Introduzione
Use this guide to replace the logic board.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Use a pair of tweezers to flip up the metal retaining bracket on the display data cable.
Carefully pull the display data cable from its socket on the logic board.
Remove the following five Phillips screws holding the lower support bracket in place:
Four 3.2 mm screws
One 1.7 mm screw
Use the tip of a spudger to push on either side of the right speaker cable connector to walk it out of its socket on the logic board.
Remove the following screws securing the hard drive bracket to the rear enclosure:
Two 21 mm T10 Torx screws from the left-hand hard drive bracket.
One 9 mm T10 Torx screw.
One 27 mm T10 Torx screw.
Use the tip of a spudger to push each side of the power button cable connector and gently walk it out of its socket.
Use the tip of a spudger to push the fan cable connector out of its socket on the logic board.
Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
Remove the single 7.2 mm T10 screw securing the hard drive tray to the rear enclosure.
Use the tip of a spudger to walk the left speaker cable connector out of its socket.
While pressing on the clip with your thumb, lift and disconnect the SATA data connector from its socket on the logic board.
The following screws secure the heat sink to the logic board:
Remove the two T8 screws from the exhaust port end of the heat sink.
Loosen, but do not remove, the four captive T8 screws securing the CPU end of the heat sink.
Remove the two 3.2 mm T5 screws securing the AirPort/Bluetooth card to the logic board.
During reassembly of the logic board, pay attention to the position of the I/O connectors. When the board is back in the case, insert a USB or Thunderbolt cable into one of the connectors to align it perfectly.
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
Altre 2 persone hanno completato questa guida.
