Salta al contenuto principale
iPhone 4 Rear panel glass Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
Panoramica Video
  1. iPhone 4 Rear panel glass Replacement, Rear Panel: passo 1, immagine 1 di 3 iPhone 4 Rear panel glass Replacement, Rear Panel: passo 1, immagine 2 di 3 iPhone 4 Rear panel glass Replacement, Rear Panel: passo 1, immagine 3 di 3
    • Here you can see the original cracked rear panel and the replacement panel.
    • Next using a Phillips head screwdriver, remove the mounting screws at the bottom of the iPhone. Place them aside carefully as they are really small.
    • Finally, once the screws are out gently apply pressure and slide the screen up to release the panel. Careful not to be too rough with it.
  2. iPhone 4 Rear panel glass Replacement: passo 2, immagine 1 di 2 iPhone 4 Rear panel glass Replacement: passo 2, immagine 2 di 2
    • Carefully place the replacement panel on to the iPhone back lining it up as close to the bottom as possible.
    • Now again gently apply pressure as you slide the panel towards the bottom of the iPhone to lock it into place.
    • Replace the screws that you set aside earlier and be sure no to over tighten otherwise you will strip them.
  3. iPhone 4 Rear panel glass Replacement, Kara repairs Grandma's iPhone: passo 3, immagine 1 di 1
    • So simple even a four-year-old can fix it!
Conclusione
Altre 6 persone hanno completato questa guida.
joe
Membro da: 07/28/14
242 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 681
