Introduzione
Prereq only, does not remove antenna, battery is in.
Cosa ti serve
Remove the following three screws securing the bottom left antenna to the rear case:
One 1.2 mm Phillips #00
One 1.1 mm Phillips #00
One 2.5 mm Phillips #00
Pull the wide tape toward the top of the iPad, applying constant force to release it from the antenna cable between it and the speaker.
Slide the tip of a spudger through the gap between the wide tape and the antenna cable, to break the adhesive connecting the two.
Continue pulling the wide tape until it is no longer covering the antenna cable.
Slide the tip of a spudger through the gap between the wide tape and the antenna cable, to release the adhesive connecting the two.
