Salta al contenuto principale
iPad Mini Home button Replacement
Cosa ti serve
  1. iPad Mini Home button Replacement, Reveal solder pads: passo 1, immagine 1 di 1
    • Use heat to losen the adhesive. A low temp hot air gun will suffice.
    • After heating up the adhesive, you can use a basic spudger to pry off the flex from the glass
    • be sure not to use too much force, this flex is very fragile.
    Chiedi a FixBot
    Aggiungi Commento
  2. iPad Mini Home button Replacement, Apply your own solder: passo 2, immagine 1 di 1
    • use your iron, and low guage solder to apply a layer of your own solder on the pads
    • the new solder will allow for faster, and more controlled heat transfer.
    Chiedi a FixBot
    Aggiungi Commento
  3. iPad Mini Home button Replacement, Remove the flex: passo 3, immagine 1 di 1
    • a few back and forth strokes of your soldering iron should be enough to remove the flex cable.
    • be sure not to apply too much force with the iron, as you can cause physical damage to the pads.
    • Using a little bit of solder flux, can help decrease the amount of pressure needed to properly transfer the heat.
    Chiedi a FixBot
    Aggiungi Commento
  4. iPad Mini Home button Replacement, Line up the pads: passo 4, immagine 1 di 1
    • be sure to make sure you can see directly through the holes marked on both sides.
    • Line the corrisponding holes up, and make sure they are 100% overlapped.
    • failing to properly line up the holes can cause a short, or cold circuit.
    Chiedi a FixBot
    Aggiungi Commento
  5. iPad Mini Home button Replacement, Re-Solder: passo 5, immagine 1 di 1
    • Use the new solder you added, to connect to the flex.
    • be sure to cover the traces with some electrical tape to avoid shorts.
    • congratulations on your home button replacement
    Chiedi a FixBot
    Aggiungi Commento
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Scott
Membro da: 10/09/13
9.925 Reputazione
4 guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 16
Ultimi 30 giorni: 78
Tutti i Tempi: 13,078
