Salta al contenuto principale
iMac Intel 21.5" EMC 3068 Display Assembly Replacement
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. iMac Intel 21.5" EMC 3068 Display Assembly Replacement, Display Assembly Separation: passo 1, immagine 1 di 2 iMac Intel 21.5" EMC 3068 Display Assembly Replacement, Display Assembly Separation: passo 1, immagine 2 di 2
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  2. iMac Intel 21.5" EMC 3068 Display Assembly Replacement: passo 2, immagine 1 di 3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: passo 2, immagine 2 di 3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Plastic Cards
    $2.99
    Compra
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
    • Repeat this step with the other adhesive strip and remove it.
    • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
  3. iMac Intel 21.5" EMC 3068 Display Assembly Replacement: passo 3, immagine 1 di 3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: passo 3, immagine 2 di 3 iMac Intel 21.5" EMC 3068 Display Assembly Replacement: passo 3, immagine 3 di 3
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • After the adhesive is cut, it cannot be used to re-seal the display in place. Follow this guide to replace the adhesive strips that secure the display to the rear enclosure.
Conclusione
Adam O'Camb
Membro da: 04/11/15
196.587 Reputazione
416 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 4
Tutti i Tempi: 81
