Salta al contenuto principale
iPad Mini CDMA Wi-Fi/Bluetooth Antenna Replacement
Solo Prerequisita
Questa guida รจ destinata a essere usata solo come prerequisito per altre guide. Da sola รจ incompleta.
Cosa ti serve
  1. iPad Mini CDMA Wi-Fi/Bluetooth Antenna Replacement, Wi-Fi/Bluetooth Antenna: passo 1, immagine 1 di 3 iPad Mini CDMA Wi-Fi/Bluetooth Antenna Replacement, Wi-Fi/Bluetooth Antenna: passo 1, immagine 2 di 3 iPad Mini CDMA Wi-Fi/Bluetooth Antenna Replacement, Wi-Fi/Bluetooth Antenna: passo 1, immagine 3 di 3
    • Pull the wide tape toward the top of the iPad, applying constant force to release it from the antenna cable between it and the speaker.
    • Slide the tip of a spudger through the gap between the wide tape and the antenna cable, breaking the adhesive connecting the two.
    • Continue pulling the wide tape until it is no longer covering the antenna cable.
  2. iPad Mini CDMA Wi-Fi/Bluetooth Antenna Replacement: passo 2, immagine 1 di 3 iPad Mini CDMA Wi-Fi/Bluetooth Antenna Replacement: passo 2, immagine 2 di 3 iPad Mini CDMA Wi-Fi/Bluetooth Antenna Replacement: passo 2, immagine 3 di 3
    • Peel back and remove the wide tape from the iPad.
  3. iPad Mini CDMA Wi-Fi/Bluetooth Antenna Replacement: passo 3, immagine 1 di 3 iPad Mini CDMA Wi-Fi/Bluetooth Antenna Replacement: passo 3, immagine 2 di 3 iPad Mini CDMA Wi-Fi/Bluetooth Antenna Replacement: passo 3, immagine 3 di 3
    • Use the tip of a spudger to pry the antenna cable tape up from the rear case of the iPad.
    • Gently pull the antenna cable out of the way as you work along the piece of tape, to keep it from resealing.
  4. iPad Mini CDMA Wi-Fi/Bluetooth Antenna Replacement: passo 4, immagine 1 di 1
    • Remove the following three screws securing the bottom left antenna to the rear case:
    • One 1.2 mm Phillips #00 screw.
    • One 1.1 mm Phillips #00 screw.
    • One 2.5 mm Phillips #00 screw.
  5. iPad Mini CDMA Wi-Fi/Bluetooth Antenna Replacement: passo 5, immagine 1 di 2 iPad Mini CDMA Wi-Fi/Bluetooth Antenna Replacement: passo 5, immagine 2 di 2
    • Use the flat end of a spudger to loosen the foam adhesive securing the lower left antenna to the left speaker.
  6. iPad Mini CDMA Wi-Fi/Bluetooth Antenna Replacement: passo 6, immagine 1 di 1
    • Remove the antenna from the iPad.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 4
Tutti i Tempi: 85
