Salta al contenuto principale
iPad Mini CDMA Battery Connector Replacement
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. iPad Mini CDMA Battery Connector Replacement, Battery Connector: passo 1, immagine 1 di 1
    • Remove the three 1.3 mm Phillips #00 screws securing the connector shield to the logic board.
    • Be sure to not substitute these three screws with any other screws, specifically the screws securing the LCD shield plate to the rear case of the iPad. Any slightly longer screws may strip the screw holes and result in irreparable damage to the logic board.
  2. iPad Mini CDMA Battery Connector Replacement: passo 2, immagine 1 di 1
    • Use a pair of tweezers to grasp and remove the connector shield from the iPad.
  3. iPad Mini CDMA Battery Connector Replacement: passo 3, immagine 1 di 2 iPad Mini CDMA Battery Connector Replacement: passo 3, immagine 2 di 2
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not on the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
Conclusione
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 500
