Salta al contenuto principale
iPad 2 GSM Headphone Jack & SIM Slot Replacement
Cosa ti serve
  1. iPad 2 GSM Headphone Jack & SIM Slot Replacement, iOpener Heating: passo 1, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement, iOpener Heating: passo 1, immagine 2 di 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    Chiedi a FixBot
    Aggiungi Commento
  2. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 2, immagine 1 di 1
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    Chiedi a FixBot
    Aggiungi Commento
  3. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 3, immagine 1 di 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    Chiedi a FixBot
    Aggiungi Commento
  4. iPad 2 GSM Headphone Jack & SIM Slot Replacement, Alternate iOpener heating method: passo 4, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement, Alternate iOpener heating method: passo 4, immagine 2 di 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
    Chiedi a FixBot
    Aggiungi Commento
  5. iPad 2 GSM Headphone Jack & SIM Slot Replacement, SIM Card: passo 5, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement, SIM Card: passo 5, immagine 2 di 2
    • Use a SIM eject tool or an uncoiled paperclip to eject the SIM card tray.
    Chiedi a FixBot
    Aggiungi Commento
  6. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 6, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 6, immagine 2 di 2
    • Pull the SIM tray out of its slot and remove it from the iPad 2.
    • If replacing the SIM card, pop it out of its tray and install the new one.
    Chiedi a FixBot
    Aggiungi Commento
  7. iPad 2 GSM Headphone Jack & SIM Slot Replacement, Front Panel: passo 7, immagine 1 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement, Front Panel: passo 7, immagine 2 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement, Front Panel: passo 7, immagine 3 di 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
    Chiedi a FixBot
    Aggiungi Commento
  8. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 8, immagine 1 di 1
    • Again, as you may find yourself working with broken glass during this procedure, we strongly recommend wearing safety glasses for protection from flying shards.
    • Lay the iOpener flat on the right edge of the iPad, smoothing it out so that there is good contact between the surface of the iPad and the iOpener.
    • Let the bag sit on the iPad for approximately 90 seconds before attempting to open the front panel.
    Chiedi a FixBot
    Aggiungi Commento
  9. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 9, immagine 1 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 9, immagine 2 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 9, immagine 3 di 3
    • There is a small gap in the iPad's adhesive ring in the upper right corner of the iPad, approximately 2.0 inches (~5 cm) from the top of the iPad. You are going to exploit this weakness.
    • Align the tool with the mute button. Insert the tip of a plastic opening tool into the gap between the front glass and the plastic bezel. Just insert the very tip of the opening tool, just enough to widen the crack.
    • It may require some force to get the wedged tip of the opening tool between the glass and plastic. Work patiently and carefully, wiggling the plastic opening tool back and forth as necessary.
    Chiedi a FixBot
    Aggiungi Commento
  10. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 10, immagine 1 di 1
    • Make sure you place the tool in the proper spot—between the plastic display bezel and the front panel glass.
    Chiedi a FixBot
    Aggiungi Commento
  11. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 11, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 11, immagine 2 di 2
    • Keeping the tip of the plastic opening tool wedged between the front glass and plastic bezel, slide a plastic opening pick in the gap, right next to the plastic opening tool.
    Chiedi a FixBot
    Aggiungi Commento
  12. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 12, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 12, immagine 2 di 2
    • Remove the plastic opening tool from the iPad, and push the opening pick further underneath the front glass to a depth of ~0.5 inches.
    Chiedi a FixBot
    Aggiungi Commento
  13. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 13, immagine 1 di 1
    • While you work on releasing the adhesive on the right side of the iPad, reheat the iOpener, and replace it on the bottom edge of the iPad.
    Chiedi a FixBot
    Aggiungi Commento
  14. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 14, immagine 1 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 14, immagine 2 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 14, immagine 3 di 3
    • While the bottom edge is being heated by the iOpener, begin releasing the adhesive from the right edge of the iPad.
    • Slide the opening pick down along the edge of the iPad, releasing the adhesive as you go.
    • The adhesive is very strong, and some serious force may be required. Work carefully.
    • If you can see the tip of the opening pick underneath the front glass, pull the pick out just a little bit. While using the opening pick this deep won't damage anything, it may get adhesive residue all over the LCD.
    Chiedi a FixBot
    Aggiungi Commento
  15. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 15, immagine 1 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 15, immagine 2 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 15, immagine 3 di 3
    • It may be necessary to move the heated iOpener back onto the right edge of the iPad as you release the adhesive. This depends on how long the iPad has been able to cool while you were working on it.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  16. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 16, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 16, immagine 2 di 2
    • Before removing the first opening pick from the bottom corner of the iPad, insert a second pick under the right edge of the front glass to keep the adhesive from re-adhering.
    • Re-heat the iOpener, and move it to the top edge of the iPad.
    Chiedi a FixBot
    Aggiungi Commento
  17. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 17, immagine 1 di 1
    • The next few steps require extreme caution.
    • The Wi-Fi antenna is attached to the bottom right edge of the rear case of the iPad via screws and a cable. Because of the orientation of the Wi-Fi antenna, it is imperative to proceed with caution otherwise irreversible damage to the Wi-Fi antenna may result.
    • You will have to release the adhesive securing the antenna to the front panel without damaging the delicate parts attaching the antenna to the bottom of the iPad. Follow the next steps carefully.
    Chiedi a FixBot
    Aggiungi Commento
  18. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 18, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 18, immagine 2 di 2
    • Slide the opening pick around the bottom right corner of the iPad, releasing the adhesive there.
    • Do not slide the pick further than the bottom right corner. You may damage the Wi-Fi antenna by doing so.
    Chiedi a FixBot
    Aggiungi Commento
  19. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 19, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 19, immagine 2 di 2
    • This step requires you to move the opening pick along the bottom right edge of the front panel. The Wi-Fi antenna is very close to the corner and is easily severed if the adhesive is released improperly.
    • Do not completely remove the pick from under the front glass, but pull it out just a little bit so that ~1/8" (3 mm) of the tip is still under the front glass.
    • Slide the tip of the opening pick along the bottom edge of the iPad, releasing the adhesive over the Wi-Fi antenna.
    Chiedi a FixBot
    Aggiungi Commento
  20. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 20, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 20, immagine 2 di 2
    • Once you have moved past the Wi-FI antenna (approximately 3" (75 mm) from the right edge, or right next to the home button) re-insert the opening pick to its full depth.
    • Slide the pick to the right, releasing the adhesive securing the Wi-Fi antenna to the front glass.
    • The antenna is attached to the bottom of the iPad via screws and a cable. This step detaches the antenna from the front panel, ensuring that when you remove the panel, the antenna will not be damaged.
    Chiedi a FixBot
    Aggiungi Commento
  21. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 21, immagine 1 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 21, immagine 2 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 21, immagine 3 di 3
    • Continue releasing the adhesive along the bottom of the iPad, pulling the opening pick out far enough to go around the home button, and re-inserting it to a depth of 1/2 inch (10 mm) once the pick is past the home button.
    • If the adhesive has cooled too much along the bottom edge, reheat the iOpener to warm the adhesive where you are working.
    • Do not heat the iOpener more than a minute at a time, and always allow at least two minutes before reheating it.
    Chiedi a FixBot
    Aggiungi Commento
  22. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 22, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 22, immagine 2 di 2
    • Continue releasing the adhesive all the way along the bottom edge of the iPad.
    • On iPad 4 models, insert the pick to a maximum depth of 1/2 inch (10 mm) in this area, to avoid damaging the home button ribbon cable.
    • Leave the opening pick wedged underneath the front glass near the home button.
    Chiedi a FixBot
    Aggiungi Commento
  23. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 23, immagine 1 di 1
    • Reheat the iOpener in the microwave and set it on the left edge of the iPad to start warming the adhesive in that section.
    Chiedi a FixBot
    Aggiungi Commento
  24. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 24, immagine 1 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 24, immagine 2 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 24, immagine 3 di 3
    • Slide the opening pick along the top edge of the iPad, pulling it out slightly to go around the front-facing camera bracket.
    • The adhesive along this section is very thick, and a fair amount of force may be required. Work carefully and slowly, making sure to not slip and damage yourself or your iPad.
    • If the adhesive has cooled too much, replace the iOpener along the top edge and continue working. If the iOpener has cooled too much, reheat it.
    • If the opening pick is getting stuck in the adhesive, "roll" the pick as shown in step 9.
    Chiedi a FixBot
    Aggiungi Commento
  25. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 25, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 25, immagine 2 di 2
    • Continue releasing the adhesive along the top edge of the iPad, and slide the opening pick around the top left corner.
    • If the adhesive is warm enough, remove the iOpener from the iPad for convenience. However, if the adhesive is still quite sticky, re-heat the iOpener and lay it on the left edge while you work.
    Chiedi a FixBot
    Aggiungi Commento
  26. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 26, immagine 1 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 26, immagine 2 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 26, immagine 3 di 3
    • Slide the opening pick along the left edge of the iPad, releasing the adhesive as you go. The adhesive is thin here due to the digitizer along the whole left side. Make sure the pick is not too deep (max 1/2 inch) 10 mm to prevent damaging the digitizer.
    • The digitizer cable is located approximately 2" (50 mm) from the bottom of the iPad. Stop sliding the pick when you get ~2.25" (60 mm) from the bottom of the iPad.
    Chiedi a FixBot
    Aggiungi Commento
  27. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 27, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 27, immagine 2 di 2
    • Using the opening pick that is still underneath the bottom edge of the iPad, release the adhesive along the bottom left corner.
    • The bottom of the digitizer cable is only ~1" (25 mm) from the bottom of the iPad. Work carefully and slowly, making sure to not sever this cable.
    Chiedi a FixBot
    Aggiungi Commento
  28. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 28, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 28, immagine 2 di 2
    • Using one of the opening picks, pry up the bottom right corner of the iPad and grab it with your fingers.
    • Some of the adhesive along the perimeter of the iPad may have stuck back down again. If this is the case, slide a pick underneath the edge of the iPad where the front glass is still stuck and "cut" the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  29. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 29, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 29, immagine 2 di 2
    Strumento utilizzato in questo passaggio:
    Microfiber Cleaning Cloths
    $3.99
    • Holding the iPad by the top and bottom right corners, rotate the front glass away from the iPad.
    • Be careful of any adhesive that may still be attached, and use an opening pick to cut any adhesive that may still be holding the front panel down.
    • During reassembly use a microfiber cloth and compressed air to clean any dust or fingerprints off the LCD before reinstalling the glass.
    Chiedi a FixBot
    Aggiungi Commento
  30. iPad 2 GSM Headphone Jack & SIM Slot Replacement, LCD: passo 30, immagine 1 di 1
    • Remove the four 2.0 mm Phillips screws securing the LCD to the rear case.
    Chiedi a FixBot
    Aggiungi Commento
  31. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 31, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 31, immagine 2 di 2
    • Lift the LCD from its long edge closest to the volume buttons and rotate it out of the rear case.
    • Lay the LCD on the front panel as seen in the second picture.
    Chiedi a FixBot
    Aggiungi Commento
  32. iPad 2 GSM Headphone Jack & SIM Slot Replacement, Headphone Jack Assembly: passo 32, immagine 1 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement, Headphone Jack Assembly: passo 32, immagine 2 di 3 iPad 2 GSM Headphone Jack & SIM Slot Replacement, Headphone Jack Assembly: passo 32, immagine 3 di 3
    • Use the flat end of a plastic opening tool to flip up the retaining flap on the headphone jack and front-facing camera ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Run a plastic opening tool underneath the headphone jack and front-facing camera cable to free it from the adhesive attaching the cable to the rear panel.
    • Pull the headphone jack and front-facing camera ribbon cable straight out of its socket on the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  33. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 33, immagine 1 di 1
    • Remove the three 2 mm Phillips screws securing the SIM slot to the rear panel.
    Chiedi a FixBot
    Aggiungi Commento
  34. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 34, immagine 1 di 1
    • Remove the two 2.9 mm Phillips screws securing the headphone jack to the rear panel.
    Chiedi a FixBot
    Aggiungi Commento
  35. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 35, immagine 1 di 1
    • Use a plastic opening tool to help pull the headphone jack away from its recess in the top edge of the iPad.
    • Don't try to remove the assembly just yet.
    Chiedi a FixBot
    Aggiungi Commento
  36. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 36, immagine 1 di 1
    • Carefully peel the front camera and microphone cables off the rear panel.
    Chiedi a FixBot
    Aggiungi Commento
  37. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 37, immagine 1 di 2 iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 37, immagine 2 di 2
    • Carefully remove the strip of tape covering the front camera cable connector.
    • Use the edge of a plastic opening tool to disconnect the front camera cable from the headphone jack cable.
    Chiedi a FixBot
    Aggiungi Commento
  38. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 38, immagine 1 di 1
    • Carefully peel the front camera cable off the bottom ribbon cable attached to the headphone jack.
    Chiedi a FixBot
    Aggiungi Commento
  39. iPad 2 GSM Headphone Jack & SIM Slot Replacement, Headphone Jack & SIM Slot: passo 39, immagine 1 di 1
    • Use the edge of a plastic opening tool to disconnect the microphone cable connector.
    Chiedi a FixBot
    Aggiungi Commento
  40. iPad 2 GSM Headphone Jack & SIM Slot Replacement: passo 40, immagine 1 di 1
    • Remove the headphone jack/SIM slot from the iPad 2.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow these directions in reverse and use our iPad 2 GSM Front Panel Adhesive strips guide to reattach the front panel.
Altre 23 persone hanno completato questa guida.
1Commento della guida
Hello, Walter:
I have a iPad2 which the sim card was stuck in the sim card try with iPad2 ….
Could I use this “iPad 2 GSM Headphone Jack & SIM Slot Replacement” procedures to take out the stuck sim card?
Thanks in advance.
D.D.
davidduann - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 15
Ultimi 30 giorni: 88
Tutti i Tempi: 28,369
