Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Use this guide to replace or upgrade your hard drive.
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs are fast and easy with an iMac service wedge, but can be completed without one.
    • Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
    The wedge is an extremely tight fit for this model. I was worried that the amount of force needed to use it as shown might damage the stand, so I used it with the long side down instead. It worked fine that way and didn’t need anywhere near as much force to insert.
    roberttrevellyan - Replica
    Here’s a good YouTube vid on upgrading the RAM: Can a Normal Person Upgrade the RAM in the 2017 21.5" iMac?
    Dan - Replica
    Here are a couple tips from me:
    1) Expose the adhesive to extreme temperatures. I did this by transporting my iMac in my car, screen-down on a piece of cardboard on a cold February morning (in Chicago). When I went to pick up the iMac, the screen practically fell off the chassis. I would have been distraught by this if I hadn’t already planned this replacement. So it was a happy accident.
    2) Remember to expell the residual power from the power supply by pushing the power button while the iMac is unplugged. This does NOT guarantee it’s safe to touch, but when I accidentally brushed the solder and exposed capacitors, I didn’t get shocked.
    jerrid_foiles - Replica
    Instead of using the wedge, I placed the iMac faced up with the top side (web cam) facing me while I ran the pizza roller around. It worked out great!
    Sam Fung - Replica
    “All iMacs also come with a traditional hard drive” mine doesn’t!! it’s HDD bay is completely empty, no SATA cable or anything. I guess I’ll have to upgrade the PCIe SSD instead.
    Chris Hughes - Replica
  1. Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure. The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
    • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
    Don’t get too worried about starting exactly where the picture says. The glue is stronger in some parts so just start wherever is easier and then work slowly and patiently around in the direction shown.
    Richard Cook - Replica
  2. Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center. Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle. Run the tool up along the left side of the display.
    • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
    • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
    Erreur de traduction: "de bas en haut" et non de" haut en bas" sur le côté gauche de l'écran
    Moreau - Replica
  3. Continue running the tool up around the top left corner. Continue running the tool up around the top left corner. Continue running the tool up around the top left corner.
    • Continue running the tool up around the top left corner.
  4. Cut the adhesive along the top left of the display. Cut the adhesive along the top left of the display.
    • Cut the adhesive along the top left of the display.
  5. Continue along the top of the display. You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
    • Continue along the top of the display.
    • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
    In this step can I cut along the display without make any damage to the front camera?
    arisnordico - Replica
    Hi! Actually - there is no need to cut the tape around the camera area - there is no tape to cut at all! And so, the way go is easy - just pass 10 mm to the left and to the right from camera and start cutting!
    P.S. Just did the whole procedure to replace a RAM and to add SSD on PSIe an hour ago! Seems to be different reading the instructions... you know - 2/10 and so on. But it's really not that hard, trust me. I'll give it 5/10.
    P.P.S. By the way there is one trick to pass the difficult steps. Any action which requires pulling smth (motherboard, speaker, power supply unit) from the narrow crack (or should i say - slit?) at the bottom of your Imac is really not so easy.
    And the trick is to first remove a thin metal stripe with some kind of insulation on it which held by 5 small (very small!!) screws at the bottom of your Imac. After you done it - it's easy to pull everything! Pay attention to the fact that one of this 5 screws at the center are more shortly than others.
    dv1977 - Replica
    After doing the replacement the adhesive still sticks quite good enough to hold the screen in place. Maybe this isn't rock-solid, but enough for me.
    Mirko - Replica
    I did all steps like this manuell but now the Display wont work only some colered strips are to see! Whats happend??
    Can anybody help me ? Maybe the connector cable is broken?
    djfanta - Replica
    Check both connectors, probably one of them not seated well
    pzhivulin -
    You can add a SATA SSD if you already have a PCIe SSD Factory?
    kaserlik - Replica
    If you're changing cracked EMC 2638 display to new assembly, there's two more steps:
    Step 24: Use the tip of a spudger to flip up the metal retaining bracket on the display data cable.
    Carefully pull the display data cable from its socket on the display assembly.
    Step 25: Use the tip of a spudger to unplug bracket of the thermal sensor small cable near display data cable.
    Carefully remove scotch tape covering thermal sensor. Using iSesamo or flat tip of the spudger carefully peel the thermal sensor away.
    pzhivulin - Replica
    omg - forgot to switch the termal sensor from the old display...
    now fan runs like crazy...
    Andrei Balotescu -
  6. Push the tool around the top right corner of the display. Push the tool around the top right corner of the display. Push the tool around the top right corner of the display.
    • Push the tool around the top right corner of the display.
  7. Wheel the tool down along the right side of the display. Wheel the tool down along the right side of the display.
    • Wheel the tool down along the right side of the display.
  8. Finish pushing the opening tool to the bottom of the right side of the display. At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
    Yes, do it many times to loosen the adhesive.
    Noah Ralston - Replica
  9. While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive. Set the iMac face-up on a table. Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
    • While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
    • Be careful not to insert the plastic card more than 3/8", or you may damage internal components.
    this step is extremely important NOT to stick in the cards too far….. doing so, you risk a 600 euro replacement as I experienced………
    Edgar Broekema - Replica
  10. Kit cacciaviti Manta
    112 punte per ogni riparazione.
    Upgrade Your Toolbox
  11. Gently twist the plastic card sideways to create a gap between the display and frame. Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
    • Gently twist the plastic card sideways to create a gap between the display and frame.
    • Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
    This part must be done very carefully or you can damage the flat cable from display, despite it was under a iron cover.
    Cassio Machado - Replica
  12. Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac. Be sure to stop before the iSight camera, or you may damage it. Be sure to stop before the iSight camera, or you may damage it.
    • Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
    • Be sure to stop before the iSight camera, or you may damage it.
    You don't need to do it like this, simply open the iMac bendidng the LCD completely and use the pizza cutter to remove the adhesive.
    Felix - Replica
  13. Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking. Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
    • Wedge the plastic card into the top right corner once again, and leave it there to prevent the adhesive from resticking.
  14. Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac. Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac. Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
    • Insert a second plastic card into the gap between the display and frame near the top left corner of the iMac.
  15. Gently twist the card upward, slightly increasing the space between the display and frame. As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
    • Gently twist the card upward, slightly increasing the space between the display and frame.
    • As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
  16. Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera. Slide the plastic card toward the center, again stopping just before the iSight camera.
    • Slide the plastic card toward the center, again stopping just before the iSight camera.
  17. Wedge the plastic card back into the top left corner. Wedge the plastic card back into the top left corner.
    • Wedge the plastic card back into the top left corner.
  18. With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case. If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive. Begin to lift the top of the display up from the frame.
    • With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive.
    • Begin to lift the top of the display up from the frame.
    • Only lift the display a few inches—the display data and power cables are still connected to the logic board.
  19. While holding the display up with one hand, use the other hand to unplug the display power cable. Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
    • While holding the display up with one hand, use the other hand to unplug the display power cable.
    • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
    Pulling the display power cable by the wires makes me nervous..
    bstaud - Replica
    I had a small flight light ready so I could see. Follow the directions - don’t blindly pull.
    Head lamp gives you the best hands free view!
    lamajr - Replica
    bstaud - The display power cable has two squeezable levers on each end of the cable’s width.
    Squeeze the left lever with your thumb while you simultaneously squeeze the right lever with your
    index finger, and gently pull the cable straight back and out, and the cable comes out very easily.
    Ted Horodynsky - Replica
  20. Use the tip of a spudger to flip up the metal retaining bracket on the display data cable. Carefully pull the display data cable from its socket on the logic board. Be sure to pull the display data cable connector straight out of its socket.
    • Use the tip of a spudger to flip up the metal retaining bracket on the display data cable.
    • Carefully pull the display data cable from its socket on the logic board.
    • Be sure to pull the display data cable connector straight out of its socket.
    Sure could use a magnified picture of this connector and socket, especially the first time you go in. And it is the most critical step of the whole operation — bung it up and we’re toast.
    bstaud - Replica
    Hi bstaud! If you hover over the image you can click on the magnifying glass and get a large image of any guide photo. Hope that helps!
    Sam Goldheart -
    To clarify, the connector pulls out in the plane of the logic card, not perpendicular.
    David Thompson - Replica
  21. Lift the display up to a near-vertical position. At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
    Where can I find a replacement display for my iMac?
    Braydon Boyce - Replica
    iFixit has listings for replacements. Go to the Parts section
    jerrid_foiles -
  22. If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip. If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
    • If necessary, a plastic card can be used to cut any remaining sections of the bottom adhesive strip.
    Cutting through this extra adhesive on the bottom took a bit more effort than the step and picture implied (to me). Unlike the other edges, here don't be afraid to really push the card in there to break the seal, there's nothing behind that adhesive that is breakable.
    phil - Replica
    cutting through the adhesive is unnecessary if it's not been opened before (outside of an apple store) there will be a tab at the end of each VHB strip that you can use to simply pull the vhb strips off.
    Rory McKenna - Replica
    YES, exactly the same here. more but more simple.
    Lucio Alves -
    To save a few steps and a bit of time, if you have a helper, they can hold the display at a 90° angle while you unscrew the brackets and remove/replace the hard drive rather than remove the display entirely. Also reduces the likelihood of damaging the display as you remove and handle it.
    marty - Replica
    The proper way to remove the display according to the Macintosh tech manual and videos is as Rory McKenna and Lucio Alves have learned is to pull the tab at the end of each VHB strip until it is off.
    Ben Varela - Replica
  23. Lift the display up from the frame and remove it from the iMac. It may be necessary to slowly lift from one side, to peel against the remaining adhesive. Be very careful handling the display—it's big, heavy, and made of glass.
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
  24. Remove the following screws securing the hard drive bracket to the rear enclosure:
    • Remove the following screws securing the hard drive bracket to the rear enclosure:
    • Two 21 mm T10 Torx screws from the left-hand hard drive bracket.
    • One 9 mm T10 Torx screw.
    • One 27 mm T10 Torx screw.
    Is there a special drive for this? Apple specs only one or two drives? I am planning a seagate SDHD. It has SMART, but may not be the right version. ANy comments/ recommendations?
    Carl Schultz - Replica
    Any 2.5” SATA drive should work, but you’re doing yourself a disservice if you don’t get an SSD. One with a dram controller, preferably. They are a bit over $100 for 1TB right now (Jan 2020).
    maccentric -
  25. Remove the left and right hard drive brackets from the iMac. Remove the left and right hard drive brackets from the iMac.
    • Remove the left and right hard drive brackets from the iMac.
  26. Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess. The hard drive is attached by a single SATA power/data cable—do not attempt to fully remove it from the iMac yet. The hard drive is attached by a single SATA power/data cable—do not attempt to fully remove it from the iMac yet.
    • Lift the hard drive from the edge nearest the logic board and pull it slightly out of its recess.
    • The hard drive is attached by a single SATA power/data cable—do not attempt to fully remove it from the iMac yet.
  27. Use a spudger to disconnect the single SATA power and data combo cable by gently prying its large plastic connector away from the hard drive. Use a spudger to disconnect the single SATA power and data combo cable by gently prying its large plastic connector away from the hard drive.
    • Use a spudger to disconnect the single SATA power and data combo cable by gently prying its large plastic connector away from the hard drive.
    When reconnecting the SATA cable, there is nothing to make the connector hold still, and it is hard to reach, so it took several tries. I ended up taking off the rubber baby buggy bumpers to get more room, and then jamming them back on after getting the SATA connector snugged up.
    bstaud - Replica
    If by rubber baby buggy bumper, you mean left speaker, then yes, I agree. Reinstall the hard drive before the left speaker.
    jerrid_foiles -
    Kudo to @jerrid_foiles! I was going crazy trying to attach the SATA cable until I took the two screws out of the left speaker and slid the top end of it aside by about 3/4 inch. Make the whole process SO MUCH easier!!
    jiclark - Replica
    We solved this by removing the hard drive tray screw, then inserting the cable into the SATA hard drive. Then hold the hard drive a bit out of the way to insert the 7.3mm hard drive tray screw.
    Marjie - Replica
    Agree with this method, found it an impossible task to reconnect the SATA connector until removed the tray screw, then it was relatively easy to reconnect and then replace the tray screw.
    daveedwards -
    Also agree with this method!
    jmorphett5 -
  28. Remove the hard drive assembly from the iMac.
    • Remove the hard drive assembly from the iMac.
    When reassembling, I found it easier to loosen the HD tray screw from Step 48 and pull the tray outwards from the left side in order to plug the SATA cable in more easily.
    Cool_Breeze - Replica
    Thanks! I, too, had a hard time reconnecting the SATA cable.
    boboswell -
    And DON’T do what I did, which is to remove the left speaker - which can easily lead to breaking the cable between the power on button and the power supply. The cable is routed through a hidden slot at the very bottom of the left speaker
    bsmith1 - Replica
    I did loosen the speaker so I could get a tool behind the SATA cable to push it on to the SSD drive. Otherwise hard to align cable.
    I found the easiest way to connect the SATA cable was to not screw the plastic hard drive tray down until you plug the drive in. That way you can easily push the connector in and due to the cable you’ve got some wiggle room. You can position the tray then just lift one end of the drive up and secure the screw. Then just push the drive down.
    Chris Caldwell - Replica
    This was the step that I had the most trouble with. I’m used to replacing a hard drive in a MacBook Pro, where the “plug” that you plug the drive into is a rigid thing that you can firmly press the hard drive into.
    With the iMac, the plug is situated on the end of a non-rigid cord, so the plug moves back when you try to snap a drive into it. Also, those two rubber gasket things that you adhere to the side of the drive really make it difficult to maneuver the now-overly-chubby drive towards the plug.
    After must frustration/concern, what I ended up doing was temporarily removing the rubber gasket things, using the “spudger” as kind of a lever behind the “plug on a cord” so that it didn’t move as much, and then pushed the gasket-less SSD into the plug.
    Once I got it connected, I put the rubber gaskets back on the sides of the SSD and kind of coaxed it down into place, using the pointy end of the spudger to get the chubby corner pieces to “sit” correctly in the rigid plastic tray that the SSD kind of rests in.
    Jack OnFlickr - Replica
    From another comment elsewhere on this repair, I *highly* recommend removing the two screws holding the left speaker in place, then sliding it just a tad out of the way to be able to easily attach the SATA cable. You don’t have to move it much to make the whole process so much easier!
    jiclark - Replica
  29. Peel the rubber hard drive bumpers up off the top and bottom edges of the hard drive. Peel the rubber hard drive bumpers up off the top and bottom edges of the hard drive.
    • Peel the rubber hard drive bumpers up off the top and bottom edges of the hard drive.
    Hi,
    I would like to change my standard HDD of 1To to a SSD following these instructions. All the SSD can be used like SSD Crucial BX100 500 Go or Crucial MX200 500 Go ?
    Thanks
    Denenden - Replica
    And Samsung 850 Evo, but you should think how to solve the cooler problem before you start, because there's no thermal cable in those SSD's.
    pzhivulin - Replica
    Hi, is it important to use a HDD as replacement/upgrade from the same manufacturer like it is on older iMacs with 3,5" HDD? I'm thinking of the thermal sensor (which isn't there in this case) and the hispeed fans issue. Any hints appreciated :)
    Mac - Replica
    there is a cable adapter you can buy with an inline thermal sensor on it to attach to the outside of the drive
    Danual Ansell -
    I was under the impressoin that this model, with it’s 2.5” drive, had no extra thermal issues like other older iMacs. Meaning you could just pop any other SATA 2.5” drive in there and the fans would operate normally.
    Other comments seem to imply this is not the case? I’ve never seen sensors or adapters for this model of Mac?
    John M - Replica
    You are correct, John. Per OWC Tech support, no thermal sensor cable needed for the 2.5” HDD, SDD on this 21.5” iMac.
    lamajr -
    I had to take out the 10 torr screw holding the bottom bracket done in order to get enough room to connect the new hard drive to the cable; before attaching bumpers
    provda - Replica
    thank you…easy repair
    rmolway1 - Replica
    I am so glad to discover that this process isn’t nearly as difficult as I thought it might be!! The hardest part is reattaching the SATA cable to the new hard drive, but removing the screws that hold the left speaker in place and sliding it aside just a tad makes it easy peasy!!
    jiclark - Replica
    It’s worth noting you may loosen q the left air Ram (plastic part) by removing the torx screws to gain extra access to the SATA cables if required.
    Andy Carver - Replica
    Does any formatting need to be done with the drive before installing? Or it’s a plug and go and MacOS will prompt the install?
    Phillip Ray - Replica
    any recommendations for the adhesive to use when re attaching the screen?
    Bryan Mclean - Replica
Conclusione
Altre 168 persone hanno completato questa guida.
Sam Goldheart
Membro da: 18/10/2012
408.108 Reputazione
547 Guide realizzate
iFixit Membro di iFixit
Community
116 Membri
11.204 Guide realizzate
Super awesome instructions, As always easy to follow, swapped out he drive pretty quick. makes me miss the magnets for sure.
Justin Weathersbee - Replica
Guide was great, didn't take long at all. I hope the adhesive proceeds to stick now that I put the glass back on!
MITG - Replica
Be sure to position the screen all the way down on reassembly. I sort of tried to hinge it back, resulting in a little space of a fraction of a millimeter. Had to push the screen down when attaching the rest of it.
Daniel JB - Replica
Great instructions, I chose to purchase the adhesive strips from Ifixit and they worked great, much easier than trying to shape your own plus they stick really well.
Alan Petten - Replica
Great instructions. Is it possible to replace HD with a SSD Samsung EVO ?
thanks
Claudio Tumeo - Replica
I believe the EVO is what I used in my iMac at home, but it was a while ago and I honestly do not remember for certain. In my experience though you can replace an HDD with pretty much any SSD that meets your capacity requirements. Some have better specs than others, but ~any~ SSD is going to have alarmingly better performance than an HDD. I have totally revitalized three computers that would otherwise have been put out to pasture, by the simple act of replacing the hard drive with an SSD. Working on an iMac is a bit more daunting than many others, but following these instructions, and being very "Zen" about it, taking your time, having the tools and materials laid out and ready at hand, being focused and not rushed, should result in a great upgrade, and a computer better than new.
Keith Gardner -
So on this model we don't need to worry about a thermal sensor or the fan going into overdrive after swapping the drive?
alyssaengleson - Replica
That's is correct :)
Daniel JB -
Great guide. One thing I did on the reassembly was to loosen the speaker next to the drive bay so that I could get my fat fingers in to push the SATA connector onto the new drive.
Good job!
James Metcalfe - Replica
Step 21 is a little nerve wracking … however, if you look closely, each corner had a small section of tape that looked like a starter strip. If you pull that up and then, once loosened, pull toward you - the entire strip of tape will come off making the display removal very simple.
Joe Husk - Replica
Yes. Buy the adhesive strips, and the tools, so you don’t have to stop and scrounge around the shop/basement/house/office for tool-equivalents.
bstaud - Replica
Very apprehensive at first when taking on upgrading my iMac 21.5” Late 2013 Hard Drive with a Samsung Evo 860 SSD. Followed this hard drive replacement/ upgrade guide, plus the ‘clone and existing drive’ and ‘how to re-apply your iMac display’ and had it done with 2 hours. Fantastic guides, easy to follow and carry out. Thank you.
Nicholas Lake - Replica
Upgraded my 2014 iMac to an SSD and Its so much easier than I thought it would be. From start to finish the teardown was complete in about 30 min. The wheel and cards worked perfectly and the adhesive was easy to use. I like tearing this one down better than the older iMac. No screws or magnets to deal with.
Joe Henry - Replica
Good instructions!
Thanks
dani - Replica
Hi, dont you need to replace / substitute the thermal sensor? thanks
Christian Fleckl - Replica
No, there's no need on this model!
Daniel JB -
Awesome.. was about to upgrade my ram but used SSD as external and seems fast.. going to follow the instruction and replace with Samsung Evo 860
Crazy Punk - Replica
Would you mind linking me to the specific Samsung Evo 860 you used? I think I’m going to attempt this switch, and a RAM upgrade too, but I don’t want to get the wrong model!
Thanks
Daniel Hearn -
unscrewing the speaker to shift out of the way makes plugging in the new hard drive much easier.
With the tools from iFixit I encountered no problems, not even the ones mentioned in some comments. Everything worked fine. Just make sure to carefully reattach the display cables and keep their plugs clean.
Bachsau - Replica
do you need a special ssd disc to make it fit in the iMac or can i just buy a Samsung ssd?
Oynes - Replica
Very good guide. Just what i needed
Susanna verner - Replica
Hi after installation what do we do with the hard drive? Does it need formatting and installing OS?
Double C - Replica
2013 iMac. What if you replaced it with an SSD? Anything extra needed?
Danny Hoover - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 81
Ultimi 7 Giorni: 507
Ultimi 30 Giorni: 2,258
Tutti i Tempi: 99,769
