Introduzione
使用本指南对 开机排线进行更换。
Cosa ti serve
将蓝色手柄拉向铰链以解锁反向钳的手臂。
将反向钳手臂滑过 iPhone 的左边缘或右边缘。
将吸盘放在靠近 iPhone 底部边缘的位置——一个在正面,一个在背面。
向下推吸盘以将吸力施加到所需区域。
请倒序重组你的设备。
请倒序重组你的设备。
Altre 24 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
5 Commenti
I just did this while thing and my lock button still doesn’t work… any other suggestions?
Step 53: “raise—but do not remove—the logic board” did not mention that there was adhesive towards the top holding the board to the inner case. I had to use a thin plastic card to slide between to release the bond.
I did it with minor problems :
1 Quite difficult to stick the power button cable. On the left it must be just in front of the connector. On the right, at the exact place. Idem on the top for the light. And it is very sticky.
2 After doing the all work, half of the screen didn’t respond to the orders. But after cleaning it’s 4 connectors. Everything was OK.
P.M.
i like how this is moderate but the volume buttons which had 20 steps less and were the exact same procedure are very difficult
