Introduzione
Use this guide to replace the left speaker.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
While holding the display up with one hand, use the other hand to unplug the display power cable.
Remove the following five Phillips screws holding the lower support bracket in place:
Four 3.2 mm screws
One 1.7 mm screw
Pull the fan cable connector straight away from its socket on the logic board.
Use the tip of a spudger to walk the left speaker cable connector out of its socket.
Altre 4 persone hanno completato questa guida.
