Salta al contenuto principale
iPod Mini Logic Board Replacement
Cosa ti serve
  1. iPod Mini Logic Board Replacement, Top Bezel: passo 1, immagine 1 di 1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. iPod Mini Logic Board Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Jimmy
    $7.95
    Compra
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic top. Use the screwdriver to pry up the white plastic top bezel. Be careful not to damage the soft plastic with your screwdriver.
    • The top bezel is held on with an adhesive, so it may be necessary to pry up in several different locations to free the part.
    • To make this job easier, heat up the adhesive with a hairdryer on low heat for a few seconds.
    You can also gently use a metal spudger to lift up both the top and bottom bezels. Allow only 1/8" of the metal spudger (like the screwdriver in the picture) to get inside to get leverage, before fully lifting the bezel up. Please note where the little "teeth" are underneath the bezels, or you can damage those if you are not careful.
    Also, using too big of a flathead screwdriver can cause damage to the plastic and chips away plastic from where you were trying to pry up the bezels, ruining the look of the iPod.
    Ryan - Replica
    There should be a button here for "I did it -- EPIC FAILURE!!" When I put my iPod back together, the components on the mainboard were scraping against the clickwheel, and maybe the battery wasn't in perfect alignment, but the result was that there was a lethal amount of friction when sliding the assembly back into the case. As I was trying to relieve the pressure by tilting the board down using a spudger from the bottom, the top of the display bezel ended up scraping against the casing in such a way that it cracked from the center of the right edge. OUCH!! There goes a $50 repair job and a $40 replacement cost! Bye Bye perfectly working iPod Mini )-;
    There are two safeguards that can be done when reassembling this iPod. First, use a stiff piece of plastic film as a shim and lubricant between the top of the logic board and the top inside of the case, such as anti-static packaging, or the clear bag packaging of Apple display dongles (use an exacto knife to cut a long strip of it). Don't cover the display with the plastic, just the logic board components. Second, instead of pushing down on the assembly from the top or sides of the display which will place dangerous pressure on it, connect a cable to the dock connector and pull on it from the bottom, and pull out the plastic shield deftly and easily after the assembly is in position.
    steadfast I and I - Replica
    If it's held on by adhesive, how do I get it back on?
    Cam - Replica
    If you have longish fingernails and don't mind ruining them, I found it helpful to run my thumbnail between the plastic and the metal casing before going at it with a screwdriver. The little "teeth" a previous commenter mentioned are at approximately the 1/3 and 2/3 marks on the long edge of the plastic casings.
    rongshifen - Replica
    Instead of gouging the end caps out with the flat screwdriver, try hot gluing a piece of wood (I used a tongue depressor-like ‘craft stick’) to the end cap, then just lever the cap out without damaging the aluminum. Removing the stick and the glue from the end caps takes a little patience but can be done without leaving a mark.
    Human - Replica
    Don’t use any kind of metal tool to get these plastic caps off. Metal on metal will scratch up the body. I use a thin guitar pick, work it in between the cap and case, then turn it horizontal and slide around enough until you can use your fingernail to pull the cap the rest of the way off. Don’t be aggressive and break off the little fingers on the bottom side of the cap.
    Ken Mastri - Replica
    Use plastic picks or the back of an iSesamo tool to get in.
    TheYootz Media Group - Replica
    For a newbie, consider removing the bottom bezel first. In case of scratches due to lack of practice and expertise, the bottom bezel usually isn't as visible during usage.
    Using your fingernail, determine which edge would be best for starting. Feel for an edge where the aluminum case is a tiny bit higher then the plastic when pressing down gently on the bezel.
    Only use plastic tools. The plastic picks from Ifixit are good. A plastic spudger may work but it needs a very sharp edge.
    As you work the pick in between the bezel and the aluminum case, note that you can push the pick in more toward the middle of the bezel and much less (1/8") elsewhere. Avoid deep probes at the 1/3 and 2/3 points where plastic clips reside.
    For those who are looking at the suggested timeline and wondering how it is possible, this step alone took me 45 minutes. So, take your time as you see fit.
    YeeWee - Replica
    As an alternative to using hot glue: I cut a command strip to the width of the white bezel, then stuck it onto the bezel, then stuck a plastic card on the other side. Then it is easy to pull out the bezels. It is also easy to remove the command strips without damaging the bezel.
    Ian - Replica
    I found the bezel parts to be easiest to remove using a scalpel (to pry up) and the blue guitar pick looking things.
    Jonathan Cousins - Replica
  3. iPod Mini Logic Board Replacement: passo 3, immagine 1 di 1
    • Lift the top bezel off of the iPod.
    A thinner blade, such as a small pocket knife blade worked for me.
    dean dillon - Replica
  4. iPod Mini Logic Board Replacement, Bottom Bezel: passo 4, immagine 1 di 1
    Jimmy
    $7.95
    Compra
    • Carefully insert a small flathead screwdriver or Jimmy in the seam between the metal casing and white plastic bottom Use the screwdriver to pry up the white plastic bottom bezel. Be careful not to damage the soft plastic with your screwdriver.
    Again, be mindful and careful of the little white teeth on the underside of the plastic especially the two on the ends of the long sides.
    DITOSP - Replica
    I used Stanley knife blade to gently prise both top and bottom plastic covers
    jimbo20039 - Replica
    Like I do for the top, I use a thin plastic guitar pick to wedge between the plastic cap and metal case. Once it’s in, turn the pick horizontal (same as the cap) and work it around until you can get your fingernails under it. Also, I believe this cap is made to go on only one way, so maybe mark which edge is front or back
  5. iPod Mini Logic Board Replacement: passo 5, immagine 1 di 1
    • A small pair of snap ring pliers is the easiest tool to remove the metal retaining bracket.
    • You can also use a flathead screwdriver to pry out the metal retaining bracket beneath the bottom bezel as shown. You can free the bracket by first pushing in the metal arms on the corners and then lifting the bracket.
    Be *very* careful on the left hand side. It's almost too easy to scrape the click wheel cable and cause damage to it!
    LambdaCalculus - Replica
    I used a circlip tool and for removal and reinsertion. It was fast and easy and avoids bending the part. They are also referred to as snap ring pliers.
    thezazupits - Replica
    Citazione da thezazupits:
    There are two kinds of snap ring pliers available. One pivots like regular pliers, one hinges in reverse (when you squeeze the handles, the tips spread). Use the first type.
    PZencak - Replica
    My click wheel lost some of its functionality. The back button, and the touch sensitivity to scroll through songs isn't working. :(
    coombsnahuel - Replica
    Hi,
    I have followed this very good tutorial as carefully as I could and I thank you very much for having posted it!
    However, my problem is not solved. After having connect-disconnect issues when used with car charger, the iPod started making faint noise when plugged and refused to charge or start-up. I thought it was a mechanical noise (hard drive?) but obviously it is not the case because battery and hard drive are now unplugged, and the board-screen assembly still makes the same noise when plugged in a USB socket (but of course I can't localize the origin of that noise).
    Do you have any idea what it might be due to?
    Thank you in advance for any advice,
    Maxime
    Maxime Gommeaux - Replica
    I would definitely recommend either circlip pliers to take out the metal retaining bracket because using a screwdriver leaves obvious marks on he corners of the case. I have noticed many for sale on eBay that have these marks. There are now plastic 'lifters' available to remove the top and bottom bezels and these are brilliant if used carefully and go in easily on the click wheel / screen side but be aware that when removing the bottom bezel it may bend the case a bit but it is easily persuaded back into shape. I too have carried out 64 GB, 128 GB and 256 GB conversions to the mini with a compact flash to SD card adapter and before fitting I format the card in my Sony Alpha 350 camera and it works a treat. My daughter loves her 128 gb converted mini and it's almost bombproof with a solid state memory on board.
    ptrmayhew6 - Replica
    Rather than pry the ends of the clip out, insert the flat screwdriver as shown ( maybe a little more straight up) and slide it toward the open end, lifting as you go, and the corner of the clip will pop right out.
    Human - Replica
    This is possibly the hardest part of this job for me. Getting this metal spring clip out without damaging the ribbon cable that’s right under one side is tricky. Take your time and use care to avoid touching the cable.
    In my ‘repair’, I managed to do the above on the side away from the clickwheel connector. I pried it up, and gently wiggled it free from the space. That way you don’t need to go prying at the connector, at cost of causing some scrape marks on the inside of the casing. Rather have internal scrapes than needing to replace the clickwheel!
    Casey - Replica
  6. iPod Mini Logic Board Replacement: passo 6, immagine 1 di 1
    • Lift the metal retaining bracket out of the iPod.
  7. iPod Mini Logic Board Replacement, Display: passo 7, immagine 1 di 1
    • Be careful, this connector is fragile.
    • Use a spudger or the tip of your finger to carefully disconect the orange click wheel ribbon from the logic board.
  8. iPod Mini Logic Board Replacement: passo 8, immagine 1 di 1
    • Remove the two #00 Phillips screws securing the headphone jack to the casing.
  9. iPod Mini Logic Board Replacement: passo 9, immagine 1 di 1
    • Carefully slide the iPod out of its casing by pushing on the logic board near the bottom edge of the click wheel.
    • Do not pull on the headphone jack board at the top of the iPod, as the connector to the logic board is fragile.
  10. iPod Mini Logic Board Replacement: passo 10, immagine 1 di 1
    • After pushing the logic board out sufficiently, gently grasp the logic board on either side of the display, and continue to slide the iPod out of its casing.
  11. iPod Mini Logic Board Replacement: passo 11, immagine 1 di 1
    • Lift the battery off of the logic board and lay it to the side of the iPod.
  12. iPod Mini Logic Board Replacement: passo 12, immagine 1 di 1
    • Use a spudger to flip up the black plastic tab holding the orange display ribbon in place. The black tab will rotate up 90 degrees, releasing the ribbon cable.
    • This tab is fragile so be careful not to break it.
  13. iPod Mini Logic Board Replacement: passo 13, immagine 1 di 1
    • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
  14. iPod Mini Logic Board Replacement: passo 14, immagine 1 di 1
    • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
  15. iPod Mini Logic Board Replacement: passo 15, immagine 1 di 1
    • Turn the iPod over.
    • Carefully lift the display up and slide it out of its connector.
  16. iPod Mini Logic Board Replacement, Logic Board: passo 16, immagine 1 di 1
    • Use a spudger to carefully pry up the headphone jack board from the logic board. Be careful to pry up near the connector to prevent unnecessary strain on the board.
  17. iPod Mini Logic Board Replacement: passo 17, immagine 1 di 1
    • Carefully disconnect the battery from the logic board. Make sure to pull only on the connector and not on the battery wires.
  18. iPod Mini Logic Board Replacement: passo 18, immagine 1 di 1
    • Use a spudger or the tip of your finger to carefully disconect the orange hard drive ribbon from the logic board.
    • Lift the hard drive out of the iPod.
  19. iPod Mini Logic Board Replacement: passo 19, immagine 1 di 1
    • Logic board remains.
Conclusione
Altre 19 persone hanno completato questa guida.
iRobot
Membro da: 09/24/09
1 Reputazione
636 Guide realizzate
Un commento
Can You give me a step by step process for reassembling an iPod mini after replacing the logic board. I cannot follow the steps in reverse to reassemble it. Also, is there a youtube video showing the reassambly?
ahmartensson49 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 93
Tutti i Tempi: 24,898
