Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
prerequisite for logic board, heat sink, and CPU
Parti
Nessuna parte specificata.
  1. Remove the four 7.5 mm T8 screws from behind the GPU on the logic board. These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver. These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver.
    • Remove the four 7.5 mm T8 screws from behind the GPU on the logic board.
    • These screws are set inside large, spring-loaded Phillips #2 screws. To prevent the larger screws from spinning when you loosen the T8 screws, hold them with a fingertip or Phillips #2 screwdriver.
  2. Remove the bracket from behind the GPU heat sink.
    • Remove the bracket from behind the GPU heat sink.
  3. Remove four black stickers from the back of the CPU heat sink.
    • Remove four black stickers from the back of the CPU heat sink.
  4. Remove four 12.3 mm T10 screws from the back of the CPU heat sink.
    • Remove four 12.3 mm T10 screws from the back of the CPU heat sink.
  5. Remove the spring plate from behind the CPU heat sink. Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board. Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board.
    • Remove the spring plate from behind the CPU heat sink.
    • Lift and remove the backing plate from behind the CPU heat sink. The backing plate has two posts that fit into alignment holes in the logic board.
  6. Lift the heat sink up from the logic board. The CPU will most likely stick to the heat sink, so be careful about where you put it down. The CPU will most likely stick to the heat sink, so be careful about where you put it down.
    • Lift the heat sink up from the logic board.
    • The CPU will most likely stick to the heat sink, so be careful about where you put it down.
Conclusione
iFixit Membro di iFixit
Community
133 Membri
14.601 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 154
