Salta al contenuto principale
Cosa ti serve
Questo smontaggio non è una guida di riparazione. Per riparare il tuo iPad ClamCase, usa il nostro manuale di assistenza.
  1. iPad ClamCase, iPad ClamCase: passo 1, immagine 1 di 2 iPad ClamCase, iPad ClamCase: passo 1, immagine 2 di 2
    • You can skip the first 2 steps if you don't want to detach the upper and keyboard covers from each other.
    • Open the case and unpeel the 2 black stickers in the top corners of the keyboard.
    • This will reveal the 6 screws that attach the upper cover to the keyboard cover.
  2. iPad ClamCase: passo 2, immagine 1 di 2 iPad ClamCase: passo 2, immagine 2 di 2
    • Use the T9 Torx screwdriver to unscrew the 2 bigger screws in the middle of each side.
    • Use the T6 Torx screwdriver to unscrew the remaining 4 screws.
  3. iPad ClamCase: passo 3, immagine 1 di 2 iPad ClamCase: passo 3, immagine 2 di 2
    • Turn the keyboard cover over so the bottom is facing up. Manually remove the thin black covering that is attached to the bottom.
    • Be patient, the thin black covering might be really stuck to the bottom.
  4. iPad ClamCase: passo 4, immagine 1 di 1
    • Once the thin black covering is removed, you will see 15 screws.
    • Use the T6 Torx screwdriver to remove the screws.
  5. iPad ClamCase: passo 5, immagine 1 di 1
    • Once the screws are removed, lift off the bottom panel to access the keyboard and battery.
  6. iPad ClamCase: passo 6, immagine 1 di 1
    • You are done.
2 Commenti
Awesome! I used this guide to disassemble my clam case and repair some nonfunctional keys. Thanks!
justin duff - Replica
Thanks for the dis-assembly guide. Justin, what did you have to do to fix the keys that were not working. I have on with a few keys not working, not even intermittently.
dick haynes - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 20
Tutti i Tempi: 7,743
