Salta al contenuto principale
iON SnapCam 1046 Lite Camera Micro USB Replacement
Cosa ti serve
  1. iON SnapCam 1046 Lite Camera  Micro USB  Replacement, Camera Lens and Cover: passo 1, immagine 1 di 2 iON SnapCam 1046 Lite Camera  Micro USB  Replacement, Camera Lens and Cover: passo 1, immagine 2 di 2
    • Remove any external skins placed on the device. To do so, simply lift up and peel to remove.
  2. iON SnapCam 1046 Lite Camera  Micro USB  Replacement: passo 2, immagine 1 di 1
    • Firmly pull on the back clip in order to remove.
  3. iON SnapCam 1046 Lite Camera  Micro USB  Replacement: passo 3, immagine 1 di 1
    • Use a Phillips head screwdriver to remove the four 4mm PH00 screws located on the sides of the device. All screws are located under each of the grey covers for the microSD card and the microUSB insert.
  4. iON SnapCam 1046 Lite Camera  Micro USB  Replacement: passo 4, immagine 1 di 3 iON SnapCam 1046 Lite Camera  Micro USB  Replacement: passo 4, immagine 2 di 3 iON SnapCam 1046 Lite Camera  Micro USB  Replacement: passo 4, immagine 3 di 3
    • Grab a metal or plastic opening tool and insert it into the middle slot on the bottom of the camera and lightly pry open.
    • Locate the camera lens in the bottom left-hand corner of the picture which can be replaced by replacing the entire cover. The back of the cover is also shown. The camera is now located in the top right-hand corner of the picture.
  5. iON SnapCam 1046 Lite Camera  Micro USB  Replacement, Micro USB: passo 5, immagine 1 di 1
    • Using the nylon spudger, pop up the edges of the motherboard.
  6. iON SnapCam 1046 Lite Camera  Micro USB  Replacement: passo 6, immagine 1 di 1
    • With the Micro USB port exposed, part can be replaced with advanced soldering and circuitry.
Conclusione
Baleigh Hance
Membro da: 11/20/17
101 Reputazione
1 Guida realizzata
IUPUI, Team S22-G4, Bayer Fall 2017 Membro di IUPUI, Team S22-G4, Bayer Fall 2017
IUPUI-BAYER-F17S22G4
5 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 144
