Introduzione
The GPU and CPU share a heat sink and exhaust vent. Use this guide to remove the entire unit from the logic board. Don't forget to apply a new layer of thermal compound before reassembling your iMac.
Follow our thermal paste guide for instructions on cleaning and preparing the thermal surfaces and applying a new layer of thermal compound onto the CPU and GPU dies.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
Cosa ti serve
With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed with the iMac laying down, but are faster and easier with an iMac service wedge.
If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
With the cards inserted as shown near the corners, gently twist the cards to increase the gap between display and case.
If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the adhesive in the problem area.
Begin to lift the top of the display up from the frame.
If there is a wire or cable underneath adhesive tape, always pull the tape off first.
If the cable is glued to the chassis, use a heated iOpener or a hair dryer to soften the adhesive first. You can then slide an opening pick underneath the cable to loosen it. Never pull directly on the delicate connectors.
Slide an opening pick underneath the foam cushion pieces to separate them from the display, and gently pull them off. You may need some double sided tape to re-attach them to the new display.
Use a Phillips screwdriver to remove the nine 3.2 mm screws securing the support bracket.
You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
Pull straight up on the SATA data/power cable to disconnect it from the drive.
Disconnect the power supply control cable from the power supply.
Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
Use the flat end of a spudger to disconnect each of the four antenna connectors from the AirPort/Bluetooth card.
Leftmost
Top
Upper right
Lower right
Remove the four 7.5 mm T8 screws from behind the GPU on the logic board.
Insert the flat end of a spudger between the CPU and heat sink.
Gently pry the CPU up by slightly twisting the spudger.
Remove the CPU from the heat sink. Be careful not to touch the contacts.
Install your CPU into its socket on the board, not on the heat sink. Check the orientation and make sure it lines up correctly in the socket. Follow the instructions specific to your CPU type to apply fresh thermal paste to the surface of your CPU. Then, reinstall the heat sink over the top.
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
Altre 6 persone hanno completato questa guida.
5 Commenti
Hi All,
did you notice something unusual in the contact surfaces between GPU and Heatsink ?
Some unit are hotter than others, we are discussing in a forum if it may be a problem with the cooling system. My 5K with the M295X can top at 100°C and others even 108° with consistent louder fan (+400rpms for the same task).
Can you tell me if the high temps, 106 Celsius, in the iMac retina GPU should be a big concern or not? I am considering returning my iMac in the next few days because of this.
I would highly recommend using at the very least, an anti-static wrist band when attempting any computer repair to this level.
In the 1980's I ran Commodore UK's service department. At that time we suffered a 30% failure rate of PC's that were being configured and assembled in our factory. The failures ceased the moment anti-static precaution were introduced!
Asking a question for this since my iMac 17,1 is due for an upgrade.
Does anyone know how thick of a thermal pad can be used on the VRAM chips? I am not a fan of using compound for these. (Still in the learning stages of this topic)
Also has anyone attempted to use a graphite thermal pad for the CPU or GPU?
Thanks in advance!
what size thermal pad works best on a 2014 imac 27 inch retna for the gpu memory?
thanks
Chris
