Salta al contenuto principale
iMac Intel 27" EMC 2309 and 2374 superdrive fixit
Cosa ti serve
  1. iMac Intel 27" EMC 2309 and 2374 superdrive fixit, Glass Panel: passo 1, immagine 1 di 3 iMac Intel 27" EMC 2309 and 2374 superdrive fixit, Glass Panel: passo 1, immagine 2 di 3 iMac Intel 27" EMC 2309 and 2374 superdrive fixit, Glass Panel: passo 1, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    Heavy-Duty Suction Cups (Pair)
    $16.95
    • Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
    • To attach the suction cups, first position the suction cup with the movable handle parallel to the face of the glass panel (as indicated in the second picture).
    • While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
    • If your suction cups refuse to stick, try cleaning both the glass panel and the suction cup with a damp soft, lint-free cloth. (Dampen with distilled water, and if needed, an equal ratio of distilled water and white vinegar for best results.)
    • Do not use the suction cups to carry the display glass because if one of them fails to stick, you could drop the screen and break it.
    • The original iMac box makes a good place to store the glass panel. Otherwise, a padded horizontal surface, like a towel on a desk, will do nicely.
    Chiedi a FixBot
    Aggiungi Commento
  2. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 2, immagine 1 di 3 iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 2, immagine 2 di 3 iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 2, immagine 3 di 3
    • Gently lift the glass panel perpendicular to the face of the LCD, enough to clear the steel mounting pins attached along the underside of the top edge of the glass panel.
    • Pull the glass panel away from the lower edge of the iMac and carefully set it aside.
    • Don't use the suction cups to carry the glass panel—if either one loses its grip, the panel could fall and break.
    • After setting the glass panel down safely, be sure to release the suction cups, as the suction force over time can crack the glass.
    • During reinstallation, be sure to meticulously clean the inside of the glass panel and the face of the LCD as any dust or fingerprints trapped inside will be annoyingly visible when the machine is turned on.
    Chiedi a FixBot
    Aggiungi Commento
  3. iMac Intel 27" EMC 2309 and 2374 superdrive fixit, Display: passo 3, immagine 1 di 1
    • Remove the eight T10 Torx screws securing the LCD to the outer case.
    Chiedi a FixBot
    Aggiungi Commento
  4. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 4, immagine 1 di 3 iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 4, immagine 2 di 3 iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 4, immagine 3 di 3
    • Carefully lay the iMac stand-side down on a flat surface.
    • Due to tight tolerances, you will have to use a thin hooked tool to lift the display out of the outer case. As seen in the third picture, we made one out of a bent paperclip.
    • Use a thin hooked tool to lift one side of the top edge of the display by its steel outer frame.
    • After lifting the top edge of the display on one side, hold it out of the outer case while you use a hooked tool to lift the other side. A pencil or pen can be placed under the top edge of the display, parallel to the top edge and extending past the edge of the computer, to keep the first side propped up while lifting the second.
    • Do not lift the top edge of the display out of the outer case too far, as several short ribbon cables still connect the two components.
    Chiedi a FixBot
    Aggiungi Commento
  5. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 5, immagine 1 di 2 iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 5, immagine 2 di 2
    • Use a pair of tweezers to pull the vertical sync ribbon cable out of its socket on the LED driver board near the top left corner of your iMac.
    • On some iMacs this may not be a ribbon cable but four separate, very fine and very fragile wires. Be very careful, if the tweezers slip off the plug, you will very likely pull a wire out of the assembly.
    Chiedi a FixBot
    Aggiungi Commento
  6. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 6, immagine 1 di 1
    • Rotate the display out of the outer case enough to disconnect the LED backlight power cable from the LED driver board.
    Chiedi a FixBot
    Aggiungi Commento
  7. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 7, immagine 1 di 1
    • Squeeze the two display data cable connector arms together to unlock it from its socket on the logic board.
    • Pull the display data cable connector away from its socket on the logic board.
    • Be very careful when disconnecting this cable as both the cable connector and logic board socket are extremely fragile. When reconnecting the cable later, use as little force as possible.
    Chiedi a FixBot
    Aggiungi Commento
  8. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 8, immagine 1 di 1
    • Lift the display for enough clearance to disconnect the LCD thermal sensor cable connector from its socket on the logic board.
    • If your fan is spinning full speed after completion, check this connection or the hard drive's thermal sensor cable. The thermal sensor connector socket is very fragile, so be very careful when you connect back the sensor cable.
    Chiedi a FixBot
    Aggiungi Commento
  9. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 9, immagine 1 di 1
    • Carefully pull the display toward the top edge of your iMac and lift it out of the outer case.
    Chiedi a FixBot
    Aggiungi Commento
  10. iMac Intel 27" EMC 2309 and 2374 superdrive fixit, Optical Drive: passo 10, immagine 1 di 1
    • Remove the four T10 Torx screws securing the optical drive to the outer case.
    Chiedi a FixBot
    Aggiungi Commento
  11. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 11, immagine 1 di 1
    • Pull the optical drive thermal sensor connector straight away from its socket on the logic board.
    Chiedi a FixBot
    Aggiungi Commento
  12. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 12, immagine 1 di 2 iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 12, immagine 2 di 2
    • Insert a spudger between the optical drive connector and the optical drive.
    • Twist the spudger to slightly separate the optical drive connector from the optical drive, then use your fingers to pull the connector away from the drive.
    Chiedi a FixBot
    Aggiungi Commento
  13. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 13, immagine 1 di 1
    • Lift the left edge of the optical drive slightly and pull it away from the right side of the outer case.
    • During reassembly, note that there are two holes in the optical drive face plate into which two stubby plastic posts must engage for proper positioning.
    Chiedi a FixBot
    Aggiungi Commento
  14. iMac Intel 27" EMC 2309 and 2374 superdrive fixit, Optical Drive: passo 14, immagine 1 di 2 iMac Intel 27" EMC 2309 and 2374 superdrive fixit, Optical Drive: passo 14, immagine 2 di 2
    • Peel back the portion of aluminum tape highlighted in red, leaving the rest attached to the black plastic optical drive bracket.
    • It is not necessary to peel all of the EMI tape off the optical drive bracket.
    Chiedi a FixBot
    Aggiungi Commento
  15. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 15, immagine 1 di 2 iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 15, immagine 2 di 2
    • Remove the two T10 Torx screws from each side of the optical drive (four screws total).
    Chiedi a FixBot
    Aggiungi Commento
  16. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 16, immagine 1 di 3 iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 16, immagine 2 di 3 iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 16, immagine 3 di 3
    • Use the tip of a spudger to press each of the optical drive bracket tabs out of their slots on the bottom of the optical drive.
    • Rotate the optical drive bracket slightly away from the optical drive.
    • Pull the optical drive bracket away from the open end of the optical drive, minding any tabs that may get caught.
    Chiedi a FixBot
    Aggiungi Commento
  17. iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 17, immagine 1 di 2 iMac Intel 27" EMC 2309 and 2374 superdrive fixit: passo 17, immagine 2 di 2
    • Use the tip of a spudger to peel back the piece of foam tape covering the optical drive thermal sensor.
    • Use the flat end of a spudger to carefully pry the thermal sensor up off the adhesive securing it to the optical drive.
    • If you have a disc or anything else stuck inside your optical drive, we have a guide to fix it.
    Chiedi a FixBot
    Aggiungi Commento
    • Follow all super drive replacement steps for disassembly. Step 8 is absolutely unnecessary for the repair. Do not peel off the sensor from the optical drive.
    • Once the reader has been disassembled, all you have to do is unscrew the 5 small screws from the reader cover (the side where there are the labels). Remove the cover once the screws have been removed;
    • Plug in your vacuum cleaner and gently vacuum the entire interior, including the lens (beware of vacuum cleaners that are too powerful).
    • With a cotton swab previously dipped in rubbing alcohol, gently clean the lens.
    • reassemble the cover with the screws and reassemble everything.
    • Once everything is reassembled, start and cross your fingers. Usually it's just a dust issue.
    • Enjoy!!!
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
To reassemble your device, follow the instructions in reverse order.
Un ringraziamento speciale a questi traduttori:
fr en
100%
HelloMacOS ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
Quentin Hindley
Membro da: 02/08/19
73 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 13
Ultimi 30 giorni: 59
Tutti i Tempi: 1,469
