Salta al contenuto principale
iPhone 6s Battery Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. iPhone 6s Battery Replacement, Battery Connection: passo 1, immagine 1 di 1
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm Pentalobe screws surrounding the Lightning connector.
  2. iPhone 6s Battery Replacement: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    iSclack
    $24.99
    Compra
    • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
  3. iPhone 6s Battery Replacement: passo 3, immagine 1 di 3 iPhone 6s Battery Replacement: passo 3, immagine 2 di 3 iPhone 6s Battery Replacement: passo 3, immagine 3 di 3
    • There is a notch on the underside of the display just above the headphone jack that is the safest place to begin prying the phone open.
    • Pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Once a small gap has been opened, insert the flat end of a spudger above the headphone jack.
  4. iPhone 6s Battery Replacement: passo 4, immagine 1 di 2 iPhone 6s Battery Replacement: passo 4, immagine 2 di 2
    • Twist the spudger to open the gap more and break it free from the adhesive.
    • Keep pulling up on the suction cup while twisting the spudger.
  5. iPhone 6s Battery Replacement: passo 5, immagine 1 di 2 iPhone 6s Battery Replacement: passo 5, immagine 2 di 2
    • Use the edge of a spudger to slice through the adhesive on either side of the phone.
  6. iPhone 6s Battery Replacement: passo 6, immagine 1 di 2 iPhone 6s Battery Replacement: passo 6, immagine 2 di 2
  7. iPhone 6s Battery Replacement: passo 7, immagine 1 di 3 iPhone 6s Battery Replacement: passo 7, immagine 2 di 3 iPhone 6s Battery Replacement: passo 7, immagine 3 di 3
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90 degrees, as it is still connected at the top by three cables that may break if stretched.
  8. iPhone 6s Battery Replacement: passo 8, immagine 1 di 1
    • Lean the display against something to keep it propped up while you're working on the phone.
    THESE INSTRUCTION / GUIDE IS NOT COMPLETE. I broke my phone and ended up with $250 in repairs at the local cell phone store at this step. You need to detach the display completely instead of prop it up against a box. It is very likely your cables will tear at this step if you don’t completely detach the display
    Christopher Kuhar - Replica
  9. iPhone 6s Battery Replacement: passo 9, immagine 1 di 1
    • Remove the following screws from the battery connector bracket:
    • One 3.0 mm Phillips #00 screw
    • One 2.3 mm Phillips #00 screw
  10. iPhone 6s Battery Replacement: passo 10, immagine 1 di 1
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 6s Battery Replacement: passo 11, immagine 1 di 3 iPhone 6s Battery Replacement: passo 11, immagine 2 di 3 iPhone 6s Battery Replacement: passo 11, immagine 3 di 3
    • Use the flat end of a spudger to disconnect the battery connector from the logic board.
    • Push the connector to the side to ensure it doesn't accidentally make contact and power on the phone while you're working on it.
  12. iPhone 6s Battery Replacement, Battery: passo 12, immagine 1 di 3 iPhone 6s Battery Replacement, Battery: passo 12, immagine 2 di 3 iPhone 6s Battery Replacement, Battery: passo 12, immagine 3 di 3
    • Use tweezers to peel up the edges of the two adhesive strips at the bottom of the battery.
  13. iPhone 6s Battery Replacement: passo 13, immagine 1 di 1
    • Grab the ends of the two adhesive strips and hold them together. Try to keep the strips flat and wide.
  14. iPhone 6s Battery Replacement: passo 14, immagine 1 di 3 iPhone 6s Battery Replacement: passo 14, immagine 2 di 3 iPhone 6s Battery Replacement: passo 14, immagine 3 di 3
    • Slowly and gently pull the two strips up and away from the phone.
    • The strips will stretch to many times the length of the battery—keep pulling until they come out from between the battery and the rear case.
  15. iPhone 6s Battery Replacement: passo 15, immagine 1 di 1
    • Remove the battery from the rear case.
    • When installing the battery, refer to this guide to replace your battery's adhesive strips.
    when I remove battery can I again uset
    Mohammed Alhussain - Replica
Conclusione
Altre 75 persone hanno completato questa guida.
Sam Goldheart
Membro da: 10/18/12
465.741 Reputazione
538 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.767 Guide realizzate
11 Commenti
Quickkkkkkkkkkk Question. How do I go about replacing that adhesive you had me slice?
Doc Brown - Replica
I need to buy the 6s replacement battery itself as well as the tools. Do you sell that as well as the display?
2ndwindranch - Replica
i remember i get my battery repair kit and adhesive for less than 25$ from this seller on amazon https://www.amazon.com/dp/B01LKN9AUG
exdany9 -
Please do a video. Lets see how fast you guys can change the 6s battery.
klactwiggy - Replica
nice very repair mizan.....
mohsen m - Replica
Phone fell in water
matouq - Replica
Do the 6 and 6 s have the same battery???
Cashmand - Replica
If your phone is under the 'necessary recall] battery replacement be aware that Apple will give you quite a run around requiring at least two perhaps three trips to the apple store to effect repair.
WhyMeLord - Replica
What if I didn't get all the adhesive out from under the battery?!
Margo Christianson - Replica
Very nice and helped me a lot. Thank you.
krakkoandras - Replica
Success. I got one adhesive strip to come out in one piece. The 2nd one snapped in half. I had to do the pry-of-shame, but once I could see the adhesive underneath the battery, I was able to grab it with the angled tweezers, and pull the rest of it out. Wow it’s a lot easier to remove the battery if you get both adhesive strips out in one piece each! I left the screen attached during the battery replacement, so I only removed the batter connector cover. Helps to have a 2nd person hold the screen so you don’t damage the connectors.
ericrose62 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 7
Tutti i Tempi: 68,700
