Salta al contenuto principale
iPod Nano 2nd Generation Top Bezel Replacement
Cosa ti serve
  1. iPod Nano 2nd Generation Top Bezel Replacement, Top Bezel: passo 1, immagine 1 di 1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. iPod Nano 2nd Generation Top Bezel Replacement: passo 2, immagine 1 di 1
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic top.
    • Lift the top bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
Conclusione
Altre 12 persone hanno completato questa guida.
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
2 Commenti
But how do I install it on? Do I just push it back? I want to fix mine but it doesn't even have the top part anymore, or the hold switch
luis - Replica
I would recommend that you put some new adhesive on there. All you have to do is put the switch in its place and put on a new top and push it down.
Ad123re -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 27
Tutti i Tempi: 18,895
