Salta al contenuto principale
iMac Intel 27" EMC 2390 Display Replacement
Cosa ti serve
  1. iMac Intel 27" EMC 2390 Display Replacement, Glass Panel: passo 1, immagine 1 di 3 iMac Intel 27" EMC 2390 Display Replacement, Glass Panel: passo 1, immagine 2 di 3 iMac Intel 27" EMC 2390 Display Replacement, Glass Panel: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Heavy-Duty Suction Cups (Pair)
    $14.95
    Compra
    • Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups, first position the suction cup with the movable handle parallel to the face of the glass panel (as indicated in the second picture).
    • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a damp soft, lint-free cloth. (Dampen with distilled water, and if needed, an equal ratio of distilled water and white vinegar for best results.)
    • Do not use the suction cups to carry the display glass because if one of them fails to stick, you could drop the screen and break it.
    • The original iMac box makes a good place to store the glass panel. Otherwise, a padded horizontal surface, like a towel on a desk, will do nicely.
  2. iMac Intel 27" EMC 2390 Display Replacement: passo 2, immagine 1 di 3 iMac Intel 27" EMC 2390 Display Replacement: passo 2, immagine 2 di 3 iMac Intel 27" EMC 2390 Display Replacement: passo 2, immagine 3 di 3
    • Gently lift the glass panel perpendicular to the face of the LCD, enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • Don't use the suction cups to carry the glass panel—if either one loses its grip, the panel could fall and break.
    • After setting the glass panel down safely, be sure to release the suction cups, as the suction force over time can crack the glass.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
  3. iMac Intel 27" EMC 2390 Display Replacement, Display: passo 3, immagine 1 di 1
    • Remove the eight T10 Torx screws securing the LCD to the outer case.
  4. iMac Intel 27" EMC 2390 Display Replacement: passo 4, immagine 1 di 3 iMac Intel 27" EMC 2390 Display Replacement: passo 4, immagine 2 di 3 iMac Intel 27" EMC 2390 Display Replacement: passo 4, immagine 3 di 3
    • Carefully lay the iMac stand-side down on a flat surface.
    • Due to tight tolerances, you will have to use a thin hooked tool to lift the display out of the outer case. As seen in the third picture, we made one out of a bent paperclip.
    • Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
    • After lifting the top edge of the display on one side, hold it out of the outer case while you use a hooked tool to lift the other side.
    • Do not lift the top edge of the display out of the outer case too far, as several short ribbon cables still connect the two components.
  5. iMac Intel 27" EMC 2390 Display Replacement: passo 5, immagine 1 di 2 iMac Intel 27" EMC 2390 Display Replacement: passo 5, immagine 2 di 2
    • Using your fingers, carefully pull the vertical sync cable out of its socket on the LED driver board near the top left corner of your iMac.
    • Be sure to pull the connector parallel to the LED driver board, straight out of its socket.
  6. iMac Intel 27" EMC 2390 Display Replacement: passo 6, immagine 1 di 1
    • Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
    • Pull the display data cable connector away from its socket on the logic board.
  7. iMac Intel 27" EMC 2390 Display Replacement: passo 7, immagine 1 di 1
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
  8. iMac Intel 27" EMC 2390 Display Replacement: passo 8, immagine 1 di 1
    • Lift the display for enough clearance to disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable.
  9. iMac Intel 27" EMC 2390 Display Replacement: passo 9, immagine 1 di 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case.
Conclusione
Altre 28 persone hanno completato questa guida.
Brett Hartt
Membro da: 04/12/10
127.897 Reputazione
143 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
6 Commenti
Hard to learn, easy to master. There are a lot of trap cables that are not very long. For best results, I like to use cardboard hard drive boxes to prop up my LCD display to a 30° angle so I can reconnect cables with both my hands.
Kevin McCartney - Replica
Does anyone know if the display from a 2011 27" iMac is compatible with a 2010 27" iMac? The 2011 in my office died, but the 2010 still works fine, albeit with color trouble due to a malfunctioning display.
kazoodac - Replica
They are not. Sorry.
Al
Alan Ullman -
I can disassemble the LCD backlight to clean the dust that does a bad ghost, some of you have already done it
lucaramponi02 - Replica
Hello ! Do you have, any idea where I can buy the display replacement?
Javier Malpartida - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 51
Ultimi 30 Giorni: 176
Tutti i Tempi: 52,208
