Salta al contenuto principale
iON SnapCam 1045 Wearable HD Video Camera Battery
Cosa ti serve
  1. iON SnapCam 1045 Wearable HD Video Camera Battery, Battery: passo 1, immagine 1 di 1
    • Detach the magnetic clip from the bottom of the camera.
    • The magnetic clip gets in the way of disassembly because it constantly spins and therefore a distraction so it is imperative to detach.
  2. iON SnapCam 1045 Wearable HD Video Camera Battery: passo 2, immagine 1 di 1
    • Use a spudger to gently detach the memory card and USB slot cover.
  3. iON SnapCam 1045 Wearable HD Video Camera Battery: passo 3, immagine 1 di 1
    • Use a Phillips #000 Screwdriver to loosen the 0.008 mm screw located between the USB and memory card slots.
    • This screw is really tiny and can easily fall off and get lost! Make use of a magnetic mat to hold it in place or better still put the magnetic clip to use for keeping the screw safe.
  4. iON SnapCam 1045 Wearable HD Video Camera Battery: passo 4, immagine 1 di 2 iON SnapCam 1045 Wearable HD Video Camera Battery: passo 4, immagine 2 di 2
    • Once again use the spudger to gently open the encasement.
    • The case is a little fragile and forceful entry could lead to damage of the plastic case. Thread carefully.
    • The Battery can be safely detached and replaced.
Conclusione
Olakunle
Membro da: 11/11/17
102 Reputazione
1 Guida realizzata
IUPUI, Team S3-G3, Wilson Fall 2017 Membro di IUPUI, Team S3-G3, Wilson Fall 2017
IUPUI-WILSON-F17S3G3
3 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 717
