Salta al contenuto principale
iPhone 16e Loudspeaker Replacement
Cosa ti serve
  1. iPhone 16e Loudspeaker Replacement, Before you begin: passo 1, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Before you begin: passo 1, immagine 2 di 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power button and either volume button, then slide to power off your phone.
  2. iPhone 16e Loudspeaker Replacement, Tape over any cracks: passo 2, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Tape over any cracks: passo 2, immagine 2 di 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16e Loudspeaker Replacement, Remove the pentalobe screws: passo 3, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Remove the pentalobe screws: passo 3, immagine 2 di 2
    • Use a P2 pentalobe screwdriver to remove the two 7.8 mm‑long screws on either side of the charging port.
  4. iPhone 16e Loudspeaker Replacement, Mark your opening picks: passo 4, immagine 1 di 3 iPhone 16e Loudspeaker Replacement, Mark your opening picks: passo 4, immagine 2 di 3 iPhone 16e Loudspeaker Replacement, Mark your opening picks: passo 4, immagine 3 di 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  5. iPhone 16e Loudspeaker Replacement, Heat the bottom edge: passo 5, immagine 1 di 1
    • Apply a heated iOpener to the bottom edge of the back glass for 90 seconds.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 16e Loudspeaker Replacement, Insert an opening pick: passo 6, immagine 1 di 3 iPhone 16e Loudspeaker Replacement, Insert an opening pick: passo 6, immagine 2 di 3 iPhone 16e Loudspeaker Replacement, Insert an opening pick: passo 6, immagine 3 di 3
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 16e Loudspeaker Replacement, Back glass information: passo 7, immagine 1 di 1
    • As you slice the adhesive securing the back glass in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • A delicate cable connecting the back glass to the phone, next to the volume up button.
    • Multiple spring contacts around the perimeter of the phone.
  8. iPhone 16e Loudspeaker Replacement, Separate the bottom adhesive: passo 8, immagine 1 di 3 iPhone 16e Loudspeaker Replacement, Separate the bottom adhesive: passo 8, immagine 2 di 3 iPhone 16e Loudspeaker Replacement, Separate the bottom adhesive: passo 8, immagine 3 di 3
    • Slide the opening pick along the bottom of the back glass to separate the adhesive.
    • Leave the opening pick near the bottom left corner.
  9. iPhone 16e Loudspeaker Replacement, Heat the left edge: passo 9, immagine 1 di 1
    • Apply a heated iOpener to the left edge of the back glass for 90 seconds.
    • When using a hair dryer or heat gun, heat the back glass until it's hot to the touch.
  10. iPhone 16e Loudspeaker Replacement: passo 10, immagine 1 di 3 iPhone 16e Loudspeaker Replacement: passo 10, immagine 2 di 3 iPhone 16e Loudspeaker Replacement: passo 10, immagine 3 di 3
    • Rotate the opening pick around the bottom left corner and slide it along the left edge to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave the opening pick near the top left corner.
  11. iPhone 16e Loudspeaker Replacement, Heat the top edge: passo 11, immagine 1 di 1
    • Apply a heated iOpener to the top edge of the back glass for 90 seconds.
  12. iPhone 16e Loudspeaker Replacement, Separate the top adhesive: passo 12, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Separate the top adhesive: passo 12, immagine 2 di 2
    • Rotate the opening pick around the top left corner and slide it along the top edge to separate the adhesive and release the metal clips.
    • Leave the opening pick in the top right corner.
  13. iPhone 16e Loudspeaker Replacement, Heat the right edge: passo 13, immagine 1 di 1
    • Apply a heated iOpener to the right edge of the back glass for 90 seconds.
  14. iPhone 16e Loudspeaker Replacement, Separate the right adhesive: passo 14, immagine 1 di 3 iPhone 16e Loudspeaker Replacement, Separate the right adhesive: passo 14, immagine 2 di 3 iPhone 16e Loudspeaker Replacement, Separate the right adhesive: passo 14, immagine 3 di 3
    • Don't insert your pick deeper than 3 mm to avoid damaging the hidden cable.
    • Rotate the opening pick around the top right corner and slide it along the right edge to separate the remaining adhesive and the metal clip.
    • You'll hear and feel the metal clip release as you pass it.
  15. iPhone 16e Loudspeaker Replacement: passo 15, immagine 1 di 3 iPhone 16e Loudspeaker Replacement: passo 15, immagine 2 di 3 iPhone 16e Loudspeaker Replacement: passo 15, immagine 3 di 3
    • Your back glass adhesive should now be completely separated. If it isn't, slide your opening pick around the back glass to separate any remaining adhesive.
    • Swing open the back glass to the right of the phone and support it upright on a clean, sturdy object.
  16. iPhone 16e Loudspeaker Replacement, Remove the lower connector cover screws: passo 16, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Remove the lower connector cover screws: passo 16, immagine 2 di 2
    • Use a tri-point Y000 screwdriver to remove the two 1.3 mm‑long screws securing the lower connector cover.
  17. iPhone 16e Loudspeaker Replacement, Remove the battery bracket: passo 17, immagine 1 di 3 iPhone 16e Loudspeaker Replacement, Remove the battery bracket: passo 17, immagine 2 di 3 iPhone 16e Loudspeaker Replacement, Remove the battery bracket: passo 17, immagine 3 di 3
    • Use tweezers or your fingers to lift the lower connector cover and slide it toward the top of the phone to release it from its metal clip.
    • Remove the lower connector cover.
  18. iPhone 16e Loudspeaker Replacement, Disconnect the battery: passo 18, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Disconnect the battery: passo 18, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  19. iPhone 16e Loudspeaker Replacement, Remove the middle connector cover screw: passo 19, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Remove the middle connector cover screw: passo 19, immagine 2 di 2
    • Use a tri-point Y000 screwdriver to remove the 1.0 mm‑long screw securing the middle connector cover.
  20. iPhone 16e Loudspeaker Replacement, Remove the middle connector cover: passo 20, immagine 1 di 3 iPhone 16e Loudspeaker Replacement, Remove the middle connector cover: passo 20, immagine 2 di 3 iPhone 16e Loudspeaker Replacement, Remove the middle connector cover: passo 20, immagine 3 di 3
    • The middle connector cover is slotted into two metal clips on the top and bottom.
    • Use the point of a spudger to push the middle connector cover towards the bottom of the phone to release its clips.
    • Use tweezers or your fingers to remove the cover.
  21. iPhone 16e Loudspeaker Replacement, Disconnect the wireless charging coil: passo 21, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Disconnect the wireless charging coil: passo 21, immagine 2 di 2
    • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
  22. iPhone 16e Loudspeaker Replacement, Remove the back glass: passo 22, immagine 1 di 1
    • Lift the back glass off the frame and remove it.
  23. iPhone 16e Loudspeaker Replacement, Remove the loudspeaker screws: passo 23, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Remove the loudspeaker screws: passo 23, immagine 2 di 2
    • Use a Phillips screwdriver to remove the four screws securing the loudspeaker:
    • Two 1.4 mm‑long screws
    • Two 1.7 mm‑long screws
    • Use a tri-point Y000 screwdriver to remove the 1.3 mm‑long screw.
  24. iPhone 16e Loudspeaker Replacement, Remove the loudspeaker: passo 24, immagine 1 di 3 iPhone 16e Loudspeaker Replacement, Remove the loudspeaker: passo 24, immagine 2 di 3 iPhone 16e Loudspeaker Replacement, Remove the loudspeaker: passo 24, immagine 3 di 3
    • Use the point of the spudger to lift the loudspeaker out of the frame and remove it.
  25. iPhone 16e Loudspeaker Replacement, Loudspeaker gasket information: passo 25, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Loudspeaker gasket information: passo 25, immagine 2 di 2
    • If the orange loudspeaker gasket fell out during disassembly, use tweezers to place it back into the sound channel.
  26. iPhone 16e Loudspeaker Replacement, End of disassembly: passo 26, immagine 1 di 1
    • Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
  27. iPhone 16e Loudspeaker Replacement, Install the loudspeaker: passo 27, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Install the loudspeaker: passo 27, immagine 2 di 2
    • Place the loudspeaker into its cutout in the frame.
  28. iPhone 16e Loudspeaker Replacement, Install the loudspeaker screws: passo 28, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Install the loudspeaker screws: passo 28, immagine 2 di 2
    • Use a Phillips screwdriver to install the four screws securing the loudspeaker:
    • Use a tri-point Y000 screwdriver to install the 1.3 mm‑long screw.
  29. iPhone 16e Loudspeaker Replacement, Remove the residual frame adhesive: passo 29, immagine 1 di 3 iPhone 16e Loudspeaker Replacement, Remove the residual frame adhesive: passo 29, immagine 2 di 3 iPhone 16e Loudspeaker Replacement, Remove the residual frame adhesive: passo 29, immagine 3 di 3
    • Use tweezers to remove the adhesive around the perimeter of the frame.
    • You may need to bunch up the adhesive with the point of a spudger before gripping it with tweezers.
    • Use a coffee filter or a lint‑free cloth and high‑concentration isopropyl alcohol (>%90) to clean off any adhesive residue.
  30. iPhone 16e Loudspeaker Replacement, Orient the adhesive: passo 30, immagine 1 di 3 iPhone 16e Loudspeaker Replacement, Orient the adhesive: passo 30, immagine 2 di 3 iPhone 16e Loudspeaker Replacement, Orient the adhesive: passo 30, immagine 3 di 3
    • Orient your replacement adhesive over the frame with the larger blue liner on the underside and its pull tab in the bottom-right corner.
    • The color of your liner and the pull tab locations may be different on your adhesive.
    • Use features such as the camera cutout and notches along the edges to visualize how the adhesive will lay in the frame.
  31. iPhone 16e Loudspeaker Replacement, Apply the adhesive: passo 31, immagine 1 di 3 iPhone 16e Loudspeaker Replacement, Apply the adhesive: passo 31, immagine 2 di 3 iPhone 16e Loudspeaker Replacement, Apply the adhesive: passo 31, immagine 3 di 3
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • Use the pull tab to begin peeling the back liner off the adhesive starting from the bottom, but don't remove the liner all the way.
    • Hold the blue liner out of the way and align the adhesive with the bottom edge of the iPhone.
    • Lay the bottom edge of the adhesive into its recess in the frame, making sure the iPhone's spring contacts are aligned with their cutouts in the liner.
  32. iPhone 16e Loudspeaker Replacement: passo 32, immagine 1 di 3 iPhone 16e Loudspeaker Replacement: passo 32, immagine 2 di 3 iPhone 16e Loudspeaker Replacement: passo 32, immagine 3 di 3
    • Continue peeling the back liner off the adhesive while pressing the adhesive into place along the edges of the iPhone's frame.
    • If you correctly aligned the lower edge of the adhesive, the side and top edges will fall perfectly into place. If the adhesive is misaligned, remove it and start over with new adhesive.
    • If your adhesive is misaligned and you don't have another set handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive, but keep in mind that your iPhone's water resistance will be compromised until you install new adhesive.
  33. iPhone 16e Loudspeaker Replacement, Press the adhesive into place: passo 33, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Press the adhesive into place: passo 33, immagine 2 di 2
    • Use the flat end of a spudger to press the adhesive into place around the perimeter of the frame.
  34. iPhone 16e Loudspeaker Replacement: passo 34, immagine 1 di 3 iPhone 16e Loudspeaker Replacement: passo 34, immagine 2 di 3 iPhone 16e Loudspeaker Replacement: passo 34, immagine 3 di 3
    • Use the tip of a spudger to lift up the pull tab on the top right corner of the pink adhesive liner until you can grip it with your fingers.
  35. iPhone 16e Loudspeaker Replacement: passo 35, immagine 1 di 3 iPhone 16e Loudspeaker Replacement: passo 35, immagine 2 di 3 iPhone 16e Loudspeaker Replacement: passo 35, immagine 3 di 3
    • Use the pull tab to peel the pink liner off the frame and expose the secondary blue liners.
  36. iPhone 16e Loudspeaker Replacement, Connect the press connectors: passo 36, immagine 1 di 3 iPhone 16e Loudspeaker Replacement, Connect the press connectors: passo 36, immagine 2 di 3 iPhone 16e Loudspeaker Replacement, Connect the press connectors: passo 36, immagine 3 di 3
    • Prop up the back glass along the right edge of your iPhone, using a box or similar sturdy object to support the glass.
    • Use the flat end of a spudger or your finger to connect the charging coil press connector, then the battery press connector.
  37. iPhone 16e Loudspeaker Replacement, Place the middle connector cover: passo 37, immagine 1 di 3 iPhone 16e Loudspeaker Replacement, Place the middle connector cover: passo 37, immagine 2 di 3 iPhone 16e Loudspeaker Replacement, Place the middle connector cover: passo 37, immagine 3 di 3
    • Place the middle connector cover over the wireless charging coil press connector so it slightly overhangs the slot on the logic board for the bottom clip.
  38. iPhone 16e Loudspeaker Replacement: passo 38, immagine 1 di 3 iPhone 16e Loudspeaker Replacement: passo 38, immagine 2 di 3 iPhone 16e Loudspeaker Replacement: passo 38, immagine 3 di 3
    • Use your finger to press the cover down on the logic board.
    • While pressing it down, slide the cover upward so both metal clips slot into their spots in the logic board.
  39. iPhone 16e Loudspeaker Replacement, Place the lower connector cover: passo 39, immagine 1 di 3 iPhone 16e Loudspeaker Replacement, Place the lower connector cover: passo 39, immagine 2 di 3 iPhone 16e Loudspeaker Replacement, Place the lower connector cover: passo 39, immagine 3 di 3
    • Use tweezers to place the top of the lower connector cover over its slot in the logic board.
    • Lay the lower connector cover over the press connector.
  40. iPhone 16e Loudspeaker Replacement, Install the cover screws: passo 40, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Install the cover screws: passo 40, immagine 2 di 2
    • Use a tri-point Y000 screwdriver to install the 1.0 mm‑long screw securing the middle connector cover.
    • Use a tri-point Y000 screwdriver to install the two 1.3 mm‑long screws securing the lower connector cover.
  41. iPhone 16e Loudspeaker Replacement, Remove the final liners: passo 41, immagine 1 di 3 iPhone 16e Loudspeaker Replacement, Remove the final liners: passo 41, immagine 2 di 3 iPhone 16e Loudspeaker Replacement, Remove the final liners: passo 41, immagine 3 di 3
    • Use tweezers to grip the pull tabs on the three blue liners and peel them off to expose the adhesive.
    • You may need to hold the back glass above the frame without it touching the adhesive to remove the liner along the right edge.
  42. iPhone 16e Loudspeaker Replacement, Place the back glass: passo 42, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Place the back glass: passo 42, immagine 2 di 2
    • Hold the back glass above the phone and align it with the frame.
  43. iPhone 16e Loudspeaker Replacement: passo 43, immagine 1 di 2 iPhone 16e Loudspeaker Replacement: passo 43, immagine 2 di 2
    • Lay the back glass straight down onto the frame and press until the clips engage.
    • Press around the perimeter of the back glass to engage all clips.
  44. iPhone 16e Loudspeaker Replacement, Heat the back glass: passo 44, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Heat the back glass: passo 44, immagine 2 di 2
    • To help the adhesive bond, apply heat to the edges of the back glass using an iOpener, hair dryer, or heat gun until it's hot to the touch.
    • Firmly press around the perimeter of the back glass. If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the back glass.
  45. iPhone 16e Loudspeaker Replacement, Press the back glass: passo 45, immagine 1 di 3 iPhone 16e Loudspeaker Replacement, Press the back glass: passo 45, immagine 2 di 3 iPhone 16e Loudspeaker Replacement, Press the back glass: passo 45, immagine 3 di 3
    • To evenly compress your iPhone and strengthen the bond of the back glass to the frame, you need to account for the camera bump.
    • If you have the box your iPhone came in, take the lid and place it on a flat surface.
    • If you don't have your original box, skip this step for an alternate method.
    • Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
    • Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
    • Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
  46. iPhone 16e Loudspeaker Replacement: passo 46, immagine 1 di 3 iPhone 16e Loudspeaker Replacement: passo 46, immagine 2 di 3 iPhone 16e Loudspeaker Replacement: passo 46, immagine 3 di 3
    • If you don't have the original box for your iPhone, follow the next three steps for another method to evenly compress the back glass.
    • Place the iPhone screen-side-down on a soft, flat surface.
    • Apply tape to the back glass to protect its finish.
  47. iPhone 16e Loudspeaker Replacement: passo 47, immagine 1 di 3 iPhone 16e Loudspeaker Replacement: passo 47, immagine 2 di 3 iPhone 16e Loudspeaker Replacement: passo 47, immagine 3 di 3
    • Place one layer of coins or similarly thick objects on the tape along the edges of the back glass.
    • Depending on the thickness of the coins, you might need multiple layers.
    • Evenly distribute the coins and make sure they are at least as thick as the camera bump.
  48. iPhone 16e Loudspeaker Replacement: passo 48, immagine 1 di 1
    • Stack multiple books or other heavy objects on your iPhone.
    • The coins may leave an impression on the bottom object, so don't use anything valuable.
  49. iPhone 16e Loudspeaker Replacement, Install the pentalobe screws: passo 49, immagine 1 di 2 iPhone 16e Loudspeaker Replacement, Install the pentalobe screws: passo 49, immagine 2 di 2
    • Use a P2 pentalobe screwdriver to install the two 7.8 mm‑long screws on either side of the charging port.
Conclusione
After your repair, calibrate a genuine replacement loudspeaker using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16e Answers Community for help.
Alex Diaz-Kokaisl
Membro da: 01/16/22
212.843 Reputazione
1.039 Guide realizzate
iFixit Membro di iFixit
Staff
123 Membri
23.613 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 73
Tutti i Tempi: 431
