Salta al contenuto principale
iPad mini 4 LTE Right Cellular Antenna Replacement
Cosa ti serve
  1. iPad mini 4 LTE Right Cellular Antenna Replacement, Taping a Cracked Front Panel: passo 1, immagine 1 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement, Taping a Cracked Front Panel: passo 1, immagine 2 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement, Taping a Cracked Front Panel: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Safety Glasses
    $3.19
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered. For particularly bad breaks, you may need to lay down two layers.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Protect your eyes! This procedure will cause small pieces of glass to fly directly toward your face. Do not attempt without safety glasses.
  2. iPad mini 4 LTE Right Cellular Antenna Replacement, Opening Procedure: passo 2, immagine 1 di 1
  3. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 3, immagine 1 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 3, immagine 2 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 3, immagine 3 di 3
    • Apply a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat and try again.
    • Be careful to only lift the glass enough to insert an opening pickโ€”any more and you risk cracking the glass.
  4. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 4, immagine 1 di 2 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 4, immagine 2 di 2
    • While holding the glass up with the suction cup, insert the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than 2 mm into the side of the display. Inserting the pick deeper than 2 mm could damage the backlight assembly, LCD display, or touchscreen.
  5. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 5, immagine 1 di 1
    • Reheat and reapply the iOpener to the left edge for a few minutes.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
  6. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 6, immagine 1 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 6, immagine 2 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 6, immagine 3 di 3
    • Insert a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance while sliding the pick, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
  7. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 7, immagine 1 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 7, immagine 2 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 7, immagine 3 di 3
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  8. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 8, immagine 1 di 2 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 8, immagine 2 di 2
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
  9. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 9, immagine 1 di 1
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  10. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 10, immagine 1 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 10, immagine 2 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 10, immagine 3 di 3
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  11. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 11, immagine 1 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 11, immagine 2 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 11, immagine 3 di 3
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • As you reach the front-facing camera, pull the pick out slightly and continue sliding it across the top edge.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  12. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 12, immagine 1 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 12, immagine 2 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 12, immagine 3 di 3
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
  13. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 13, immagine 1 di 2 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 13, immagine 2 di 2
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  14. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 14, immagine 1 di 1
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPadโ€”along the volume and lock buttons.
  15. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 15, immagine 1 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 15, immagine 2 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 15, immagine 3 di 3
    • Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go.
  16. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 16, immagine 1 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 16, immagine 2 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 16, immagine 3 di 3
    • Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary.
    • Be careful not to slice too deep near the bottom right corner, or you risk damaging the display cable.
  17. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 17, immagine 1 di 1
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpenerโ€”no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
  18. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 18, immagine 1 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 18, immagine 2 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 18, immagine 3 di 3
    • Insert a new opening pick at the bottom right corner of the display, below the last opening pick you used to slice down the right edge.
    • Rotate the new pick around the lower right corner of the device.
  19. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 19, immagine 1 di 2 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 19, immagine 2 di 2
    • Slide the pick from the bottom right corner along the lower edge of the device. Stop about half an inch shy of the home button.
  20. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 20, immagine 1 di 2 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 20, immagine 2 di 2
    • Insert a final opening pick at the lower left corner of the iPad, directly below the existing one.
  21. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 21, immagine 1 di 2 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 21, immagine 2 di 2
    • Slide the pick around the lower left edge of the iPad.
  22. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 22, immagine 1 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 22, immagine 2 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 22, immagine 3 di 3
    • Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button.
  23. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 23, immagine 1 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 23, immagine 2 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 23, immagine 3 di 3
    • Twist the two picks at the top edge of the iPad to break up the last of the adhesive holding the display assembly in place.
    • Lift the display from the top edge to open the device.
  24. iPad mini 4 LTE Right Cellular Antenna Replacement, Battery Connector: passo 24, immagine 1 di 1
    • To avoid stressing any cables, hold the display assembly perpendicular to the body of the iPad until it is disconnected.
    • Remove the four 1.2 mm Phillips screws over the battery/display connector bracket.
  25. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 25, immagine 1 di 1
    • Remove the battery/display cable bracket.
  26. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 26, immagine 1 di 2 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 26, immagine 2 di 2
    • When disconnecting any press connectors from the logic board, be sure to lift the connector straight up to avoid ripping the socket off the board.
    • Use the flat tip of a spudger to disconnect the battery connector from its socket on the logic board.
    • Bend the battery connector ribbon cable up slightly to prevent it from making contact and powering on the iPad.
  27. iPad mini 4 LTE Right Cellular Antenna Replacement, Display Assembly: passo 27, immagine 1 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement, Display Assembly: passo 27, immagine 2 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement, Display Assembly: passo 27, immagine 3 di 3
    • Use the pointed end of a spudger to disconnect the display data connector from its socket on the logic board.
    • Use the pointed end of a spudger to disconnect the digitizer cable connector from its socket on the logic board.
    • When reconnecting these, press down from one end of the connector to the other. If you press in the middle of the connector, you may bend it, causing damage or a poor connection.
  28. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 28, immagine 1 di 1
    • Remove the display assembly.
    • To reinstall your display assembly, you will need to replace the display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
  29. iPad mini 4 LTE Right Cellular Antenna Replacement, Right Cellular Antenna: passo 29, immagine 1 di 2 iPad mini 4 LTE Right Cellular Antenna Replacement, Right Cellular Antenna: passo 29, immagine 2 di 2
    • Remove the four 1.3 mm Phillips screws securing the right antenna to the rear case.
  30. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 30, immagine 1 di 2 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 30, immagine 2 di 2
    • Lift the upper right cellular antenna cable out of its socket on the logic board.
    • Be careful not to pry on the socket, only on the connector.
  31. iPad mini 4 LTE Right Cellular Antenna Replacement: passo 31, immagine 1 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 31, immagine 2 di 3 iPad mini 4 LTE Right Cellular Antenna Replacement: passo 31, immagine 3 di 3
    • Push the connector side of the antenna up and remove it from the iPad.
Conclusione
Altre 2 persone hanno completato questa guida.
Evan Noronha
Membro da: 02/05/15
226.175 Reputazione
168 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 3,215
