Introduzione
Using this guide, you can replace your iPhone 7 (or 7 Plus) camera cover glass with minimal disassembly—but be careful, or you can easily damage your camera.
If your iPhone 7’s rear camera does not function properly but its cover glass is not broken, see the iPhone 7 Rear Camera Replacement guide for help replacing the rear camera.
This guide is for removing the cracked glass and gluing down a “frameless” replacement part. Make sure you order the correct replacement part.
Alternatively, see the iPhone 7 Camera Lens Glass Replacement Tutorial video on YouTube.
Cosa ti serve
Panoramica Video
Use a pair of tweezers to carefully remove the remains of any broken glass from the cracked camera cover.
After replacing the broken camera cover with a new one, open the phone’s Camera app. Check and make sure that the rear-facing camera is able to focus properly.
Altre 28 persone hanno completato questa guida.
8 Commenti
The Video is showing how to replace the Glass.
Why do we need to buy this suggested part ‘ iPhone 7 Rear Camera Lens Cover’ (the whole Cover not just the Glass)?
Installing the whole cover needs a complete different Guide, including opening the iphone...
+1 agreed
this guide(link) is not at all helpful
Where is the link to buy replacement camera lens?
Hi, you can find here : https://www.amazon.com/Bonafide-Hardware...
I’m torn about this. On one hand, it’s not a complete repair in the sense that you can’t use the rear camera lens cover that is sold on iFixit but a “half-cover” that is easily purchased at different online venues, including Amazon (for which the guide provides a link).
In order to replace the actual OEM lens cover (iFixit part), you have to rip out the foam pad, camera alignment bracket, and lens cover. There is a terrible video of this on Youtube where the guy rips out the rear camera foam pads and alignment bracket while saying, “I have no idea what these do.”
In order to do this repair with the iFixit part, you need three parts (all sold on iFixit): the rear camera alignment bracket, the rear camera cover, and the rear camera foam pads. HOWEVER, since the original bracket is soldered (I think) to the cover, you would likely have to use adhesive to make the bracket stick unless you have very good soldering skills. Oh, and you have to open up the iPhone and take out the rear camera too.
Best video instructions for "Replace Camera Lens of iPhone 7, 8 and SE2 (2020)": https://www.youtube.com/watch?v=Xg3mg8iA...
la colle B7000 convient parfaitement et garde l etancheité
SAV E.LECLERC - Replica
