Introduzione
In the calm after the iPhone 5s/c storm, Apple thought it could slip a couple new iMacs by us. Time for us to get our pry on and pop this next generation 27" iMac wide open for a quick tour of the highlights.
We also tore apart the newly refreshed smaller-brother iMac 21.5"—head over to its teardown and check it out too.
Can't get enough of our play-by-play? Show us your game face on Twitter, Instagram, or Facebook.
Cosa ti serve
Externally, the iMac Intel 27" EMC 2639 looks identical to the previous generation, but the interior specs have been upgraded:
3.2GHz quad-core Intel Core i5 processor (Turbo Boost up to 3.6GHz) with 6MB L3 cache
NVIDIA GeForce GT 755M graphics processor with 1GB of GDDR5 memory
802.11ac Wi-Fi
PCIe flash SSD available
Attrezzo utilizzato in questo passaggio:iMac Opening Wheel$7.99
After some quick slicing with our handy iMac Opening Tool, we pop the hood and get a massive bout of deja vu.
The AirPort/Bluetooth card, conforming to the 802.11ac Wi-Fi standard, still clings to the back of the logic board — making replacement no easier than before.
Not the first Mac to get updated with the new ac standard, we expected to see some similar hardware as in the refreshed MacBook Airs from earlier this year.
Chips off the
oldnew block: -
Broadcom BCM4360KML1G 5G WiFi 3-Stream 802.11ac Gigabit Transceiver—as expected, this is the same chip driving the ac Wi-Fi in the 11" and 13" MacBook Air
Skyworks SE5516 Dual-Band 802.11a/b/g/n/ac WLAN Front-End Module
Broadcom BCM20702 Single-Chip Bluetooth 4.0 HCI Solution with Bluetooth Low Energy (BLE) Support
As is now standard across all new iMacs, the new iMac 27" features support for PCIe-based flash storage. This is a pleasant surprise compared to last year's 21.5" model, when we were left sorely disappointed by unpopulated solder pads on our low-end logic board.
According to Apple, the inclusion of PCIe flash storage allows for up to 50 percent faster speeds than the previous generation.
Heavy-weight ICs:
Intel platform controller hub
As advertised, the iMac 27" now sports a fancy new graphics processor:
NVIDIA GeForce GT 755M GPU
Four SK hynix H5GQ2H24AFR 256 MB GDDR5 SGRAM ICs make up the 1 GB of graphics RAM
The B-side of our IC record:
NXP ARM7TDMI-S based Microcontroller
Analog Devices SSM3302 audio amplifier
Cirrus Logic 4206BCNZ audio controller, the same chip as found in last year's 21.5"
Vimicro VC0359 webcam processor
Broadcom BCM57765A1KMLG gigabit ethernet controller with integrated SDXC card reader
Intel DSL3510L Cactus Ridge Thunderbolt controller
iMac 27" EMC 2639 Repairability Score: 5 out of 10 (10 is easiest to repair)
RAM is user-replaceable without opening the case, thanks to the rear access door.
You can still replace the hard drive and CPU inside this machine, albeit with some adhesive cutting.
Components are modular and fairly easy to remove.
Budget-minded folks now can add a second hard drive to the base iMac because the Fusion Drive connector is no longer missing from the logic board.
The glass and LCD are fused together, and there are no more magnets holding the glass in place.
You'll have to masterfully peel off the old double-sided sticky tape and apply new tape in order to reseal this iMac into original condition.
22 Commenti
You forget to mention *HOW* one should mount an extra SSD in the new port.
Do we need to remove the LCD panel or is there a slot you can access through the back, like with RAM?
You'll need to remove the LCD and dig your way inside.
On the BTO "SSD flash memory only model", is the SSD connected to the rear PCIe port leaving an empty SATA port? So someone could add an additional SATA drive?
Thx
I am also looking for the same info. Anybody has an ans?
imacsps -
