Salta al contenuto principale
Parti
Nessuna parte specificata.
  1. Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board. Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board. Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
    • Use the tip of a spudger to disconnect the fan cable's connector from its socket on the logic board.
  2. Peel the black tape connecting the fan to the exhaust duct back slightly. Leave the tape in place on the exhaust duct, you only need to expose the joint to free the fan.
    • Peel the black tape connecting the fan to the exhaust duct back slightly.
    • Leave the tape in place on the exhaust duct, you only need to expose the joint to free the fan.
  3. Remove three 12.4 mm T10 screws securing the fan to the rear case.
    • Remove three 12.4 mm T10 screws securing the fan to the rear case.
  4. Remove the fan from the iMac. Remove the fan from the iMac.
    • Remove the fan from the iMac.
Conclusione
iFixit Membro di iFixit
Community
100 Membri
8.930 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 147
