Introduzione
Use this guide to replace a set of blown-out speakers.
  1. If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered. This will keep glass shards contained and provide structural integrity when prying and lifting the display.
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. The iPad shown in the photos may look slightly different from your iPad, but the procedure is the same. Insert a metal spudger between the right edge of the display assembly and the rear panel assembly.
    • The iPad shown in the photos may look slightly different from your iPad, but the procedure is the same.
    • Insert a metal spudger between the right edge of the display assembly and the rear panel assembly.
    • Rotate the spudger away from you to release the tabs along the top edge of the display.
  3. Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place. Pry the display assembly away from the rear panel.
    • Insert a second metal spudger between the top edge of the display assembly and the rear panel assembly to keep the tabs from snapping back into place.
    • Pry the display assembly away from the rear panel.
  4. Continue prying the display assembly away from the rear panel along the bottom and left edges of the iPad. Use extreme caution as you approach the top edge of the iPad. The digitizer ribbon cable is located near the edge of the rear panel and can easily be damaged.
    • Continue prying the display assembly away from the rear panel along the bottom and left edges of the iPad.
    • Use extreme caution as you approach the top edge of the iPad. The digitizer ribbon cable is located near the edge of the rear panel and can easily be damaged.
  5. Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Lift the display assembly away from the rear panel assembly by its bottom edge.
    • Do not excessively lift the display assembly off the rest of the iPad, as a fragile antenna cable with very little slack still connects the two components.
  6. Use the flat end of a spudger to pry the antenna connector closest to the bottom of the iPad up off its socket on the communications board.
    • Use the flat end of a spudger to pry the antenna connector closest to the bottom of the iPad up off its socket on the communications board.
  7. In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • In the following steps, you will disconnect the three cables attaching the display assembly to the logic board. The cables are for the following components:
    • Digitizer
    • Ambient Light Sensor
    • Display Data Cable
  8. Use the edge of an iPod opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board. Be sure you are flipping up the retaining flap, not the socket itself. Pull the digitizer ribbon cables straight out of their sockets.
    • Use the edge of an iPod opening tool to flip up the retaining flaps holding the digitizer ribbon cables in their sockets on the logic board.
    • Be sure you are flipping up the retaining flap, not the socket itself.
    • Pull the digitizer ribbon cables straight out of their sockets.
  9. Kit di riparazione per Android
    Un nuovo schermo o una nuova batteria sono ad un kit di distanza.
    Acquista ora
    Acquista ora
  10. Use an iPod opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
    • Use an iPod opening tool to remove the ambient light sensor connector from its socket by gently prying upward.
  11. Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab. Pull the cable connector away from its socket.
    • Disconnect the display data cable from the main board by flipping up the metal retainer by its black plastic pull tab.
    • Pull the cable connector away from its socket.
    • Pull the connector parallel to the face of the logic board.
  12. Remove the display assembly from the rear panel assembly.
    • Remove the display assembly from the rear panel assembly.
  13. Remove the two 4.56 mm T5 Torx screws securing the dock connector cable to the main board.
    • Remove the two 4.56 mm T5 Torx screws securing the dock connector cable to the main board.
  14. Remove the single 2.84 mm T5 Torx screw connecting the dock connector cable to the rear case assembly.
    • Remove the single 2.84 mm T5 Torx screw connecting the dock connector cable to the rear case assembly.
  15. Remove the two 2.84 mm T5 Torx screws securing the dock connector cable to the rear panel assembly.
    • Remove the two 2.84 mm T5 Torx screws securing the dock connector cable to the rear panel assembly.
  16. Carefully remove the plastic cover over the WiFi/Bluetooth board and dock connector cable using an iPod opening tool.
    • Carefully remove the plastic cover over the WiFi/Bluetooth board and dock connector cable using an iPod opening tool.
  17. Pry the Wi-Fi and Bluetooth antennas up off their respective sockets on the Wi-Fi/Bluetooth board.
    • Pry the Wi-Fi and Bluetooth antennas up off their respective sockets on the Wi-Fi/Bluetooth board.
  18. Remove the dock connector cable from the rear panel assembly.
    • Remove the dock connector cable from the rear panel assembly.
  19. Use the edge of an iPod opening tool to pry the SIM board connector up off it socket on the logic board.
    • Use the edge of an iPod opening tool to pry the SIM board connector up off it socket on the logic board.
  20. Fold the SIM cable back for clearance to access the speaker connector.
    • Fold the SIM cable back for clearance to access the speaker connector.
    • Use the edge of an iPod opening tool to disconnect the speaker connector from the logic board.
    • Pry up from beneath the wires.
  21. Remove the two 2.84 mm T5 Torx screws securing the speaker assembly to the rear panel assembly.
    • Remove the two 2.84 mm T5 Torx screws securing the speaker assembly to the rear panel assembly.
    • If necessary, remove the tape covering the Wi-Fi cables.
  22. De-route the Wi-Fi antenna through its channel in the speaker assembly.
    • De-route the Wi-Fi antenna through its channel in the speaker assembly.
  23. Deroute the speaker cable connector from under the black sticker attached to the left side of the rear panel assembly.
    • Deroute the speaker cable connector from under the black sticker attached to the left side of the rear panel assembly.
  24. Lift the speaker assembly and push it forward until the ports clear the bottom side of the rear panel assembly.
    • Lift the speaker assembly and push it forward until the ports clear the bottom side of the rear panel assembly.
Conclusione
Altre 6 persone hanno completato questa guida.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 15,397
