Introduzione
Use this guide to replace a faulty SD Board.
Cosa ti serve
Stick a heavy-duty suction cup near each of the two top corners of the glass panel.
While lightly holding the suction cup against the glass, raise the movable handle until it is parallel with the other handle (as indicated by the third picture).
Grasp the SD board cable connector with a pair of tweezers and pull it straight away from its socket on the SD board.
Altre 2 persone hanno completato questa guida.
