Introduzione
No audio? Replace the headphone jack!
Unable to unlock? Replace the lock switch, which is an integral part of the headphone jack sub assembly.
Apple designed their new iPods to be very difficult to take apart without destroying major components. Because of the metal faceplate, the metal backing, and the 13 (yes, 13) metal clips holding the case together, this is one of the toughest iPods to disassemble.
  • Apple designed their new iPods to be very difficult to take apart without destroying major components. Because of the metal faceplate, the metal backing, and the 13 (yes, 13) metal clips holding the case together, this is one of the toughest iPods to disassemble.
  • Proceed with caution and the warning that you may significantly damage your iPod beyond its present condition. Also, you may want a few extra pairs of plastic opening tools during installation, as they are easy to ruin when opening the iPod. Have fun!
  • Before opening your iPod, ensure that the hold switch is in the locked position.
Actually, there are only 11 metal clips. From the face side:
On the top, only 1 clip centred 35mm from LHS. Avoid the first 30mm on the LHS, and the last 20mm on the RHS
On the RHS there are 4 tabs centred at 20mm, 40mm, 65mm and 85mm from the top. Take great care to avoid the topmost 15mm
On the LHS there are 4 tabs centred at 20mm, 40mm, 65mm and 85mm from the top
On the bottom, there are 2 tabs, each one 10mm in from the edge.
Also, I bought 2 spudger bars with the battery, and found them invaluable. The plastic ones supplied are nearly useless
astutebs - Replica
Opening this iPod is challenging. Don't get discouraged if it takes you a few tries before the iPod is opened. One thing to notice is the angle of the plastic opening tool's tip while inserting it into the iPod. Ideally, the angle should be as vertical as possible while still clearing the edge of the rear panel.
  • Opening this iPod is challenging. Don't get discouraged if it takes you a few tries before the iPod is opened. One thing to notice is the angle of the plastic opening tool's tip while inserting it into the iPod. Ideally, the angle should be as vertical as possible while still clearing the edge of the rear panel.
  • Insert a plastic opening tool into the seam between the front and back of the iPod.
I think this must be a 5th gen ipod class and the gap is larger. I have a 6th gen ipod classic, the plastic open tool can't insert in!
The battery(thick) I bought from ifixit has problem: the cable is not same length as the original one. Be carefully.
linhaiyxs - Replica
AWESOME!!!! Couldn't b happier,1 hour and 10 mins to switch out headphone jack (had music through one speaker) and battery since I had it open. Really only had to use plastic spudger,metal spudger and 1.5 inch puddy knife. Plastic separators didn't really help,for 3 bucks I'm not complaining. Already had a 00 screwdriver. All told,$43.00 for parts and I have my 120 gig iPod back.
David Fizur - Replica
Before starting to pry open the case, look closely at the pictures in steps 21 and 23 to better understand the clips to be released and the location of the clips. It will make the probing with the spudger more effective.
Jim Athay - Replica
Don’t waste time here…just use the metal spudger.
Hwyman - Replica
  • Insert another plastic opening tool into the seam between the front and back of the iPod, leaving at least 1.5 inches of space between the two tools.
Stick yer dick in. Yer gonna f it up folks
doug - Replica
  • At an angle, carefully insert a putty knife about 1/8 inch into the seam between the two opening tools.
  • There are thin metal rails running along the inside of the rear panel, so take great care when inserting the putty knife.
  • Once the putty knife has cleared the lip of the rear panel, pivot the putty knife so that it is vertical, and carefully (but firmly) wiggle it straight down into the gap between the opening tools.
The plastic tools are fine for holding the tabs open or for prying open partially open sides, but you're much better off using the metal spudger to open em
parthmukeshbhatt - Replica
I couldn't agree more about the plastic opening tools! The metal spudger worked loads better when it came to actually opening the device. Yes, the metal tool's tip was much sharper than the plastic (and hence, easier to cut your fingers on if your grip slips) but it was substantially more effective in the end. :)
Kimberly Valdovinos -
At my local hardware store they offer stiff and flexible putty knives - which kind is better for this purpose?
anonymous 4032 - Replica
Don’t do this! The putty knife is too wide and will damage the inside of the case. You can see in the photo for step 19 how the metal clip rail has been bent out of shape. You need to use a narrower tool the will fit between the protrusions on the clip rail (which is where the clips actually are). This video shows a better, albeit more dangerous, method using an x-acto knife. I used the method shown in the video but with a #18 chisel blade on the x-acto knife. With the iPod on its back, I inserted the blade with the beveled side down. Then I pried the side out slightly and peeked through the crack with a flashlight to make sure that the blade was positioned between the protrusions, readjusting as necessary. I used multiple knives to prevent released clips from reengaging. Use this technique at your own risk, and wear adequate hand and eye protection as the blades are very sharp and somewhat brittle.
Robert Watkins - Replica
I used the iFixit Jimmy instead of a putty knife. I also watched the x-acto knife video that Robert Watkins linked to in order to find where the clips are located. I slid the Jimmy into those locations until the tool bottomed out and then move on. I only used the metal spudger (to initially open a gap), the Jimmy (to open the clips), and occasionally a plastic spudger (to hold open gaps while I relocated the metal tools to a new section). Pro tip: Use the Jimmy as a letter opener after you fix your iPod.
Hwyman - Replica
  • Push with your fingers on the rear panel behind the putty knife to minimize bending. Slowly flex the putty knife, as shown in the picture, to ensure that most of the metal tabs on this side of the iPod are disengaged.
  • The theory behind this method is, rather than attempting to not bend the rear panel at all, to bend it in a favorable manner that allows you to easily restore it later. Therefore, any bend in the sides of the rear panel should be drawing the lip of the rear panel away from the iPod, rather than pushing out on the curved surface. This method also disengages as many of the side clips as possible.
I disagree with the “theory” here. You don’t have to bend the case at all. Watch the x-acto blade video on youtube (it’s linked above in the Step 4 comments). The idea is to slide whatever wide flat tool (putty knife, x-acto blade, iFixit Jimmy, etc…) in between the clip and the body. Setting the iPod flat on the table instead of holding it will help and you won’t cut yourself if a tool slips out. As you disengage clips, you will find that the body will start coming out on it’s own without having to flex your wide tool and bending the case in the process.
Hwyman - Replica
  • Remove the putty knife from the iPod and reinsert it closer to the corner of the iPod, using the same wiggle method as before.
  • If at all possible, do not bend the corner of the rear panel.
Aggiungi Commento
  • Between the lock slider and headphone jack, insert a plastic opening tool into the seam between the front and back of the iPod.
  • You may find it easier to carefully flex the putty knife downward in order to create more of a gap for the opening tool, but be sure not to bend the corner of the rear panel!
The clip holding this part of the iPod together is different from the others around the iPod and you might want to keep the spudger in place until you've opened the iPod completely.
Karsten - Replica
  • Near the center of the display, carefully insert a metal spudger into the gap created by the plastic opening tool.
  • It is easy to create a noticeable bump in the rear panel here that is difficult to repair. When prying the tab free, try to have the metal spudger pivot on the edge of the rear panel rather than bending the rear panel outward.
  • Using the metal spudger, disengage the single clip on the top of the iPod.
This was the most difficult step in opening for me. Place the device on a hard surface and press with increasing force until you feel the clip push down and out of the way.
joe - Replica
  • Near the other top corner, insert an opening tool into the seam between the front and back of the iPod
Aggiungi Commento
  • On the other side, insert an opening tool into the seam between the front and back of the iPod.
  • You may find it easier to angle the opening tool stuck in the top corner in order to create a sufficient gap.
Aggiungi Commento
  • Remove the plastic opening tool from the top corner and insert it into the seam between the front and back of the iPod, leaving at least 1.5 inches of space between the two tools (as done on the other side).
Aggiungi Commento
  • Again, there are thin metal rails running along the inside of the rear panel, so take great care when inserting the putty knife.
  • Once the putty knife has cleared the lip of the rear panel, angle the putty knife so that it is vertical, and carefully (but firmly) wiggle it straight down into the iPod via the gap between the plastic opening tools.
  • Push with your fingers on the rear panel behind the putty knife to minimize bending. Ever so slightly flex the putty knife to ensure that most of the metal tabs on this side of the iPod are disengaged.
Aggiungi Commento
  • The metal clips near the corners are notorious for tenaciously gripping the front panel. It is necessary to disengage these clips in order to open the iPod.
  • Carefully insert a metal spudger into the area near the stubborn metal clip.
Aggiungi Commento
  • Gently wiggle the metal spudger down so that it is all the way in the rear panel.
Aggiungi Commento
  • Gently begin to disengage the clip from the front panel.
Aggiungi Commento
  • Continue to push up on the front panel with the metal spudger until the metal clip releases.
Συνεχίστε να πιέζετε προς τα επάνω το μπροστινό πάνελ με το spudger μέταλλο έως ότου ελευθερωθεί το μεταλλικό κλιπ.
ermiskaspis - Replica
I couldn't have said it better.
mike - Replica
  • There are two ribbon cables connecting the rear panel to the rest of the iPod. In the following step, be careful not to damage these ribbon cables.
  • Grasp the front panel assembly with one hand and the rear panel with the other.
  • Take a deep breath!
  • Gently (GENTLY) disengage the remaining clips on the rear panel by pulling the tops of the front and rear panels away from each other (think of the bottom of the iPod as a hinge), taking great care not to damage the ribbon cables holding the two halves together.
Aggiungi Commento
  • Use a spudger to lift the retaining flap holding the connector cable.
    • The retaining flap only needs to lift up 2 mm. This is a sensitive connector and too much force can remove it from the logic board.
  • Slide the orange battery ribbon out of its connector.
Be careful here. I screwed up and ruined the iPod's motherboard when trying to reconnect the battery cable.
greekman07 - Replica
very easy tear off battery connection from the logic board,very careful when open that plastic lock.
andraskiss - Replica
Be EXTREMELY careful not to lift too far up and remove the whole piece from the motherboard. You'll never get the pins to line up correctly again without breaking the solder joints and ruining the motherboard if you do. iFixit failed.
bcook -
totally screwed up, pulled out the whole
agnesmadness - Replica
the connector came out with the battery cable ,almost lost it. I did get it back in though.
elsprato13 - Replica
Yeah, this battery connector is extremely fragile if you pry too hard you will lift the whole connector plastic off the board. A really, really bad design from Apple having that type of connector like that. The white plastic part is not secure at all to the logic board so when you pry the tab up, you may lift the whole thing up.
rgarjr - Replica
Had no problem disconnecting the cable, I used a nylon spudger to press the connector down while using a plastic pry tool to pull the cable up, be patient, it might take time.
Tip for reassemble: Use a tweezer to reinsert the cable, again, it might take time.
Luis Soto - Replica
ifixit fail. Be VERY careful pulling up that lever or the whole connector will pop right the !&&* out and you will never, never, NEVER get that sucker back in. Time to buy a new one, %#*!^@.
Jeff White - Replica
Just poke this latch up from behind. It's a little scary, but it literally just popped straight up for me.
Gordon Krupsky - Replica
You MUST put the warning in the instructions not to pull out the connector. Everything worked perfectly, seriously perfectly, until I went to put the battery cable back in and realized I had popped the connector out and it pulled all of the metal prongs out. Without a way to reconnect metal to metal, this basically just killed my ipod. It's trash now. Such a disappointment. Will not be recommending this site until you fix this one instruction.
djbagwell - Replica
Took me a long time to figure it out. The retainer literally pulls up ... straight up, not hinged. The retainer is the (at leeast on mine) grey thingy with a rounded top. I finally got the courage to gently pry it up (2 mm = 1 smidgen) and tthe connector pulled/fell out. Gods know if I'll ever get it back.
Larry Osborne - Replica
I pulled the connector off the motherboard, trying my best to be gentle. The instructions need to be more specific about what to pull and in what direction. The spudger wouldn't grip onto anything and I tried to rock the retainer out, not sure which way it needed to go before releasing. Then, voila, the whole thing came off. That's the end of life for my iPod classic, which I've had since 2008.
David Harbin - Replica
1 use a fine tool to lift the brown tab of the latch vertically up
2 use tweezers to grip the ribbon along its horizontal run then lift out. Don’t grip the last section that bends into the motherboard connector or you might short circuit the battery conductors, which are not insulated for the last 12mm or so
3 make sure the latch is fully up when you want to connect the ribbon of the new battery, as it falls down very easily and stops the new battery ribbon entering the connector
anonymous 2502 - Replica
I released the battery first (with the spudger), which enable the whole case to be butterflied. Then, using a splinter probe with a slight hook lifted the retaining clip, and removed the existing battery lead. Then using a very fine tweezers inserted the new battery cable, and pushed the retaining clip back into place, while holding the cable with the tweezers. All good.
astutebs - Replica
  • Place the rear panel next to the iPod, being careful not to strain the orange headphone jack cable.
Be careful not to damage the hold switch ribbon there...
Karsten - Replica
  • Lift the hard drive up with one hand so you can access the headphone jack ribbon beneath.
  • Use a spudger to flip up the plastic tab holding the headphone jack ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
  • Slide the orange headphone jack ribbon out of its connector.
  • The rear panel is now free from the iPod.
I don't know if this step is totally necessary. If its not feel free to skip it just be careful to avoid tearing the ribbon.
kevman12 - Replica
I recommend not doing this. I couldn't figure out how to reattach and broke the jack in process. There is no need to do this step, just be careful not to strain this connector.
JOSHUAEGILLESPI - Replica
This is probably the most difficult part because the jack is so tiny and it's not obvious that it contains a "flip up" retainer. A very difficult step.
robertdraznik - Replica
How do I get that little 90° clip to stay back down with the new ribbon in it
Nar -
How do I get the little clip to stay down holds the year Jack ribbon to the motherboard
Nar -
I just pulled. The thing flipped up automaticly 90° degrees.
tellmiger - Replica
This step (and next few “repair” steps) is not worth doing unless you mangle the case when you pry it open. If it doesn’t look all bent up, leave this ribbon attached and skip ahead.
Hwyman - Replica
  • Now to repair the damage caused by liberating the internal parts of the iPod Classic! It is highly likely that at least one of the metal clips in the lower case has been bent upward. These clips must all be pointing downward in order to reinstall the rear panel.
Right, I thought the way that this was phrased is a tad confusing. Basically, once you've separated the front and back panel, insure all the prong-like-clips around the sides of the back panel are all down - not sticking up after opening the ipod. I skipped the step because it was confusingly put. I ended up successfully swapping the battery, however when I went to put the ipod panels back together, they wouldn't clip back properly. This made it very fiddly. Anyway, hope that helps.
Joe Parkes - Replica
  • Take the broad, flat side of the metal spudger and push the clip down, taking care not to tear the thin metal rail from the rear panel. Alternatively a pair of flat pin nosed pliers can be used to reduce risk of slipping and damaging the headphone jack.
  • Be careful not to damage any of the headphone jack parts while shaping these clips!
Aggiungi Commento
  • On a clean, hard surface, lay the rear panel on its side. Carefully but firmly push down on it, rolling the entire lip side back into its proper spot.
  • It may be necessary to do this multiple times in order to achieve optimal straightness on the sides. It is better to have the edges of the case pushed in slightly too far rather than not far enough, because the reseating of the front panel will bend the rear panel into its correct alignment.
  • Now that the rear panel is back to a beautiful condition, you can move on to repairing the iPod!
Aggiungi Commento
  • The battery is attached to the rear panel with adhesive. Be careful not to tear the orange headphone jack or hold button ribbon cables when removing the battery.
  • Use a spudger to lift the battery and the attached orange cable out of the iPod. If you have a 160 GB iPod, the battery will be thicker than the one pictured.
Just wanted to say THANK YOU to whoever made this tutorial!! Kinda unclear in some areas, but I got it! Thanks so much!!!
shaunlovesyou - Replica
I just want to say that with out this tutorial I could never have taken my iPod apart the biggest help was the addition of the putty knife. It took about 30min cause I took it slow. My iPod is charging and seems to be working thank you
PMM - Replica
dont do this, as u see, any one can edit it, it's like wikipedia, not reliable.
sophia - Replica
I do this and my ipod works now!
loquetraoul -
Thanks for this. It worked for me without any hitches. Your presentation, products and packaging are all first rate.
tripplc - Replica
All very easy to do. Ive just "frankensteined" a 100Gb classic and working all fine. Very simple and clear instructions.
Been using iFixit for almost 10 years in my data recovery company and always been informative in getting Macs opened easily and with great results
michael earl - Replica
Within the first minute, I pushed a plastic opener through the flesh of my opposite index finger. Within the second minute I peeled back about 3/16" of my index finger nail. Within the third minute I broke the tips off of first one and then the other of the supplied plastic openers. On the fourth minute, I threw the entire kit -- brand new replacement battery included -- in the trash. Thanks for absolutely nothing!! Ken Queale
K Queale - Replica
Sounds like you're just clumsy...
bjoernskytte -
Absolute waste of money. I have been working on it for an hour and half. Blue tools wore out the first 1/2hour
Dave Sherman - Replica
My hold button ribbon was in the battery glue and tore when I pried the battery loose. I 'm going to try to replace that part with luck that will be all I have to do.
There are several hard tasks in this process and this step was hard for me. Took me a while to detach the battery without damaging the cables. But with some patience I succeeded.
Great guide, by the way.
Luis Soto - Replica
I have been trying unsuccessfully to get into my ipod to replace the duff battery for a long while. Now, armed with your instructions and the right tools I have done it! (not without considerable frustration with those pesky clips I might add). The plastic spudgers are useless by the way. It took a while to work out how to release the battery ribbon cable and larger picture of the clip action would help. I too found the battery glued to the ribbon cable beneath it. Perseverance, patience and a steady handed are a must for this one. Well done and thank you!
Colin Kaye - Replica
  • Use one hand to hold the orange ribbon cables in place, and peel up the black tape securing the cables to the rear panel with your other hand.
I saw some YouTube videos where they were able to reuse the black tape on the new backplate, so I took some time to carefully remove it, without success. However, since I was replacing my iPod 7th Gen with a 240GB disk (thicker than the original), the new thicker back plate did not need the tape since the cables are separated form the case.
Luis Soto - Replica
  • Remove the two black Phillips screws securing the headphone jack to the rear panel.
  • These are SMALL! Be sure you have a size 00 screwdriver on hand
One tip when reassembling. These screws are very tiny and difficult to handle even with magnetized drivers, so I used the PH000 tip of the iFixIt kit to pick the screws and screw the first turns. Then switch to a PH00 to tighten them. Actually, using a PH00 of a cheaper set I bought to open the iPod, worked better since the length of the screwdriver was shorter than the case.
Luis Soto - Replica
You can also use a Phillips 000 for these. I also accidentally picked up the wrong screwdriver and got one out with a Phillips 0, but I think there's a definite risk of stripping your screws if you're not careful with this one.
When re-assembling, if you dip the tip of the screwdriver a couple of mm into a pot of vaseline, then place the screw onto the tip, it will hold the screw nicely in place until you tighten the screw (ie it will stick to the tip without dropping off)
  • Remove the following two screws:
    • One black Phillips screw securing the hold switch near the corner of the iPod.
    • One silver Phillips screw securing the other side of the hold switch.
Aggiungi Commento
  • Lift the hold switch free from its housing on the rear panel. Don't remove the hold switch completely at this time, because it is connected to the same cable as the headphone jack.
Aggiungi Commento
  • Slide the headphone jack out of its housing on the rear panel.
  • Lift the headphone jack and hold switch assembly out of the iPod.
Aggiungi Commento
  • If you're just trying to remove the rear panel, you can skip Steps 30 and 31.
  • If your replacement headphone jack includes the white plastic hold switch, simply reinstall the replacement headphone jack. When replacing the hold switch assembly note the locating pin near the hole the silver screw position, concentrate on locating that and the rest falls into place. Once it's all screwed in remember to peal the backing tape off the contact pad just along from the jack.
  • If your replacement part does not include the plastic hold switch, follow the next steps to transfer the plastic hold switch to your new headphone jack.
  • Remove the single Phillips screw nearest to the hold switch.
  • Lift the plastic portion of the Hold switch away from the orange ribbon cable.
  • Ensure that the black notch lines up with the gray slider during reassembly of the switch (see picture 2).
Aggiungi Commento
  • Use the small iPod opening tool to carefully peel the orange ribbon cable and attached black Hold switch up from the metal backing.
  • When re-attaching the replacement Hold switch, make sure the two small posts on the back of the switch are aligned with the two holes in the metal backing.
Aggiungi Commento
Conclusione
Before you snap the case shut, be sure to test the device to ensure that it's working properly.
Altre 189 persone hanno completato questa guida.
iRobot
Membro da: 24/09/2009
1 Reputazione
774 Guide realizzate
This worked a charm for me! If you take it slow and steady, and keep all the warnings in mind, you shouldn't have too much trouble :)
myungtrucci - Replica
my battery clip came out but i connected the cable to it and pushed it back on no problem
just wanted to say a big thank you to the guys/girls at ifixit for the guide my ipod classic is working better than ever!!!
patrick - Replica
where do you buy new headphone jack?
alxg000 - Replica
The headphone jack is part of an assembly, on a cable with the hold switch. We sell this assembly for thin iPod classics (80, 120, or 160 GB) here, and for the thick (160 GB) variety here.
Andrew Optimus Goldberg -
check this guy I used dollar store xacto blades you got to be careful you can easily cut yourself but this method wont damage the clips or anything,
http://www.youtube.com/watch?feature=end...
Nicolas - Replica
works out perfectly for me! 3.5 hours, a lot (A LOT) of patience and attention. Didn't break or bend anything; now my ipod is working again. I'm very happy!
just a note: everything has to be done slowly and with no distraction. Take your time and deep breaths
kia - Replica
Excellent, my ipod is now working like new, after a year without it when a faulty headphone get broke inside it.
maxevg - Replica
This is the third time I've used one of Ifixit's guides and the third time I have been successful
in fixing one of my faulty Apple products. HUGE THANKS for having this forum and offering help that would otherwise cost far much more! Power to the people and those who help each other to help themselves!
anthonyzmc - Replica
Yes this guide does work. The plastic tools are pretty useless. They break. I used a paint scraper and small flat head screw drivers. Top tip is to test the headphones before you re-close it. I did this and found that the left headphone was not working. I found the problem was the connection at step 20. The lead is pre-bent to fit snug. Once I taped it flush to the wall of the case I had both speakers working. To find out how to re-close the ipod watch this video https://www.youtube.com/watch?v=dmEVVLSR....
mike - Replica
Did it successfully!! Just be patient and you need to be to rough to break anything, because I have big hands and is a little difficult to work with those little parts. But is no that hard, the harder steps were the ones to separate the front face from the rear face.
Nasim - Replica
I was able to follow this tutorial without too many issues. The problem is that, once it was apart and "repaired," there weren't really any instructions on reassembly. "Follow these steps in reverse order" doesn't quite seem sufficient. In trying to reattach the ribbons, the orange battery ribbon came unattached, and the pictures aren't enough to make it clear where it should go. Any suggestions?
Chris Massa - Replica
Hi ! Mine was almost impossible to open but once I manage to get in everything worked very well. Thank you ifixit for transforming a 350 CHF reparation into a 40$ one you guys rocks. (only thing is that all the border of the ipod now look like he fell from a plane but he works well so ....)
arnaudlhc - Replica
apart for some issues with the connector on the headphone jack (it was bent and therefore caused distorted sound) all went fine. Lifesaver. Thanks Ifixit!
hambachw - Replica
i just replaced mine and still no audio and no hold
i did everything acording to what i watch online like this tutorial is there a bug?
franciscotanoeiro91412 - Replica
how do you know if its a thick or thin ipod? and does it matter
Stephen LaScola - Replica
You're better off with the metal spudger when taking out the battery. My plastic one broke while attempting to remove it, however it came right out once used the metal one
johnny scanlon - Replica
Very straightforward process when you follow the instructions carefully. Thanks for the step-by-step, as well as the quick shipping of the parts.
Joel Davidson - Replica
I'm just wondering how to decipher/ID my iPod for the thick and thin headphone jack/switch part options that are available to purchase. My iPod looks like the one in the image, but I'm uncertain which of those two choices (thick) or (thin) that would be. Anyone have any ideas for me? Thank you much for any help
M Liggett - Replica
Hi, you need to check the serial number in this website (http://www.everymac.com/ultimate-mac-loo...), all you need to do is copy the serial number and it will tell you which iPod Classic you have. Then, just go to ebay and type "iPod Classic (whatever gen it is) headphone jack" and you'll be good to go!
alvaricoca9686 -
Since you guys seem to rarely have any of the parts in stock, is this headphone jack and switch the right kind? https://www.amazon.com/gp/product/B00QSI...
Sara French - Replica
Thanks for a nice and clear guide! Had it done in about 45 minutes. A set of little craft knives had the case off straight away with no clips bent :)
aggrobmxer - Replica
Hi everyone ! I changed the jack connector and the hold button both with the rear panel (because i have a second broken iPod classic) and after that an error display on the screen. If someone have same problem and probably an issu to fix that i'm interesting ! Thanks a lot for this tutorial !
paulgoedertax - Replica
Well I successfully change the battery and my iPod classic but I don't think I plugged the headphone jack in properly so I will need to go back in tomorrow and figure that out. I have no volume through my headphones.
sanibelsandflee1 - Replica
I did a great job replacing my Battery. A few little marks from the putty knife i used but managed to just file down a bit. Smooth as ever. Took it apart today to attach the headphone jack ribbon because i had it upseide down on accident. I went from no sound to sound only in my left ear. Even with glasses, i have a really hard time getting the headphone ribbon in place. I need a really clear image close up that can help me. Any suggestions, guys?
The instructions were on point and I had no issues. I was able to complete this repair in about 30 minutes front to back. Thanks for giving my iPod back :)
Jim - Replica
The instructions were great. I also had no issues. I did take my ipod apart prior to getting the part. That way I had an idea of how things would go apart and together. I also ordered the ifixit kit of tools so I wouldn't be running around to find the exact tools. Also having the kit enables me to fix some other ipods and whatever. So Bravo on the instructions. It is nice to have an ipod that is not locked up..!!
Julie German - Replica
Excellent guide! Luckily my Ipod was super worn and old, so taking off the casing was easy peasy! one word of advice though : MAKE SURE YOU HAVE THE RIGHT SCREWDRIVER! I stripped one of those tiny interior screws and it was a huge hassle to pry it out.
Gage Norris - Replica
amazing instructions, thank you!! i’m so excited to have a working ipod :))))
thardee - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 30
Ultimi 7 Giorni: 247
Ultimi 30 Giorni: 1,069
Tutti i Tempi: 268,722
