Salta al contenuto principale
iPod Nano 4th Generation Display Replacement
Cosa ti serve
  1. iPod Nano 4th Generation Display Replacement, Glass Panel: passo 1, immagine 1 di 2 iPod Nano 4th Generation Display Replacement, Glass Panel: passo 1, immagine 2 di 2
    • Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
    • Pry the top bezel off the adhesive securing it to the display retainer.
    • At this point the hold switch slider is free and may fall. Be careful not to lose it.
    Be sure to use the smaller iPod opening tool and press it in FIRMLY in order to get enough leverage to get under the bezel and pry it off. Adhesive is very strong, so don't be afraid to use a little bit of force.
    captcarl13 - Replica
    Tool broke before I could get the cover off !!! So I’m done before I even started !!
    linda45p - Replica
    I have a Apple iPod Nano 4th gen(Green) and I only have 7 tech pieces to the iPod and I may/might have the small philips screws and I am not sure how to fix the iPod nano
    Nick Davies - Replica
    I also had Problems to remove the bezel. The solution was to start with a very small screw driver from the hole of the switch. There I could lift it a bit and get the plastic tool in between. Than it was easy.
    Michal Niewiadomski - Replica
    After replacing the battery, the old glue would lump up too thick, and also become too weak to fix the panel back to the outer case. I have scraped all the old glue off using a small flat head screw driver, and affixed a double sided adhesive tape cut into small strips, which was successful in both aspects.
    diytradjazz - Replica
    TIP: Use a plastic tool and pull it out through the hold switch. This may break the top bezel, but this was the only way to get it off.
    Caleb Murphy - Replica
  2. iPod Nano 4th Generation Display Replacement: passo 2, immagine 1 di 1
    • Remove the hold switch slider from the top of the Nano.
  3. iPod Nano 4th Generation Display Replacement: passo 3, immagine 1 di 1
    • Remove the two angled Phillips screws from the two corners of the display retainer.
    • These screw heads are extremely small and easily stripped.
    Be sure to use a good phillips #00 screwdriver here, or you run the risk of stripping the very small screws.
    iTronics Repair - Replica
    The screws were covered with the adhesive. They were very difficult to remove.
    I RUINED the hold switch! I accidentally broke the cord. 0_o The directions were kind of unclear.
    bodieg - Replica
    Citazione da bodieg:
    Step 12 is misleading as it does not show to remove the screen from the metal frame.
    bodieg - Replica
    Sorry guys, but the explanations are really bad. Go onto youtube and watch it. This site misses heaps of steps. I just broke my iPod :(
    S Mile - Replica
    Like others have noted, screws are covered in adhesive and difficult to remove. Take extreme care to not strip the heads. I'd suggest using a very small flathead to scrape some of the adhesive off before attempting to remove the screws.
    a 1mm slotted screwdriver will work in a pinch, but be carefull and make sure you get the angle just right
    andrew - Replica
    The tools list doesn't say you need an iPod opener to, nor does the parts list day you'll need a new click wheel, though this is called ”...click wheel REPLACEMENT​”. I don't get the feeling these are very trustworthy instructions, ESPECIALLY after having read other comments. I'd say BEWARE, and look at a variety of resources to get a much more comprehensive picture.
    Skyfire - Replica
    Actually, the screws are not aligned with the edges of the iPod, which means that you must not try to unscrew them vertically. If you do there is a good chance that you damage the head of the screws. Thus look carefully with a torch to see at what angle you have to unscrew them.
    Fabrice Sarelli - Replica
    Actually, the screws are not aligned with the edges of the iPod. That means that if you try to unscrew them vertically, there is a good chance that you damage the head of the screws. Thus, look carefully with a torch to see exactly at what angle you need to unscrew them safelly.
    Everything was good up to this point. I could barely see the screws and ended up stripping them. Just gave up at this point and threw the
    Ipod on the ground and stomped on it.
    gonzalo gonzalez - Replica
    I agree with several other contributors here, that a properly sized flat screwdriver *that is not worn* held at the correct angle is a better option than a phillips because the screw head is filled in with adhesive tape. BEWARE: The screws on the top and bottom outer edges are not parallel to the case. They are offset by 25 or 30 degrees, with the tips of the screws pointing out towards the outer edge of the case with respect to where the heads are. Use something to get magnification so you can really see how your screwdriver fits, and whether it’s engaged. An undamaged and properly sized standard screwdriver held in the appropriate orientation will readily remove the top and bottom side screws without stripping and with very little force. Feel for engagement — press the screwdriver in just enough to get past the adhesive. Not much torque or pressure is required — just a good fit. You must have the right tools to do this job successfully, and look under high magnification. Align your screwdriver!
    Barry L. Kramer - Replica
    In accordance with another source, I have bought online and used a Phillips #0000 screw driver, which worked pretty well here. It costed me only $2 .
    Screws are inserted under an angle. Would suggest to use a jeweler’s magnifying glass to check the angle before sticking any screw driver in there.
    aramis - Replica
  4. iPod Nano 4th Generation Display Replacement: passo 4, immagine 1 di 1
    • Insert an iPod opening tool between the outer case and the display retainer.
    • Use the tool to slide the display assembly out of the case slightly.
    • Do not rotate the display retainer about the top edge of the display, as it is attached to a thin steel bracket that is easily broken.
    • Do not forcefully remove the display retainer, as the hold switch cable is liable to snap.
    I found I had to gently pry the retainer open with a craft knife (xacto knife?) as the plastic opener tool was too blunt or soft to get any purchase...
    aaaidan - Replica
    My nano had a "swollen" battery which wedged the LCD between battery and front glass. As a result, this step didn't work, I couldn't pull out the TFT and botched case, TFT and TFT frame until it came out. Telltale sign was a display that looked like there is a water between glass and LCD. The other nanos I've opened didnt have this problem and came out effortlessly, so if yours is stuck, don't feel bad, there's not much you can do!
    oliver - Replica
    What to do if the upper metal base (which is fixed to the circuit with 2 screws) came off when extracted?
    Which side can I anchor to force the display to exit?
    Francesco Taliercio - Replica
  5. iPod Nano 4th Generation Display Replacement: passo 5, immagine 1 di 1
    • Slide the display out of the Nano. It will move about .5" until the display data cable limits its travel.
    • Do not put unnecessary tension on the very thin display data cable.
    I have several problems in taking it out. I don't know if it is dued to the glue that the iPod has inside. Could you help me. Thanks
    Hector - Replica
    instructions say 5" (inches) it really means 5mm
    pedalsandpicks - Replica
    Citazione da pedalsandpicks:
    If you're gonna repair the way you read it will get you nowhere: the text reads .(as point)5 inch. Which is about 12mm.
    Frank veenis - Replica
    The glass panel can be very difficult to get moving requiring a lot of downward force. I have found good old fashioned spit to be very useful here.Just lick both thumbs and rub on fingers until just sticky enough.
    This willl move the glass.
    Pete Green - Replica
  6. iPod Nano 4th Generation Display Replacement: passo 6, immagine 1 di 2 iPod Nano 4th Generation Display Replacement: passo 6, immagine 2 di 2
    • With the display pulled out of the case as much as possible, gently press on the lower edge of the glass panel until it pops in slightly (~1 mm).
    • Use your thumbs on the lower edge of the glass panel to slide the glass down and into the case until the top edge pops up out of the case.
    I found the adhesive (or fit) quite strong. Pushing on the bottom part of the glass created a small gap at the top, which I could fit a craft knife (xacto blade) into. This made it easier to carefully lever the glass out for me.
    aaaidan - Replica
    I slipped and broke the LCD. So !#^&@@ off. What an absolute bastard of a job!
    lf - Replica
    What is the "rear edge" of the nano? Can this be a bit clearer please? Maybe a video of this step would be a good idea. Then again, since Apple owns this site, I guess that's not gonna happen, is it?
    lf - Replica
    I don't see "rear edge" anywhere in the instructions. I do see "lower edge" a few times and it looks pretty clear to me. I did this repair a couple years ago without much trouble.
    Rene Jeddore -
    You could do all these steps and really mess up your nano. Instead of disassembling the iPod, carefully remove the remnants of the old glass which I assumed you have cracked. With the new glass in hand CAREFULLY sand one edge of the glass evenly. I used my fine grinder on my dremel tool. After assuring a snug fit I removed the adhesive and installed the glass. Looks great and functional and I didn't ruin my iPod in the process. And when I said sand one edge I mean one of the edges that has a "lip" on it. The other lip you can slide right in and push gently down for a nice fit. Do not remove the adhesive until you are sure of a good fit. This is a quick fix for those who are too queezy to take apart their device.
    Jim - Replica
    My battery had expanded and pushed out the glass enough for me to peel the glue out like a battery pull tab on a phone so it was pretty easy to remove, but the screen is giving me some trouble. The expanded battery is holding the screen to the frame making it more difficult to remove.
    Elijah - Replica
    Absolut falsch beschrieben, die Anleitung ist
    Herbert - Replica
    Grottenschlecht
    Herbert - Replica
    Lieber Herbert,
    schade, dass dir die Anleitung bisher nicht geholfen hat. Stand heute haben bereits 35 andere Nutzer ihr Gerät damit erfolgreich repariert, deshalb wäre es gut zu wissen, was genau bei dir nicht geklappt hat und wo es hakt?
    Unsere Anleitungen werden nach dem Wikipedia-Prinzip geschrieben, das heißt du kannst auch selbst jederzeit noch zusätzliche Punkte hinzufügen oder Änderungen vornehmen, die besser beschreiben, was hilft, damit für diejenigen, die nach dir diese Reparatur versuchen, eine noch umfassendere Dokumentation zur Verfügung steht.
    Sandra Hiller -
  7. iPod Nano 4th Generation Display Replacement: passo 7, immagine 1 di 1
    • Lift the glass panel out of the Nano.
    • Before reinstalling the glass panel, be sure to clean the face of the display and the inside of the panel as any dust or fingerprints will be annoyingly visible when the Nano is turned on.
  8. iPod Nano 4th Generation Display Replacement, Display: passo 8, immagine 1 di 1
    • Use the edge of an iPod opening tool to separate the hold switch from the adhesive securing it to the top edge of the display.
    • The hold switch ribbon cable is extremely fragile and easily broken. Work gently.
    Be extremely careful while doing anything around the screen. The slightest bit of pressure in the wrong direction and you will be replacing the screen along with the battery. I speak from experience.
    Brian Campbell - Replica
    I was extremely careful… and, I broke the display! ~ Gah! ~ $18 for a new one on Ebay (half the price if I wanna wait 3-4x as long to purchase from overseas, twice the price if I buy it from this site!) ~ What a bummer! ~ The goal was to fix this for a customer, and instead I created a longer wait & obviously have to pay for the screen I broke. LISTEN TO BRIAN! BE CAREFUL! THE SCREEN _WANTS_ YOU TO BREAK IT! DON’T FALL FOR IT!
    cybrosis catharsis -
    Does anyone know where I could get the power button flex cable replacement? I was too extremely careful but the screen has a very precise fit. I is fine when you push the screen into the case but !&&* of a work to pull it out.
    [deleted] - Replica
  9. iPod Nano 4th Generation Display Replacement: passo 9, immagine 1 di 1
    • Peel back the Kapton tape covering the display data cable socket.
  10. iPod Nano 4th Generation Display Replacement: passo 10, immagine 1 di 1
    • While holding the light colored socket down with one finger, use the tip of a spudger to flip the ZIF cable lock up toward the bottom of the Nano.
    Continue to carefully hold the socket down while doing the next step. If the cable come off at the wrong angle it can pull the connector away from the board at the base of the screen.
  11. iPod Nano 4th Generation Display Replacement: passo 11, immagine 1 di 1
    • Use an iPod opening tool to peel the display data cable off the thin metal plate attached to the display.
    • Be careful not to rip the display data cable.
    Some of the ribbon is inside the white housing with the lock on, it needs to slide out of the housing. I didn't notice this because everything is so small - be sure not to slide your pry tool right through it.
    Martin Mccaffrey - Replica
    The display can actually be pulled out slightly further than it initially seems. When you gently pull it up, you'll experience some resistance, which I initially thought indicated it was as far as it could go. But an extra bit of (still very gentle) force can pull it up a few more millimetres, which means the opening tool can fit.
    Also, it seemed to me to actually be helpful to lever the cable out of its port before removing the ribbon from the adhesive on the plate, since this allowed better access to the adhesive with the opening tool.
    aaaidan - Replica
    As commenter Brian Campbell wrote on the previous step, it is important to hold down the white cable socket while carefully working the cable loose from the adhesive. Even a small amount of upward force on the display data cable while it is still inside the socket could be enough to tear the socket off the board. Try not to pry up - use a thin, new (undamaged) opening tool to get under the ribbon cable and keep it parallel and as close to the metal plate as possible. It needs to be worked *under* the data cable, not to pry, as the cable just slides straight out the bottom of the white socket.
  12. iPod Nano 4th Generation Display Replacement: passo 12, immagine 1 di 1
    • Pull the display out of the Nano, minding the hold switch cable that may get caught.
    • As you pull the display out of the case, be careful not to break the hold switch cable.
    WATCH THE HOLD SWITCH!! Be *sure* it is disconnected before pulling out the screen! (I've made that mistake too many times :P)
    disconnected from what?
    I never saw where it was connected to!
    Fred Rodolf -
    By "caught" do you mean glued to the case? Mine was, and I cant tell how I could possibly have removed the screen without it breaking. Luckily my Ipod was already broken, but now its even more broke because of this guide.
    swd311000 - Replica
    Oops!!!…..I managed to break the little ribbon cable going to the hold switch…lots of very “colourful“ words aimed at myself are in my head now.
    Simon Kormendy - Replica
  13. iPod Nano 4th Generation Display Replacement, Display: passo 13, immagine 1 di 1
    • If present, remove the strip of tape covering the display electronics.
  14. iPod Nano 4th Generation Display Replacement: passo 14, immagine 1 di 2 iPod Nano 4th Generation Display Replacement: passo 14, immagine 2 di 2
    • The display bracket is attached to the display by a strip of adhesive around its perimeter.
    • Use the edge of an iPod opening tool to carefully pry the display bracket off the rear of the display.
    • Continue separating the display bracket along the side of the display.
  15. iPod Nano 4th Generation Display Replacement: passo 15, immagine 1 di 1
    • Separate the display bracket from the other side of the display.
  16. iPod Nano 4th Generation Display Replacement: passo 16, immagine 1 di 1
    • Use an iPod opening tool to carefully peel the display electronics off the display bracket.
  17. iPod Nano 4th Generation Display Replacement: passo 17, immagine 1 di 1
    • Remove the display from the display bracket.
Conclusione
Altre 49 persone hanno completato questa guida.
5 Commenti
And what to do if you break the hold switch?!
Fred Rodolf - Replica
I believe you might have to buy a new one online.
Ad123re -
Hello, can I connect a 10" LCD display to the iPod display connection instead of it's original display?
irrevocablemihiranga97 - Replica
No. No idea what you're talking about because even if it was connected it wouldn't physically fit. TV out would be your best friend.
the bongo guy -
Your instructions are well prepared and very helpful! Thanks a lot!
ndinijimi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 13
Ultimi 7 Giorni: 48
Ultimi 30 Giorni: 171
Tutti i Tempi: 78,651
