Salta al contenuto principale
Introduzione
Follow the steps in this guide to replace the headphone jack in your iPad mini 4 LTE.
Parts of this guide were shot with a Wi-Fi model and as such the internals may look slightly different from the LTE model. The procedure is the same for both models except where noted.
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered. For particularly bad breaks, you may need to lay down two layers.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Protect your eyes! This procedure will cause small pieces of glass to fly directly toward your face. Do not attempt without safety glasses.
  1. We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener. Place the iOpener in the center of the microwave.
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. Heat the iOpener for thirty seconds.
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. Handling it by the tabs on either side, place the heated iOpener on the side of the iPad to the left of the home button assembly.
    • Handling it by the tabs on either side, place the heated iOpener on the side of the iPad to the left of the home button assembly.
    • Let the iOpener sit for about five minutes to soften the adhesive beneath the glass.
  5. Carefully place a suction cup halfway up the heated side. Be sure the cup is completely flat on the screen to get a tight seal. While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel assembly from from the rear case.
    • Carefully place a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel assembly from from the rear case.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
  6. While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad. Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
    • While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
  7. Reheat and reapply the iOpener.
    • Reheat and reapply the iOpener.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
    • Let it rest for a few minutes to reheat the left edge of the iPad.
  8. Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go. Throughout the rest of the procedure, if you encounter significant resistance to sliding picks beneath the glass, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass. Throughout the rest of the procedure, if you encounter significant resistance to sliding picks beneath the glass, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
    • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance to sliding picks beneath the glass, stop and reheat the section you're working on. Applying too much pressure with the pick can crack the glass.
  9. Continue moving the opening pick down the side of the display to release the adhesive. If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive. If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  10. Take the first pick you inserted and slide it up toward the top corner of the iPad. Take the first pick you inserted and slide it up toward the top corner of the iPad.
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
  11. Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  12. Slide the opening pick around the top left corner of the iPad to separate the adhesive. Slide the opening pick around the top left corner of the iPad to separate the adhesive. Slide the opening pick around the top left corner of the iPad to separate the adhesive.
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  13. Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera. As you reach the front-facing camera, pull the pick out slightly and continue sliding it across the top edge. Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • As you reach the front-facing camera, pull the pick out slightly and continue sliding it across the top edge.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  14. Leave the opening pick in the iPad slightly past the front-facing camera. Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive. Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
  15. Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner. Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  16. Kit di riparazione batterie iPhone
    Solo $29.99
    Buy Now
    Solo $29.99
    Buy Now
  17. Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
  18. Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go. Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go. Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go.
    • Insert a new opening pick and slide it down the right edge of the iPad, releasing the adhesive as you go.
  19. Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary. Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary. Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary.
    • Continue sliding the opening pick down the right edge of the iPad, reheating the edge using an iOpener if necessary.
  20. Leave the opening picks in place and reheat the iOpener.
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
  21. Insert a new opening pick at the bottom right corner of the display, below the last opening pick you used to slice down the right edge. Rotate the new pick around the lower right corner of the device. Rotate the new pick around the lower right corner of the device.
    • Insert a new opening pick at the bottom right corner of the display, below the last opening pick you used to slice down the right edge.
    • Rotate the new pick around the lower right corner of the device.
  22. Slide the pick from the bottom right corner along the lower edge of the device. Stop about half an inch shy of the home button. Slide the pick from the bottom right corner along the lower edge of the device. Stop about half an inch shy of the home button.
    • Slide the pick from the bottom right corner along the lower edge of the device. Stop about half an inch shy of the home button.
  23. Insert a final opening pick at the lower left corner of the iPad, directly below the existing one. Insert a final opening pick at the lower left corner of the iPad, directly below the existing one.
    • Insert a final opening pick at the lower left corner of the iPad, directly below the existing one.
  24. Slide the pick around the lower left edge of the iPad. Slide the pick around the lower left edge of the iPad.
    • Slide the pick around the lower left edge of the iPad.
  25. Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button. Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button. Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button.
    • Continue sliding the pick at the lower left edge of the display toward the center of the iPad, until it is roughly half an inch from the home button.
  26. Twist the two picks at the top edge of the iPad to break up the last of the adhesive holding the display assembly in place. Lift the display from the top edge to open the device. Lift the display from the top edge to open the device.
    • Twist the two picks at the top edge of the iPad to break up the last of the adhesive holding the display assembly in place.
    • Lift the display from the top edge to open the device.
  27. To avoid stressing any cables, hold the display assembly perpendicular to the body of the iPad until it is disconnected.
    • To avoid stressing any cables, hold the display assembly perpendicular to the body of the iPad until it is disconnected.
    • Remove the four 1.2 mm Phillips screws over the battery/display connector bracket.
  28. Remove the battery/display cable bracket.
    • Remove the battery/display cable bracket.
  29. When disconnecting any press connectors from the logic board, be sure to lift the connector straight up to avoid ripping the socket off the board. Use the flat tip of a spudger to disconnect the battery connector from its socket on the logic board.
    • When disconnecting any press connectors from the logic board, be sure to lift the connector straight up to avoid ripping the socket off the board.
    • Use the flat tip of a spudger to disconnect the battery connector from its socket on the logic board.
    • Bend the battery connector ribbon cable up slightly to prevent it from making contact and powering on the iPad.
  30. Use the pointed end of a spudger to disconnect the display data connector from its socket on the logic board. Use the pointed end of a spudger to disconnect the digitizer cable connector from its socket on the logic board. When reconnecting these, press down from one end of the connector to the other. If you press in the middle of the connector, you may bend it, causing damage or a poor connection.
    • Use the pointed end of a spudger to disconnect the display data connector from its socket on the logic board.
    • Use the pointed end of a spudger to disconnect the digitizer cable connector from its socket on the logic board.
    • When reconnecting these, press down from one end of the connector to the other. If you press in the middle of the connector, you may bend it, causing damage or a poor connection.
  31. Remove the display assembly.
    • Remove the display assembly.
  32. Run the pointed end of a spudger between the looped tape and the plastic cellular antenna housing to make it easier to peel the tape up. Run the pointed end of a spudger between the looped tape and the plastic cellular antenna housing to make it easier to peel the tape up.
    • Run the pointed end of a spudger between the looped tape and the plastic cellular antenna housing to make it easier to peel the tape up.
  33. Use tweezers to peel up the looped tape adhered over the upper component cable bracket. Use tweezers to peel up the looped tape adhered over the upper component cable bracket. Use tweezers to peel up the looped tape adhered over the upper component cable bracket.
    • Use tweezers to peel up the looped tape adhered over the upper component cable bracket.
  34. Remove the following four Phillips screws holding the upper component bracket in place:
    • Remove the following four Phillips screws holding the upper component bracket in place:
    • Two 2.1 mm screws
    • Two 1.2 mm screws
  35. Remove the upper component cable bracket.
    • Remove the upper component cable bracket.
  36. Use tweezers to remove the small piece of tape covering the the left antenna ribbon cable ZIF connector. Use tweezers to remove the small piece of tape covering the the left antenna ribbon cable ZIF connector.
    • Use tweezers to remove the small piece of tape covering the the left antenna ribbon cable ZIF connector.
  37. Use the flat end of a spudger to flip up the retaining flap on the left antenna ribbon cable ZIF connector. Use the flat end of a spudger to flip up the retaining flap on the left antenna ribbon cable ZIF connector.
    • Use the flat end of a spudger to flip up the retaining flap on the left antenna ribbon cable ZIF connector.
  38. Use tweezers to pull the antenna ribbon cable from its ZIF socket on the headphone jack ribbon cable. Use tweezers to pull the antenna ribbon cable from its ZIF socket on the headphone jack ribbon cable.
    • Use tweezers to pull the antenna ribbon cable from its ZIF socket on the headphone jack ribbon cable.
  39. Peel up the tape over the front camera ribbon cable. Peel up the tape over the front camera ribbon cable.
    • Peel up the tape over the front camera ribbon cable.
  40. Use the flat end of a spudger to disconnect the front camera press connector from its socket on the logic board. Use the flat end of a spudger to disconnect the front camera press connector from its socket on the logic board. Use the flat end of a spudger to disconnect the front camera press connector from its socket on the logic board.
    • Use the flat end of a spudger to disconnect the front camera press connector from its socket on the logic board.
  41. Use the flat end of a spudger to lift the headphone jack cable connector from its socket on the logic board. Use the flat end of a spudger to lift the headphone jack cable connector from its socket on the logic board.
    • Use the flat end of a spudger to lift the headphone jack cable connector from its socket on the logic board.
  42. Slide the flat end of a spudger under the headphone jack ribbon cable to separate it from the adhesive holding it to the rear case. Slide the flat end of a spudger under the headphone jack ribbon cable to separate it from the adhesive holding it to the rear case. Slide the flat end of a spudger under the headphone jack ribbon cable to separate it from the adhesive holding it to the rear case.
    • Slide the flat end of a spudger under the headphone jack ribbon cable to separate it from the adhesive holding it to the rear case.
  43. Remove the two 1.5 mm Phillips screws securing the headphone jack bracket.
    • Remove the two 1.5 mm Phillips screws securing the headphone jack bracket.
  44. Remove the headphone jack bracket. Remove the headphone jack bracket.
    • Remove the headphone jack bracket.
  45. Remove the final 2.6 mm Phillips screw securing the headphone jack to the rear case.
    • Remove the final 2.6 mm Phillips screw securing the headphone jack to the rear case.
  46. Remove the headphone jack from the iPad. Remove the headphone jack from the iPad.
    • Remove the headphone jack from the iPad.
Conclusione
Altre 2 persone hanno completato questa guida.
Evan Noronha
Membro da: 05/02/2015
166.172 Reputazione
177 Guide realizzate
iFixit Membro di iFixit
Community
101 Membri
8.699 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,241
