Did you follow all the steps? Yes! Then enjoy!
Altre 12 persone hanno completato questa guida.
3 Commenti
If you get the replacement screen with daughterboard attached you don’t need to solder anything.
That is correct …. but if you solder it on yourself you reuse the original daughter board instead of throwing it away and save some money to boot. Seems reasonable if you can do it.
