Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
For the official iFixit guide, follow this link. This guide has been archived for historical purposes.
This will be a helpful guide on how to try and fix your water damaged iPhone.
Panoramica Video
  1. 1. Look at the phone and try to get the water out
    • 1. Look at the phone and try to get the water out
  2. 2. Next take it apart like the sim card and let that dry out for like 24 hours.
    • 2. Next take it apart like the sim card and let that dry out for like 24 hours.
  3. 3. If it doesn't help then try the rice method by putting the phone in the rice as well as the sim card.
    • 3. If it doesn't help then try the rice method by putting the phone in the rice as well as the sim card.
  4. 4. You can also use silica gel sachets to help with the drying.
    • 4. You can also use silica gel sachets to help with the drying.
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. 5.If that doesn't help your battery is probably damaged and you can replace it or just get a whole new phone.
    • 5.If that doesn't help your battery is probably damaged and you can replace it or just get a whole new phone.
  7. Try to turn on the phone to see if it works if not then your screen is probably damaged if you don't see anything come on.
    • Try to turn on the phone to see if it works if not then your screen is probably damaged if you don't see anything come on.
  8. Start by unscrewing the screen to look and identify the whole problem.
    • Start by unscrewing the screen to look and identify the whole problem.
  9. After you look at whats wrong, start to replace the screen
    • After you look at whats wrong, start to replace the screen
  10. If you can fix the screen and get it replaced but it wont hold a charge then the battery is probably damaged and you will have to try and get a new one.
    • If you can fix the screen and get it replaced but it wont hold a charge then the battery is probably damaged and you will have to try and get a new one.
  11. Once you put a new battery put the screws back in may sure it's in correctly and try to power non your phone and it should work.
    • Once you put a new battery put the screws back in may sure it's in correctly and try to power non your phone and it should work.
Conclusione
Now once it's all done put the phone back together and it should be back in full functioning mode
Altre 2 persone hanno completato questa guida.
anonymous 591
Membro da: 25/04/2018
235 Reputazione
1 Guida realizzata
What does everyone think is it helpful?
anonymous 591 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 931
