Salta al contenuto principale
iPhone 4 (CDMA/Verizon) Screen Replacement
Cosa ti serve
  1. iPhone 4 (CDMA/Verizon) Screen Replacement, Rear Panel: passo 1, immagine 1 di 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Your phone's rear cover may have two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws. Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
    • Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
  2. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 2, immagine 1 di 2 iPhone 4 (CDMA/Verizon) Screen Replacement: passo 2, immagine 2 di 2
    • Push the rear panel toward the top edge of the iPhone.
    • The panel will move about 2 mm.
  3. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 3, immagine 1 di 1
    • Pinch the rear panel with your fingers, and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
    • Be careful not to damage the plastic clips attached to the rear panel.
  4. iPhone 4 (CDMA/Verizon) Screen Replacement, Battery: passo 4, immagine 1 di 1
    • Remove the single 1.5 mm Phillips screw securing the battery connector to the logic board (if present).
  5. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 5, immagine 1 di 1
    • Use the edge of a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not the socket on the logic board. If you pry up on the logic board socket, you may break it entirely.
    • Remove the metal clip covering the antenna connector.
  6. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 6, immagine 1 di 2 iPhone 4 (CDMA/Verizon) Screen Replacement: passo 6, immagine 2 di 2
    • Pull up on the exposed clear plastic tab to peel the battery off the adhesive securing it to the iPhone.
    • If the tab breaks before the battery is freed, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery. Wait about one minute for the alcohol solution to weaken the adhesive. Carefully slide a spudger under the battery tab to release the adhesive.
    • Prying in other places may cause damage. Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
    • If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
    • Remove the battery.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
    • Before reassembly, clean metal-to-metal contact points with a de-greaser such as windex. The oils from your fingers have the potential to cause wireless interference issues.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
  7. iPhone 4 (CDMA/Verizon) Screen Replacement, Dock Connector Cable: passo 7, immagine 1 di 2 iPhone 4 (CDMA/Verizon) Screen Replacement, Dock Connector Cable: passo 7, immagine 2 di 2
    • Remove the two 1.8 mm Phillips screws securing the dock connector cable to the logic board.
    • Remove the thin metal dock connector cable cover.
  8. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 8, immagine 1 di 1
    • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
  9. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 9, immagine 1 di 1
    • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
  10. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 10, immagine 1 di 2 iPhone 4 (CDMA/Verizon) Screen Replacement: passo 10, immagine 2 di 2
    • Remove the 1.6 mm Phillips screw securing the pressure contact to the logic board near the vibrator.
    • Remove the pressure contact.
  11. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 11, immagine 1 di 2 iPhone 4 (CDMA/Verizon) Screen Replacement: passo 11, immagine 2 di 2
    • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
    • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
    • When reconnecting the antenna wire be VERY certain that the round connector at the end of the wire is centered on its mating half on the motherboard before applying pressure. Failure to do so will likely destroy both halves of the connector.
  12. iPhone 4 (CDMA/Verizon) Screen Replacement, Rear Camera: passo 12, immagine 1 di 1
    • Remove the following five screws:
    • Three 1.3 mm Phillips screws
    • One 1.5 mm Phillips screw
    • One 2.4 mm Phillips screw
  13. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 13, immagine 1 di 2 iPhone 4 (CDMA/Verizon) Screen Replacement: passo 13, immagine 2 di 2
    • Lift the cable cover from its edge nearest the top of the iPhone.
    • Pull the cable cover tabs out of their slots cut into the EMI shield on the logic board and remove it from the iPhone.
  14. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 14, immagine 1 di 2 iPhone 4 (CDMA/Verizon) Screen Replacement: passo 14, immagine 2 di 2
    • Use the edge of a plastic opening tool to pry the rear camera connector up from its socket on the logic board.
    • Be careful not to break any components off the surrounding area on the logic board as you pry upwards.
    • Remove the rear camera from the iPhone.
    • Be careful not to scratch the back of the display assembly after the removal of the rear facing camera.
  15. iPhone 4 (CDMA/Verizon) Screen Replacement, Logic Board: passo 15, immagine 1 di 1
    • Disconnect the five cables near the top of the logic board in the following order:
    • Headphone jack/volume button cable
    • Power button cable
    • Front facing camera cable
    • Digitizer cable
    • Display data cable
    • To disconnect the cables, use the edge of a plastic opening tool to gently lift their connectors up and out of the sockets on the logic board.
    • Be careful not to break any of the small and delicate surface mount components as you disconnect the cables.
  16. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 16, immagine 1 di 1
    • Remove the 1.5 mm Phillips #000 screw near the headphone jack.
  17. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 17, immagine 1 di 1
    • Lift the small grounding clip up off the logic board and remove it from the iPhone.
  18. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 18, immagine 1 di 1
    • Use the edge of a plastic opening tool to disconnect the Wi-Fi antenna cable connector from the logic board.
    • When reconnecting the wifi ribbon connector to the mother board be VERY certain that the round connector at the end of the ribbon cable is centered on its mating half on the motherboard before applying pressure. Failure to do so will likely destroy both halves of the connection.
  19. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 19, immagine 1 di 2 iPhone 4 (CDMA/Verizon) Screen Replacement: passo 19, immagine 2 di 2
    • If present, remove the piece of tape covering a Phillips screw near the power button.
  20. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 20, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Standoff Screwdriver for iPhones
    $5.49
    Compra
    • Remove the 2.5 mm Phillips #000 screw securing the logic board near the power button.
    • Remove the 4.8 mm standoff screw near the headphone jack.
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  21. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 21, immagine 1 di 1
    • Remove the 3.4 mm Phillips screw near the vibrator motor.
    • Remove the two 3.6 mm standoff screws along the side of the logic board nearest the battery opening.
  22. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 22, immagine 1 di 1
    • Carefully lift the logic board from the end closest to the speaker enclosure and slide it away from the top edge of the iPhone.
    • Remove the logic board.
    • Before reassembly, be sure to clean all metal-to-metal contact points on the logic board (not the mating halves of connectors) with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause grounding issues.
    • There's a small rectangular rubber pad at the top of the logic board that prevents the display cables from chafing against the edge of the board. If it comes loose during your repair, make sure to position it correctly when reinstalling your logic board.
  23. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 23, immagine 1 di 1
    • Be sure not to lose the small grounding finger for the rear facing camera near the power button.
  24. iPhone 4 (CDMA/Verizon) Screen Replacement, Vibrator: passo 24, immagine 1 di 2 iPhone 4 (CDMA/Verizon) Screen Replacement, Vibrator: passo 24, immagine 2 di 2
    • Use the edge of a plastic opening tool to pry the vibrator off the adhesive securing it to the frame of the iPhone.
    • Remove the vibrator.
  25. iPhone 4 (CDMA/Verizon) Screen Replacement, Screen: passo 25, immagine 1 di 1
    • Remove the two 2.4 mm Phillips screws from the sides of the speaker enclosure assembly.
  26. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 26, immagine 1 di 1
    • Remove the small plastic bracket that was installed under the screw closest to the dock connector cable.
  27. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 27, immagine 1 di 2 iPhone 4 (CDMA/Verizon) Screen Replacement: passo 27, immagine 2 di 2
    • Remove the speaker enclosure assembly from the iPhone.
    • Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the second picture.
    • Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
  28. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 28, immagine 1 di 1
    • Remove the small pieces of black tape covering the display mounting tabs.
  29. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 29, immagine 1 di 1
    • Remove the 1.6 mm Phillips screw securing the display assembly near the power button.
  30. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 30, immagine 1 di 1
    • Remove the 1.6 mm Phillips screw near the headphone jack.
  31. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 31, immagine 1 di 1
    • Remove the 1.6 mm Phillips screw near the lower microphone.
  32. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 32, immagine 1 di 1
    • Remove the 1.6 mm Phillips screw near the dock connector cable.
  33. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 33, immagine 1 di 2 iPhone 4 (CDMA/Verizon) Screen Replacement: passo 33, immagine 2 di 2
    • Loosen the three large-headed Phillips screws along the volume button side of the iPhone about one half turn.
    • It is not necessary to completely remove these screws. When reinstalling the display assembly, be sure the washers are closest to the screw head (as seen in the second picture).
  34. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 34, immagine 1 di 1
    • Loosen the three large-headed Phillips screws along the other side of the iPhone about one half turn.
  35. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 35, immagine 1 di 3 iPhone 4 (CDMA/Verizon) Screen Replacement: passo 35, immagine 2 di 3 iPhone 4 (CDMA/Verizon) Screen Replacement: passo 35, immagine 3 di 3
    • Use the edge of a plastic opening tool to gently pry up the display assembly around its perimeter.
    • Press gently on the home button to push it through the display and make sure it stays behind as the display separates from the iPhone. Otherwise, the home button cable may tear.
    • De-route the digitizer and LCD cables through the steel inner frame.
    • When reinstalling the display, carefully straighten the digitizer and LCD data cables, and feed them through the slot cut in the steel frame. This photo shows the display assembly being installed incorrectly, with a fold in the digitizer cable.
    • When the front panel has been correctly installed, both the LCD and digitizer cables should be immediately next to one another and should be the same length, as shown in the second photo.
    • If the digitizer cable has been installed incorrectly, it will not reach its socket on the logic board. Do not attempt to pull it through by force, or it will tear. Remove the display assembly, straighten the cable, and feed it through to its full length, as shown.
    • During reassembly, do not touch the metallic area at the base of the LCD data cable, as this can cause problems with the LCD. If you do touch it accidentally, clean it gently with an alcohol wipe before continuing.
  36. iPhone 4 (CDMA/Verizon) Screen Replacement: passo 36, immagine 1 di 2 iPhone 4 (CDMA/Verizon) Screen Replacement: passo 36, immagine 2 di 2
    • Remove the display assembly from the iPhone.
    • Be sure to separate the home button from the front panel. If the home button sticks to the front panel you may tear the home button cable.
    • When replacing the display assembly, note the following:
    • You may have to reuse the earpiece grille and the clear plastic ring around the front facing camera from the old/damaged assembly. This will depend on where you buy the replacement part.
    • Your replacement display may come with colored plastic film on the back of the LCD. If so, use the pull tab near the home button to peel the plastic film from the LCD before installing the new display in your iPhone.
    • After reassembly, note the following:
    • Clean the touchscreen surface with an alcohol wipe prior to turning the iPhone back on. The alcohol helps dissipate any lingering static electricity, which can cause problems with the display.
    • After reassembly, connect the iPhone to an AC power source before turning it on for the first time. Once the iPhone has booted up successfully, you can disconnect the AC power.
Conclusione
Altre 622 persone hanno completato questa guida.
44 Commenti
Thanks guys' u are always awesome!!!
Cheik sana - Replica
I could not remove the logic board because it will not release at the top left. Have I missed something.
elaineleiker - Replica
Their are only 3 things that are holding down anything in the cell phone world screws adhesive or clips their are 5 screws connecting the board make sure all 5 are removed theirs also kinda a clip it fits under be careful not to brake that when taking it out
brandon hobbs -
Had it done in1.5hrs exact. Very helpful as always, thanks IFIX IT.
Its a good note to posted's and label where the screw is from, since they are so small and a pain to remember where its going.
mirandaroque - Replica
The Digitizer Cable seems to be too short. Trying to make it reach. It doesn't reach its place on the logic board. Going to disassemble and start over. (Step 15)
Any pointers?
chris - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 33
Ultimi 30 Giorni: 108
Tutti i Tempi: 368,167
