Salta al contenuto principale
iPhone 11 Pro Rear Case Replacement
Cosa ti serve
Panoramica Video
  1. iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: passo 1, immagine 1 di 2 iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: passo 1, immagine 2 di 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Conclusione
Altre 12 persone hanno completato questa guida.
Arty
Membro da: 10/27/19
24.481 Reputazione
92 Guide realizzate
3 Commenti
how much for housing iphone 11 pro ? Thank you
daddy - Replica
If yo buy it from indonesia it only cost you arround $100-$200
izaz adityas -
I ordered a new charging port but it doesn’t seem to include a speaker element on the left side, and the charging connector module above the port. Can those be moved over from the old charging port?
lemonlev - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 119
Tutti i Tempi: 17,055
