Salta al contenuto principale
iPod 2nd Generation Front Panel Replacement
Cosa ti serve
  1. iPod 2nd Generation Front Panel Replacement, Rear Panel: passo 1, immagine 1 di 1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    Chiedi a FixBot
    Aggiungi Commento
  2. iPod 2nd Generation Front Panel Replacement: passo 2, immagine 1 di 1
    • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
    • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
    Chiedi a FixBot
    Aggiungi Commento
  3. iPod 2nd Generation Front Panel Replacement: passo 3, immagine 1 di 1
    • Continue to run the opening tool along the side of the case until all five tabs have been released.
    Chiedi a FixBot
    Aggiungi Commento
  4. iPod 2nd Generation Front Panel Replacement: passo 4, immagine 1 di 1
    • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
    Chiedi a FixBot
    Aggiungi Commento
  5. iPod 2nd Generation Front Panel Replacement: passo 5, immagine 1 di 1
    • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
    Chiedi a FixBot
    Aggiungi Commento
  6. iPod 2nd Generation Front Panel Replacement: passo 6, immagine 1 di 1
    • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
    Chiedi a FixBot
    Aggiungi Commento
  7. iPod 2nd Generation Front Panel Replacement, Hard Drive: passo 7, immagine 1 di 1
    • Peel up the metallic tape attached to the top of the battery.
    Chiedi a FixBot
    Aggiungi Commento
  8. iPod 2nd Generation Front Panel Replacement: passo 8, immagine 1 di 1
    • Lift the battery up from the hard drive and lay it next the the iPod (it is still connected to the logic board).
    Chiedi a FixBot
    Aggiungi Commento
  9. iPod 2nd Generation Front Panel Replacement: passo 9, immagine 1 di 1
    • Carefully disconnect the orange ribbon cable from the hard drive.
    • If the cable doesn't come free easily, it may be helpful to gently wiggle the cable from side to side.
    • Lift the hard drive out of the iPod.
    Chiedi a FixBot
    Aggiungi Commento
  10. iPod 2nd Generation Front Panel Replacement, Hard Drive Cable: passo 10, immagine 1 di 1
    • For the following step, you only need to move the locking bar about 2 mm. Pushing too hard or too far will damage the connector.
    • Loosen the connector by pulling the brown locking bar toward the hard drive cable using the tips of your fingers.
    Chiedi a FixBot
    Aggiungi Commento
  11. iPod 2nd Generation Front Panel Replacement: passo 11, immagine 1 di 1
    • Slide the hard drive cable out of its connector.
    Chiedi a FixBot
    Aggiungi Commento
  12. iPod 2nd Generation Front Panel Replacement, Touch Wheel: passo 12, immagine 1 di 1
    • Lift the blue hard drive mounting bracket out of the iPod.
    Chiedi a FixBot
    Aggiungi Commento
  13. iPod 2nd Generation Front Panel Replacement: passo 13, immagine 1 di 1
    • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
    Chiedi a FixBot
    Aggiungi Commento
  14. iPod 2nd Generation Front Panel Replacement: passo 14, immagine 1 di 1
    • Like the hard drive connector, for the following step, you only need to move the connector about 2 mm. Pushing too hard or too far will damage the connector.
    • Loosen the touch wheel connector by pulling the brown locking bar toward the side of the iPod using the tips of your fingers.
    Chiedi a FixBot
    Aggiungi Commento
  15. iPod 2nd Generation Front Panel Replacement: passo 15, immagine 1 di 1
    • Reove the 8 T6 Torx screws from the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  16. iPod 2nd Generation Front Panel Replacement: passo 16, immagine 1 di 1
    • Lift the logic board up enough to disconnect the orange touch wheel cable.
    • Lift the logic board out of the iPod.
    Chiedi a FixBot
    Aggiungi Commento
  17. iPod 2nd Generation Front Panel Replacement: passo 17, immagine 1 di 1
    • Lift the touch wheel out of the front panel
    Chiedi a FixBot
    Aggiungi Commento
  18. iPod 2nd Generation Front Panel Replacement, Front Panel: passo 18, immagine 1 di 1
    • Front panel remains.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
iRobot
Membro da: 09/24/09
1 Reputazione
636 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 49
Tutti i Tempi: 4,585
