Introduzione
Use this guide to replace a set of blown-out speakers.
Cosa ti serve
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass.
Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
Remove the two 4.56 mm T5 Torx screws securing the dock connector cable to the main board.
Use the edge of an iPod opening tool to pry the SIM board connector up off it socket on the logic board.
Altre 7 persone hanno completato questa guida.
