovi il primo strumento di apertura dall'iPod posto tra il vetro e l'LCD nella parte superiore del dispositivo.
The iPod I repared had a cracked screen. Caution here because it doesn't pop out that easily. I had to apply some force on the plastic opening tool while using another tool to take out the shards (who are glued to the side).
90% guaranteed you will destroy the LCD in this step. You just dont know how much for to use and if you stress the LCD too much, even with a plastic tool it will be damaged.That’s why ifixit sells those too. My advice is to first completely follow this guide, and if successful, and only then , start ordering parts.
Since the display is probably 99 percent broken, I decided to use a different method. I heat the ipod on my 3-printer heating bed to around 70 degrees Celsius, then I take a suction cup and pull on the display glass. When the glue is warm enough, the glass rises and you can carefully detach the glass with an opening pick. the display remains completely intact greeting Andre
Con uno strumento di apertura per iPod ancora tra il vetro e la copertura esterna, infila un altro strumento simile tra la copertura esterna e il bordo sinistro del vetro.
Fai scorrere lo strumento di apertura per iPod lungo il bordo sinistro del vetro verso la base del dispositivo per separare l'adesivo.
Sollevando il vetro dal bordo superiore dell'iPod, rimuovi il pannello di vetro dall'iPod Nano.
It might be a good idea to remove all the adhesive from the screen before trying to slide the internals out. I had a nightmare trying to get mine out, ended up cutting my thumb and finger from holding onto the edges of the screen too tight trying to wiggle it out. And then to top it off, I broke the hold switch ribbon cable too. I don’t know how much the screen glue vs the battery glue was responsible for making it difficult to remove. Also when sliding it out, be careful the lip on the lower edge of the button hole doesn’t snag on the thin steel frame around the screen.
Is it really needed to remove the glas? Can‘t you just slide out the logic board when glas remains?
Usa una pistola termica per ammorbidire l'adesivo sotto il bordo in plastica inferiore dell'iPod.
Usa uno strumento di apertura in plastica per fare leva tra il bordo in plastica e la copertura esterna dell'iPod per rimuoverla.
You MUST remove the bottom plate BEFORE forcing of the wheel or you WILL tare it apart as there is a lug on the bottom plate that holds the wheel in place ( wish I had known this before I damaged mine)
also do not lose the very small spring that is under the wheel (I DID )
+1. There is a tiny piece of plastic containing a little spring just under the wheel. Remove thoses parts before extracting the main board or you will probably loose them.
Svita le tre viti dal bordo inferiore dell'iPod:
Due viti a croce Phillips inclinate da 4,4 mm
Una vite a croce Phillips da 5,4 mm
Usa uno strumento di apertura in plastica per fare leva sul supporto in metallo e rimuoverlo dal bordo inferiore dell'iPod.
Infila un plettro tra la ghiera cliccabile e la copertura esterna dell'iPod Nano e rimuovi lo spudger in metallo.
Fai leva sui bordi della ghiera cliccabile con il plettro per sollevarla finché non si libera dalla copertura esterna.
Use extreme care when inserting the metal plunger to lift up the click wheel. I ended up damaging one of the sensor pads and then needed to order a new click wheel circuit. Not very expensive to replace but I had not intended to replace this item and so my finished repair was delayed.
Solleva la ghiera cliccabile con una mano e con uno strumento di apertura in plastica solleva il connettore del cavo a nastro della ghiera dalla sua presa sulla scheda madre per scollegarlo.
Rimuovi la ghiera cliccabile.
In the second photo where you can see under the click wheel, just above the square black piece with the apple on it is a black rectangle with a hole in the center. There will be a spring in the hole. Remove the spring and the black piece it is in and set aside or they will fall out and get lost.
Usa una pistola termica per ammorbidire l'adesivo sotto la copertura della fotocamera/microfono.
Fai leva con uno spudger in metallo sulla copertura della fotocamera/microfono per rimuoverla dalla copertura esterna.
Usa la colla a caldo per coprire la copertura.
Metti il beccuccio nella copertura di colla per 20 secondi per scaldare l'adesivo che tiene ferma la copertura della fotocamera.
Infila uno spudger nella colla finché questa non si raffredda e si indurisce.
Tira lo spudger con una decisione e applicando una forza costante, mentre usi un'unghia per sollevare il bordo della copertura.
Use a heatgun/hairdryer for a very long time and use a cutter knife and pry continuously only from the right bottom corner (near the camera lens). If you don't get it open use the heatgun once more.
Alternatively use a fabric bag filled with chick peas, put it in a microwave for 4 mn at power 600w and leave it to rest on the iPod 10 / 15 mn. It does the same job. I also use a fresh stanley knife blade (mind your fingers) the blade is very slim and is therefore easier to wedge between the casing and the cover.
You can remove this lens with zero damage to case or lens:
Using a hot glue gun, apply a bead of glue across the entire lens but not on the body of the iPod. Move the nozzle back and forth in the glue for about 20 seconds; this keeps the glue hot and heats up the Apple adhesive on the other side.
Quickly jam an old spudger into the hot glue and hold it until the glue starts to harden; this will happen quickly. Gripping the spudger and digging into the glue over the spudger with the fingernail of your forefinger, pull straight up evenly but firmly. The lens will release pretty easily if you time it right; otherwise it will pop if it has gotten cold.
I’ve done a dozen of these this way successfully.
Thanks Paul! I will add this into the step.
This works great, as long as you time it right. I found putting the tip of the glue gun flat against the lens is useful, and a few seconds after the glue stops sticking to your finger is a good time to do it.
Aydan -
just use a needle and pull it from the little hole
have to be careful because after removing the click wheel, when you turn it upside down, the are pieces that fall down. I lost one that fall in my carpet
I was able to remove it using a pin in the small hole. Once it is out there may be pieces that want to fall off; a round ring and the white retainer piece.
Same here. With some pliers I bent the pointy tip of a push-pin to make a 120 degree angle and used that to lift up the plate using the microphone hole after I heated up the plate. Like a mini crowbar. It came off in 30 seconds including the white indent attached to it.
Infila uno spudger in metallo dal bordo superiore dell'iPod tra la batteria e la copertura esterna per separare l'adesivo che tiene ferma la batteria.
In case anyone else didn't realize this, you need to push your spudger fairly deep into the iPod to completely seperate the glue from the battery. I just stuck mine in maybe half an inch, then spent 30 minutes struggling to move the logic board. After removing all of the glue, it slid out with relative ease.
I didn’t have a spudger so I used a metal nail file with a rounded end. Heated the back of the iPod with a hair dryer for about a minute first to soften the adhesive and it all worked fairly smoothly. Be gentle with the lcd display.
Keep in mind the only glue holding the logic board to the metal case is a small rectangle of adhesive. In the picture, the author is just scraping away at the glue. You don’t need to insert your spudger any lower than half an inch as there isn’t any other adhesive holding the logic board to the metal case . Once the glue has been scraped away, then the board should slide out easily. If it doesn’t slide out, then the adhesive is still there.
Infila una puntina nel foro nell'angolo del sistema di bloccaggio e rimuovilo dalla copertura.
I think this step should be step 16. Otherwise you risk to drop the retainer.
Facendo forza delicatamente ma con costanza, spingi sul bordo superiore dello schermo per far scorrere la scheda madre fuori dal bordo inferiore dell'iPod.
Una volta che il bordo superiore dello schermo ha superato il bordo inferiore della copertura esterna, rimuovi il gruppo della scheda madre dal corpo dell'iPod.
I accidentally snapped the little ribbon that held the top of the device. Is it fixable?
Perhaps this one? iPod Nano 4th/5th Generation Hold/Lock Switch Ribbon Cable Repair
Per rimontare il dispositivo, segui le istruzioni in ordine inverso.
Altre 11 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Un commento
at step 14 when lifting the click wheel have a look at the small black bar, placed to the upper edge of the chip. in its center it holds a very small tiny coil spring thats hardly to see and that easily jumps out. better you lift the click wheel in parallel to the ground. if spring jumps off one time, you will never find it again. i guess it has some grounding purpose a it docks on the metal below the logic on the click wheel. also a point to have an eye on at reassembly
