Introduzione
Utilizzare questa guida per installare un disco rigido nell'iMac Intel EMC 2134 o EMC 2211 da 24".
Cosa ti serve
Premere la staffa del disco rigido verso il bordo inferiore dell'iMac per liberarla dal case posteriore, quindi ruotare la parte dell'unità verso di sé.
To avoid the pain on my finger tips in applying enough force, I used a bit of microfiber towel as padding under the sharp plastic edge and it was then easy.
I found out that the black plastic bar is a lever, which swings up outwards left side — away from the backside of the casing — and then drops off of the right side, which releases the rubberized bolts, that hold the hard drive! The hard drive then could be lifted easily out of its hinges. Mind the cables!
Using a trigger clamp to compress the black retainer was the easiest method to remove the drive. Move the sensor wires out of the way then position the clamp in such a way that one jaw is on the drive and the other is on the black plastic. Compress it just enough to clear the metal support. Then to reinstall reverse the process.
DON’T do this! you’ll likely hurt yourself. I tried doing this way and it just required more force than i was comfortable applying. just unscrew the HDD off the black “lever” piece. The HDD will just come right out. The side opposite of the black “lever” are secured with pins, don’t bother trying to unscrew from there.
Inserire l'estremità piatta di un inseritore fra il connettore del cavo di alimentazione SATA e il bordo del disco rigido.
Ruotare l'inseritore per separare il connettore dal disco rigido.
Scollegare il cavo dati SATA estraendone il connettore dal disco rigido.
This cable was not long enough to reach the SSD connector for me. The adapter I used, and I suspect many used, puts the SSD centred, thus the data and power connectors a bit further away from where the original drive's connector were. The power cable had enough give to plug it in, but not the data cable. I knew the data cable had more give from the other end of it, so I careful pulled it with, ashamed to say, force. I heard tape giving away, so I figured it was taped down underneath. I managed to get just enough length to plug it in.
Per riassemblare il dispositivo, seguire queste istruzioni in ordine inverso.
Un ringraziamento speciale a questi traduttori:
100%
Jasper Fleischhauer ci sta aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
