Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
Prereq only.
  1. Lift the hard drive from the edge nearest the fan and pull it slightly out of its recess. The hard drive is attached by two cables, do not attempt to fully remove it from the iMac just yet. The hard drive is attached by two cables, do not attempt to fully remove it from the iMac just yet.
    • Lift the hard drive from the edge nearest the fan and pull it slightly out of its recess.
    • The hard drive is attached by two cables, do not attempt to fully remove it from the iMac just yet.
  2. Disconnect the SATA power cable. Disconnect the SATA power cable.
    • Disconnect the SATA power cable.
  3. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. Unplug the SATA data cable from the hard drive. Unplug the SATA data cable from the hard drive.
    • Unplug the SATA data cable from the hard drive.
  5. Lift and remove the hard drive from the iMac.
    • Lift and remove the hard drive from the iMac.
Conclusione
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
Sam Goldheart
Membro da: 18/10/2012
414.165 Reputazione
547 Guide realizzate
iFixit Membro di iFixit
Community
126 Membri
11.824 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 68
