Questa traduzione potrebbe non riflettere gli aggiornamenti più recenti dalla guida originale. Aiuta ad aggiornare la traduzione o visualizza la guida d'origine.
Introduzione
Guida di riparazione della scheda logica dell'iPhone7.
Guarda l'immagine che mostra i principali circuiti e la loro funzione.
Per rimontare il tuo dispositivi, segui le istruzioni in ordine inverso.
Altre 54 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
50%
Gi Gio ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
12 Commenti
Could anyone tell me why, after a screen repair, and iPhone 7 front and rear cameras only display a black screen? Also, the flashlight doesn't work.
I don't know. I would like to know this as well. I have even reset all the software just in case. Did you get your answer?
After a screen replacement, baklight is gone, not working. Do you have some solution for repair this, do you have a service manual for iPhone 7 A1778 ?
Hi, check your back light filter to see if its blown, if you replaced the screen what can happen is if the battery is attached it will send a spike through the system and blow the filter, if so just replace it
Just recently replaced a part where the antenna broke away from it's soldered mounting, check your mounts.
A1778 no sound, no screen but if I call it it vibrates, does not connect to iTunes but will boot in safe mode. Any thoughts?
Power IC on my iphone 7 is printed as 338S00225 A-1 1638PHAX but I coundn’t find ICs with the same serial number online. Is it possible to use power IC for iphone 7 with a different serial number like 338S00225 A-1 1644PHAW ?
Hello, on a charged battery the iphone works and on supply power too, which component or ic must be tested?
بسیار خوب و موثر است
Reza panahiyan - Replica
Finde ich großartige Hilfe um sich zurechtzufinden.
Nur ein Teil ist für mich unklar. Der Lade IC befindet sich genau da wo auf dem Bild “Sync IC” steht. Wenigstens auf vielen Reparatur Videos war das so aber hier ist es anders. Liegt es womöglich ein Fehler vor?
Janusz Bukowski - Replica
