Salta al contenuto principale
iPhone 7 Display Assembly Replacement
Solo Prerequisita
Questa guida รจ destinata a essere usata solo come prerequisito per altre guide. Da sola รจ incompleta.
Cosa ti serve
  1. iPhone 7 Display Assembly Replacement, Display Assembly: passo 1, immagine 1 di 3 iPhone 7 Display Assembly Replacement, Display Assembly: passo 1, immagine 2 di 3 iPhone 7 Display Assembly Replacement, Display Assembly: passo 1, immagine 3 di 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  2. iPhone 7 Display Assembly Replacement: passo 2, immagine 1 di 3 iPhone 7 Display Assembly Replacement: passo 2, immagine 2 di 3 iPhone 7 Display Assembly Replacement: passo 2, immagine 3 di 3
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
  3. iPhone 7 Display Assembly Replacement: passo 3, immagine 1 di 2 iPhone 7 Display Assembly Replacement: passo 3, immagine 2 di 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  4. iPhone 7 Display Assembly Replacement: passo 4, immagine 1 di 1
Conclusione
Altre 4 persone hanno completato questa guida.
Evan Noronha
Membro da: 02/05/15
223.466 Reputazione
168 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,652
