Introduzione
Use this guide to replace a broken, cracked, or non‑responsive screen in your iPhone 16.
You'll need replacement screen adhesive to complete this repair.
Note: Since you can't disconnect the battery during this repair, be especially careful not to use metal prying tools or touch exposed contacts in your iPhone.
After your repair, calibrate an authentic display using Apple's Repair Assistant.
Cosa ti serve
Unplug any cables from your phone.
Hold the power and either volume buttons and slide to power off your phone.
If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
Attrezzo utilizzato in questo passaggio:iOpener$14.99
Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
Apply a suction handle to the bottom edge of the screen.
While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
Insert the tip of an opening pick into the gap.
Two delicate cables connecting the screen to the phone—one just above the Action button and the other about halfway between the volume down button and the bottom of the phone.
Multiple spring contacts around the perimeter of the phone.
Use a hair dryer or heat gun to heat the right edge of the screen until it's hot to the touch.
Slide your opening pick around the bottom right corner and up the right edge of the screen to separate the adhesive and release the metal clip.
Use a hair dryer or heat gun to heat the top edge of the screen until it's hot to the touch.
Continue sliding your pick around the top right corner and across the top edge to separate the adhesive and release the two metal clips.
Use a hair dryer or heat gun to heat the left edge of the screen until it's hot to the touch.
Slide the opening pick down the left edge of the screen to separate the remaining adhesive and release the last two metal clips.
Swing open the screen over the left edge of the phone and support it with a clean, sturdy object.
Use a tri-point Y000 driver to remove the two 0.9 mm‑long screws securing the front sensor and screen connector covers.
Use the tip of a spudger to pry up and disconnect the screen press connector.
Repeat for the front sensor press connector.
Use a Phillips screwdriver to remove the 1.3 mm‑long screw securing the ambient light sensor bracket.
Use a pair of tweezers or your fingers to lift and remove the ambient light sensor bracket.
Use a hair dryer, heat gun, or heated iOpener to soften the adhesive under the ambient light sensor and ambient light sensor cable.
Use an opening pick to pry up the ambient light sensor.
Use your finger to push the ambient light sensor away from its recess.
Gently slide an opening pick under the ambient light sensor cable, starting near the sensor and moving towards to the opposite corner.
Continue slowly sliding the opening pick under the ambient light sensor cable until the cable is free from the screen.
Use a pair of tweezers to lift the ambient light sensor off of the screen.
Congratulations on completing disassembly! The remaining steps will show you how to reassemble your device.
Attrezzo utilizzato in questo passaggio:Tesa 61395 Tape$2.99
Without letting the ambient light sensor adhesive touch the screen, use a pair of tweezers to hold the sensor above the back of the new screen.
Align the ambient light sensor with its recess in the back of the screen.
Use a spudger or your finger to press the ambient light sensor into its recess.
Lay the ambient light sensor cable down on the back of the screen.
Use your finger to press down the ambient light sensor cable.
Use tweezers or your fingers to place the ambient light sensor bracket over the back of the sensor.
Use a Phillips screwdriver to install the 1.3 mm‑long screw securing the ambient light sensor bracket.
Use a spudger to push the screen adhesive up until you can grab it with a pair of tweezers.
Use a pair of tweezers to remove the adhesive around the entire perimeter of the phone.
Wrap a microfiber or lint-free cloth around the pointed end of a spudger and apply a few drops of high-concentration (greater than 90%) isopropyl alcohol to the cloth.
Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
Wait a few minutes before proceeding to make sure any excess alcohol has evaporated.
Lay the adhesive next to the phone and use features like cutouts for spring contacts and the front‑facing camera to make sure the adhesive is oriented correctly.
Use the pull tab to begin peeling the back liner off of the adhesive starting from the bottom, but do not remove the liner all the way.
While holding the back liner out of the way, carefully align the exposed edge of the adhesive to the bottom edge of the iPhone's frame.
When the adhesive is aligned, use your finger to press it down firmly along the bottom edge.
Make sure the liner is aligned properly by checking that all spring contacts and the front-facing camera are in their cutouts. If they aren't, remove the adhesive and start over with a new sheet.
Use the flat end of a spudger to press the adhesive firmly into place all around the iPhone.
Use the point of a spudger to lift the pull tab in the top‑right corner of the frame until you can grab it with your fingers.
Peel back the top liner and remove it.
Once the top liner is removed, there should be three narrow liners on top of the adhesive with pull tabs near the bottom edge.
If you don't see these pull tabs, you may have accidentally removed the thin liners in the previous step. If the adhesive is clean and properly aligned, you may proceed, just be careful not to touch anything to the exposed adhesive until you are ready to install the screen.
Prop the screen up along the left edge of the iPhone frame, using a box or similar sturdy object to support the screen.
Use the flat end of a spudger or your finger to connect the screen and front sensor press connectors.
Use a pair of tweezers or your fingers to place the screen connector cover over the screen connector by inserting it at a slight downward angle to engage the hook, then laying the cover flat over the connector.
Use a tri-point Y000 driver to install the two 0.9 mm‑long screws securing the front sensor connector and screen connector covers.
Use a pair of tweezers or your fingers to remove the two narrow liners covering the adhesive along the right, top, and bottom edges of the iPhone.
To help the adhesive bond, apply heat to the edges of the screen using an iOpener, hair dryer, or heat gun until it's hot to the touch.
Firmly press around the perimeter of the screen.
If you have screen vise clamps, use them to strengthen the bond of your new adhesive. If not, keep reading for more ways to secure the screen.
If you have the box your iPhone came in, take the lid and place it on a flat surface.
Place your iPhone screen-side-up in the lid of your box with the camera bump in its recess.
Find something close to the size of your iPhone, but taller than the sides of the box. Stack it on top of the iPhone, followed by a few heavy objects.
Leave the objects in place for at least thirty minutes. The lighter the objects, the longer they should be left. Ideally, leave them stacked overnight.
Use a P2 pentalobe driver to install the two 7.7 mm-long screws on either side of the charging port.
After your repair, calibrate a genuine replacement screen using Apple's Repair Assistant. Navigate to Settings → General → About → Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Answers Community for help.
Altre 5 persone hanno completato questa guida.
3Commenti sulla guida
i am impressed that apple FINALLY caved for better repair support on right-to-repair and RCS. worked great on my iphone 16 for much cheaper than the appple store was offering. also first comment.
